Results 1 to 13 of 13
Thread: how much atf and engine oil needed in vitz.
    sun2sunny's Avatar
    Sep 2006
    31
    572
    Default how much atf and engine oil needed in vitz.
    plz tell me how much ATF and oil needed in 1000 cc vitz 2004
    sun2sunny's Avatar
    Sep 2006
    31
    572
    bump
    DreamGirl's Avatar
    Aug 2007
    32
    129
    4 Post(s)
    4 liters for Atf and 3.5 liters for engine
    moak89's Avatar
    Aug 2006
    86
    1,807
    6 Post(s)
    and which atf is recomended?
    www.TheTweakShop.pk
    sun2sunny's Avatar
    Sep 2006
    31
    572
    yaar mai ne to 2 liter dala hai is main?? aur us main se nikla bhi do liter hi hai ATF dex. 2 from zic???
    heddie19's Avatar
    May 2009
    23
    45
    2 litre is required
    naya wala model (2nd generation asks for 4 litre)
    mene abhi kal 2 litre hi dalwaya hai.
    Faisalsaeed11's Avatar
    Nov 2012
    460
    4 Post(s)
    Check the hot and cold guage....should ve in between
    Sent from my Nexus One using Tapatalk 2
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    do that with engine running please. some people have posted here that they check and fill ATF with engine off.. It is wrong and will result in underfilling.
    waqar19's Avatar
    Aug 2011
    25
    1,110
    32 Post(s)
    3 Thread(s)
    Digged
    how much atf and engine oil needed in vitz -1175656
    The best car safety device is a rear-view mirror with a cop in it.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    for the better good.
    rizkhan2010's Avatar
    Oct 2011
    37
    1,858
    20 Post(s)
    7 Thread(s)
    ^^ xulfiqar bhai, without gear oil wont it damage the transmission if we run the engine at the time of gear-oil drain interval ?
  12. #12
    umer331's Avatar
    Mar 2013
    6
    Quote Originally Posted by rizkhan2010 View Post
    you are right i agree with you
  13. #13
    vagabondpiper's Avatar
    Jun 2010
    34
    1,325
    23 Post(s)
    He is just mentioning for checking and filling , not draining and refilling . Under no circumstances car should run wuthout transmission oil .
    Sent using Mobilink Indigo
    No one cares for Toyota more then Toyota
