Results 1 to 9 of 9
Thread: problem with my Vitz 2002 ,,, plzz help
    BKid's Avatar
    May 2005
    36
    381
    Default problem with my Vitz 2002 ,,, plzz help
    Dear Vitz owners,
    last 3 or 4 days i've been having a serious problem with my vitz 2002 . in the morning when i start the car and try to put on reverse to backup ,, literally nothing happens as if its in N or P . this is really strange but more importantly its serious too , its CNG but nothing happens even if i convert it to petrol , D works fine though.
    someting wrong with the tranny , keep in mind that last 3-4 days its lil much cooler that before in khi. i really appreciate if someone can help me or face similar situation with his vitz ,coz its appears to me that Reverese gear is not engaging or something , after driving some 2, 3 km , ther reverse starts to work , please brothers help me or name a good mechanic in karachi , regards
    juneyd's Avatar
    May 2007
    Peshawar
    35
    22
    Check the gear oil and change it if u havent. its a common problem with imported vehicles that there gear oil is so bad, its doesnt look like oil anymore, and it can screw the gear box (i hope it hasnt happnd for u yet).
    BKid's Avatar
    May 2005
    36
    381
    thanks for ur reply Juneyd ,
    i've checked the oil , it looks clean but i will change it today anyway , any recommendations for the oil , as far as i know it should be dexron II , i hope changing oil should solve the problem
    tyrone_40's Avatar
    Jan 2005
    Other
    1,600
    13 Post(s)
    Noooooooooooooooo its not Dexron II. Its Toyota ATF Type T-IV
    saulatqureshi's Avatar
    Oct 2007
    46
    21
    Change your ATF immediateley with TypeIV, and check th eextended life coolant if its milage more than 35000 KM. cause antifreeze also circulates and cool the transmission and maintains its temperature.
    BKid's Avatar
    May 2005
    36
    381
    @tyron_40
    where can i get type T-IV, at toyota dealships they have TOYOTA ATF D-II. its s round black metal can 1 ltr capacity , thats all they have , these ignorant ppl dont have any Type T-IV atf . they said thats all they have and they always replace it with Toyota ATF D-II.
    do you know any place where i can get Type T-IV atf
    btw my car has 54000 km on the clock , i am not sure if its the right milage or tampred
    tyrone_40's Avatar
    Jan 2005
    Other
    1,600
    13 Post(s)
    I got my the last time from Toyota Motors at Khalid Bin Waleed Road. They also have it at Plaza I saw it there too in the shops.
    devilsadv's Avatar
    Jul 2006
    24
    1,749
    Do you mean that the car doesnt work at all in the R mode when its cold? Or you dont feel the slight bump after you put it into R after P?
    Im confused
    ***,gass or grass...
    Nobody rides for free
    devilsadv's Avatar
    Jul 2006
    24
    1,749
    by the way how is your car doing on CNG?
    Is it ok with the pick ?
    I need to know inshallah ill also be buying a vitz and putting CNG
