Results 1 to 11 of 11
Thread: vitz engine check light always on at CNG
    jzsaeed's Avatar
    Jan 2007
    Rahimyar khan
    34
    Default vitz engine check light always on at CNG
    Hey buddys!
    1. I own a vitz 2003 model auto transmission and i am running it on cng for last 2 years. the engine check light never goes off when i drive on cng but on petrol it is otherwise. so anybody plz let me know if there is any problem with the ECU (i m not very good at technicalities).
    2. Secondly, it does not go more than 105km/h on cng after a great effort where as my friends 2000 vitz with similar condition goes more than 120km/h with a blink on cng. i m very much desperate at this situation.
    3. Plz tell me if there is something to be replaced apart from Fuel Filter, Oil and Air filter (coz i have already done that but no improvement observed). and what is the best place or a good mechanic in Lahore who understands all these things wisely
    I will be much obliged.
    Thanks and regards.
    Jahanzaib Saeed
    Waqar_14's Avatar
    Oct 2005
    here
    26
    4,558
    frstly get the catalytic converter removed. that shuold let the engine breathe easier. then get it professionaly tuned. thats all i can help with. strictly petrol.
    Retrograde's Avatar
    Dec 2004
    40
    2,439
    dude i believe there is something wrong with the CNG emulator, get it checked
    Hail to the King Baeeeebay!!!!
    blueanwar's Avatar
    Apr 2005
    42
    224
    hmm! a similar kind of problem came to me few days back n was rectified accordingly
    An engine scan by a campatible scaner is the right way to go.
    SHOTTY42's Avatar
    Mar 2007
    Rawalpindi
    25
    hmm! i have got vitz 2002 and facing same problem of check engine light only on cng. i have done every thing engine tuning, cng check etc but check engine light iz always there. how much kms your vitz can do in 45 cylinder. plz reply. my vitz average in 45 kg cylinder iz 85-95 kms.
    sun2sunny's Avatar
    Sep 2006
    31
    572
    shotay ur average is very good....
    jz saeed ... go for tomasato emulator+advancer vitz ka geniune wiring wala set lena koi cuting nhi karni parti
    jab vitz ki wiring main cuting kar k advancer lagao to chek light on ho jati hai aur pick nhi banti ... personal expieriance hai mera
    usarwar's Avatar
    Aug 2006
    30
    993
    Hi my friend owns a vitz 2004 he had the same problem a efi mecanic told us that vitz has a petrl sensor in it and when converted on cng it malfunctions he told us to go on a long trip on cng and then the chk-engine sign would be removed we took the car to lahore and when returning the check engine symbol was dissapeared this is the only way to remove the sign bt again if the car is driven on petrl for more than a day the sign comes back again....
    razapower's Avatar
    Nov 2004
    40
    403
    jzsaeed
    It is your o2 sensor sending the alarm.
    When you switch from petrol to gas, the emissions from exhaust change (due to change in fuel type), causing the o2 to send alarm.
    It is not a problem as long as the alarm disappears on petrol.
    FLi_GTi's Avatar
    Jun 2005
    Ahead of you!
    38
    3,116
    Its your 02 sensor. The ECU cannot convert to closed loop operation due to the 02 readings when the car is immediatly turned to CNG. The MIL is caused by the pulsewidth increase on cold starts. Simply put,just start the car on petrol, warm it up till the idle settles down. Switch to gas, no MIL.
    |||||||||||||||||||||||||||||| C2G - GARAGE | SHOP | TUNE +92 346 8776643 |||||||||||||||||||||||||||||||
    Site Banned Follow
    scharee's Avatar
    Dec 2005
    36
    7
    1) No issue with the ECU, the engine check light is because the ecu prompts error on
    CNG coil although i got mine checked several times so ignore it as long as u r on CNG. but if u start on petrol and stay on n the EC blinks get your petrol sensor checked.
    2) u definetly need a tune up, cause mine dose 130 km/hr with minimum efforts on CNG w/o AC. & round 120 with AC. replace your plugs with atleast 2 pin. clean the air filter regularly n get it replaced every 3rd month at max.
    3) regular clean up with any good carb- cleaner
    Site Banned Follow
    scharee's Avatar
    Dec 2005
    36
    7
    n dudes (PROs correct me if im wrong) ECU wont detect if somtin is wrong with CNG or related devices...
