Results 1 to 11 of 11
Thread: !!!Trouble Shooting! (Vitz) Help!!!!!!!
    TuNpArTy's Avatar
    Mar 2006
    35
    949
    Default !!!Trouble Shooting! (Vitz) Help!!!!!!!
    guys i need your help
    the other day i had to take 2003 vitz to sumplace as it was standing at for last 3 days of eid...now the problem is it show me Red temperature lite with in 1/2 km of its first run after 3 days...things i checked
    1) coolent in the radiator was full
    2) fan was working(automatically as they come with vitz)
    3) i just filled the water container thats connected to the radiator ...after that the problem pretty much disappeared!
    Ne ideas whats wrong with it?
    A Car should not leave its mark on the road, but in ur head!
    hash4u's Avatar
    May 2005
    38
    24,377
    18
    404 Post(s)
    13 Thread(s)
    13
    thermostat valve malfunction?
    TuNpArTy's Avatar
    Mar 2006
    35
    949
    hmmm maybe thats what i could think of ....could there be ne other reason behind it?
    sumhow i cant figure out ne other thing!
    Newbie Follow
    anjoyia's Avatar
    Oct 2007
    36
    AOA, Please Remove the Therosate Valve. and Make sure your Temperature guage wire is not touching the body. if wire is short then you will also get his lite.
    TuNpArTy's Avatar
    Mar 2006
    35
    949
    thanx guys!
    btw how much water should a on average wastes daily?
    n should the water level checked daily?
    TuNpArTy's Avatar
    Mar 2006
    35
    949
    bump!
    Ne one elsE?????
    TuNpArTy's Avatar
    Mar 2006
    35
    949
    @anjoyia
    if i remove the therosate valve wont that make the fan direct ??
    tyrone_40's Avatar
    Jan 2005
    Other
    1,600
    13 Post(s)
    I think checking the water container connected to the radiator once a week should be fine, as long as there is no leak.
    Mine was a bit low when I bought mine. So I just added a little water to the coolant in the container to bring it upto the full mark.
    rehana's Avatar
    Feb 2007
    40
    255
    try bleeding the cooling system....could be trapped air.
    -take it to the limit!
    TuNpArTy's Avatar
    Mar 2006
    35
    949
    shouldnt that air b released by its self? rather bleeding the system?
    kwa3001's Avatar
    Sep 2010
    43
    31
    dear i solved ur problem bt on call,,,,,,,?03335101482
