Results 1 to 10 of 10
Thread: Vitz Cng / petrol problem
    amirpk_143's Avatar
    Aug 2007
    30
    93
    Default Vitz Cng / petrol problem
    i convert my vitz 1.3 on cng but after conversion check engine light is on , but it turns on after 5 to 8 mins when i start engine...
    and also facing problem on petrol maybe dere is sum problem in fuel pump..
    i change plugs , air filter but still facing same problem
    car is good on cng but on petrol ots jerks sum times ...
    plz help me in that matter...
    2fast_to_furious's Avatar
    Mar 2006
    Dubai
    33
    1,629
    7 Post(s)
    did the mechanic in cng conversion make air intake pipe narrow or somting like that...becaus i was facing same problem only on petrol, on cng it works fine...
    WhEn ThInGs Go WrOnG, DoN'T Go WiTh ThEm.
    Mar 2006
    Dubai
    33
    1,629
    7 Post(s)
    As for check engine light is concern, in most of ECU it remained on due to O2 sensor..may b expert comments better on this issue..
    amirpk_143's Avatar
    Aug 2007
    30
    93
    yah i hope so .... yar jab bhi jao mechanic kay pass 2 din theek chalti hay den da same problem.....
    which city u r from and which vitz u have 1000 cc...? or model .?
    saadsmalik's Avatar
    Oct 2005
    25
    3,345
    4 Post(s)
    another car destroyed by cng...
    My height has stopped increasing, my width compensates for it.
    Mar 2006
    Dubai
    33
    1,629
    7 Post(s)
    im from Rawalpindi, i have yaris 2000 manual...i used to this sort of problem...but now make it rectify myself...so no mechanic...
    amirpk_143's Avatar
    Aug 2007
    30
    93
    so u mean ur car iz perfect now on petrol...
    Mar 2006
    Dubai
    33
    1,629
    7 Post(s)
    u r right this happened to me on same day when i tunned my Yaris 2000 manual transmission on CNG...however what i sort out problem was air intake, fuel mixture...seems u have same problem..
    amirpk_143's Avatar
    Aug 2007
    30
    93
    now wt should i do ..... or if u r online on yahoo or msn den giv me ur id
    Mar 2006
    Dubai
    33
    1,629
    7 Post(s)
    sibtain_rajpoot@hotmail.com
