plz tell me how much ATF and oil needed in 1000 cc vitz 2004
bump
4 liters for Atf and 3.5 liters for engine
and which atf is recomended?
yaar mai ne to 2 liter dala hai is main?? aur us main se nikla bhi do liter hi hai ATF dex. 2 from zic???
2 litre is requirednaya wala model (2nd generation asks for 4 litre)mene abhi kal 2 litre hi dalwaya hai.
Check the hot and cold guage....should ve in between
Sent from my Nexus One using Tapatalk 2
do that with engine running please. some people have posted here that they check and fill ATF with engine off.. It is wrong and will result in underfilling.
Digged
for the better good.
^^ xulfiqar bhai, without gear oil wont it damage the transmission if we run the engine at the time of gear-oil drain interval ?
you are right i agree with you
He is just mentioning for checking and filling , not draining and refilling . Under no circumstances car should run wuthout transmission oil .
Sent using Mobilink Indigo
