Results 1 to 6 of 6
Thread: Vitz Brakes Hard
    kash856's Avatar
    Jun 2006
    41
    7
    Default Vitz Brakes Hard
    Hi Guys,
    Hope all r fine. Well from many days i was studying the topics in discussion form quite satisfied with fruitful answers. Do help me having problem with my vitz brakes on cng its getting stucked on slow.
    Dont know whats the matter with it and that little tiny check light playing games with me on..off ... on ...off
    Regards,
    Kash
    LOGAS's Avatar
    Dec 2006
    57
    1,921
    @Kash856.................
    You are not the first n only one faceing this trouble, Vitz, Civic 1800cc, XLI, Corolla X and few other new models also have this problem.
    Reason is that on treditional efi cng conversion kits, you by- pass the ecu when you are on cng. So your car's mostly systems and gadgets cannot get signals, emulator provide false signals to ecu that the injectors are working, but you cant fool the whole ecu...........
    Solution............there is a cost for everything.......
    Economy With Security And Durability.
    kash856's Avatar
    Jun 2006
    41
    7
    Thanks logas for the information. My friend suggest me for oxygen sensor also but I think it will also not work fine. Regarding with different cars as u have mentioned problem occurs rarely in those cars but vitz is on top in this raly. Regarding with the Solution means "Cost" do let me know......Plz
    Regards,
    Kash
    LOGAS's Avatar
    Dec 2006
    57
    1,921
    Best Solution is SIS Kit for all EFI cars.
    mwaqar's Avatar
    Oct 2006
    169
    @logas sir,
    pls come down a little and suggest a less costly solution.
    I've seen ur other products @Automax and found them quite good even from outlook.
    kash856's Avatar
    Jun 2006
    41
    7
    Logas sir,
    Thanks for ur solution but according to my knowlege people r removing SIS kits from their cars and installing EFI kits. For Instance Liana... The bug in SIS Kit is it directly hits the computer due to which Lum Sum amount is required to remove the Bug.....
    Regards,
    Kash
