Results 1 to 8 of 8
Thread: vitz(japan) vs yaris(uk)
    iki786's Avatar
    Jun 2007
    23
    11
    Default vitz(japan) vs yaris(uk)
    Is there any difference between vitz or yaris
    ikram
    toofast's Avatar
    Sep 2004
    Chizhou
    18,163
    31 Post(s)
    Usually is but not sure what. It should not be big one.
    Even if you are on the right track, you will get run over if you just sit there.
    iki786's Avatar
    Jun 2007
    23
    11
    i just wanted to find because my cousin is buying his first car and he is not sure whether to get a imported yaris or tobuy a vitz from pakistan
    ikram
    2fast_to_furious's Avatar
    Mar 2006
    Dubai
    33
    1,629
    7 Post(s)
    yes there are many differences between yaris n vitz
    first of all comfort wise yaris is superior...
    yaris have more options then vitz
    ..i used to have drive both n this time ihave yaris..
    if u need specifi detail i may let u know...
    WhEn ThInGs Go WrOnG, DoN'T Go WiTh ThEm.
    Mar 2006
    Dubai
    33
    1,629
    7 Post(s)
    in vitz there are only 1 but in yaris there are 2
    vitzjapan vs yarisuk -804337
    builtin fog-light(instead of of real reverse light it have fog light), head light bulbe controller...
    Intergrate Panel for sound n other stuff, in cabin
    temperature gauge, milage meter...buitin function, All the
    FM channels works fine from 87-105(most of vitz there
    work only 89.0) nice built cd player with 4 speakers 2 in
    das n 2 in frond side..
    images/forums/2008/1/22/aftab805_UBZ_PakWheels(com).jpg]
    5forward that is most good feature for at least Pakistan
    last but not the least it have digital RPM which vitz don;t
    vitzjapan vs yarisuk -804338
    vitzjapan vs yarisuk -804339
    vitzjapan vs yarisuk -804340
    vitzjapan vs yarisuk -804341
    Mar 2006
    Dubai
    33
    1,629
    7 Post(s)
    buit-in fog lights
    vitzjapan vs yarisuk -804359
    taimurs's Avatar
    Apr 2007
    35
    133
    man, my vitz has all the things you mentioned, except the digital rpm, which i wish it did have! other than that i think the yaris comes in 1.3 whereas the latest vitz, at least in pk, are 1.0
    i'd get a yaris, if i had known before.
    Bilaltq's Avatar
    Mar 2004
    Select City
    26
    10,311
    10 Post(s)
    Yaris in the US comes with a 1.5L SOHC VVT-i engine. In pakistan you can import the 1.0L or the 1.3. I think a few people have even imported the AWD vitz
    This comment was made by a person with a tested IQ of negative 9.
