Results 1 to 17 of 17
Thread: Vitz engine swap
    N2O
    N2O is offline
    N2O's Avatar
    Nov 2005
    2,317
    15 Post(s)
    Default Vitz engine swap
    guys my friend here is thinking to swap his vitz engine for either 4afe or 20v,depending on the alteration required,he wants minimal alteration done to his engine bay area,so want ur advice which engine wod fit with minimal alteration?
    *can a 20v be swapped? if so what about suspension? can the gear assembly fit in too?
    *how much wod both engine costs and a rough idea on the swapping charges.
    knowledge is horsepower
    born_2b_wild's Avatar
    Jul 2006
    5,339
    33 Post(s)
    I think he should Go for 4efte ... 1.3 turbo
    Live To Ride ..... Ride To Live
    https://www.facebook.com/seeyouinmyrearviewmirror
    palaykhan's Avatar
    Jan 2006
    Peshawar
    28
    7,378
    2zzge
    my rides.....!!!.AE90 4AFE supercharged nitrous.........!!!.http://www.youtube.com/watch?v=IhNhlNoYq8s......!!!civic 3g hatch B20 almotor nitrous............!!!intgera B18b LS Vtec nitrous
    salik990's Avatar
    May 2006
    33
    4,268
    57 Post(s)
    @N20: have u heard bout new yaris/vitz sport with 1.8 vvti engine...it's 140bhp.....but i think 4efte is better option.....i ve seen turbo vitz in black color with hood open...damn fast...donno if it's 4efte or vitz engine was turbocharged
    My lugnuts require more torque than your Vtec can put out...
    SER_GTR's Avatar
    Nov 2005
    30
    9,737
    16
    489 Post(s)
    19 Thread(s)
    Both Can Be Swapped And Both Can Be Done.....!And Have Done.....!
    In Japan....4AFE and 4AGE Powered Vitz And Platz Exist...!
    Well As Far As Alteration...So Either Swap 4AFE or 4AGE...Both Need Same Mounts Work Bcz Both Belongs From A series...! You Need Suspension And Braking To Be Good...!
    Vitz Have ABS And Have Good Braking B/w....!
    Same Axles Work.....! Before Working....Check For Suspension And Axles Work Before Getting It Into.....!
    If He Need Economical and Hassle Free Swap With Power Like 4AFE...I Suggest 1NZ-FE VVT-i....From JDM Corolla...!
    (y) Its Gonna Rock..Same Mounts...Things Really Match B/w Stock And This...!
    4EFTE Can Also Fit...But Have To See Turbo Can Really Cover Area And Also Let Space For Radiator Bcz Day Is Not Long In Length....!For That..Body Alteration Is Needed Which I Don't Think Is Good....!4EFTE Gonna Be Hell..Just Fitting Comes...!
    Regards
    TOYOTA Sprinter 86- AE80 DOHC 20v'D TOYOTA Corolla 98- AE101 4AFE 16v
    palaykhan's Avatar
    Jan 2006
    Peshawar
    28
    7,378
    agree u on this but 2zzge will rock in it (y)
    Ghuncha's Avatar
    Aug 2005
    35
    5,967
    19 Post(s)
    i will recomment 2zzge/2zzfe as its z generation.... as is the one of vitz..
    for the a series i think you will need serious alteration as the intake/exhaust layout is on the opposite side in both the generations..
    another factor will be the weight as 2zz-ge is a solid 30~40 kg lighter than the 20v, and the engine being in the critical position regarding the handling of the car, with 20v you will only have a drag car...
    this is just my thinking and i stand here to be corrected....
    its all about power to weight ratio...
    Retaliator's Avatar
    Apr 2006
    Rawalpindi
    8
    1,445
    13 Post(s)
    can u put altis's vvti 1.8 engine in it? it wl b gud dont u think.
    sd_sig's Avatar
    Dec 2003
    1,866
    Aridsoul used to tell me abt Vitz 1.8(altis engine) factory fiitted which was for sale in lahore.
    Think 100 times before you take a decision, But once that decision is taken, stand by it as one man--]M.A Jinnah
    [ A L I ]
    KillaCam's Avatar
    Sep 2006
    24
    2,618
    @ali
    to kahan se online aya:O:O
    -Turbo'ed H22a charade
    -V6 ; BAMA tuned+CAI
    haroon131's Avatar
    Aug 2005
    31
    299
    2ZZ-GE is best option, coz it s equipped with 6-speed manual tranny
    there is one for sale in karachi, u can get a qoute 0321-2400464 Ayoub, he have many shops in Shereshah.
  12. #12
    Jul 2006
    5,339
    33 Post(s)
    ^^ 2ZZ-GE .. 190 BHP in Vitz .. it would fly ...
  13. #13
    Ghuncha's Avatar
    Aug 2005
    35
    5,967
    19 Post(s)
    the 190 hp 2zz-ge only came in lotus elise, the one that came in runx is max 180
  14. #14
    7650's Avatar
    Dec 2006
    27
    1,153
    in my opinion 4efte will be great,
    about 4age Man that engine is huge and is a power house 160 hp
    if u want a perfect dragster then go for 4age BT which is kind a hard swap for vitz.
    but if u want to enjoy speed go for 4efte !
    YOU want to PLAY, YOU got to PAY .. Performance doesn't come cheap. (Stock B16a Motor in a light weight Hatch.)
  15. #15
    N2O
    N2O is offline
    N2O's Avatar
    Nov 2005
    2,317
    15 Post(s)
    thanks for ur input guys
  16. #16
    lowresolution's Avatar
    Jun 2006
    35
    3,189
    21 Post(s)
    i read some where a honda engine was also swapped in a vitz, b18c if i recall correctly ...
  17. #17
    SER_GTR's Avatar
    Nov 2005
    30
    9,737
    16
    489 Post(s)
    19 Thread(s)
    Yup....!
    True...!
    So Many Things Can Be Swapped...But A Good Mean Swap Is What He Is Asking For.....!
    And TOYOTA is Gonna Be Suitable Rather Than HONDA
