i had changed my vitz ATF wid DX iii is it ok ? ....
bump
wat is ATF..??? wat is DX iii..???:S
Check what is written on the Dip Stick. I guess its ATF- T-IV and not DXIII
yes but .... toyota ka oil use karna ???? koi hadeees thori hai
Hello there!
I will strongly recommend ATF from genuine Toyota, the reason is that it is specifically designed for toyota Auto Gear Box.........in emergency you can use other ATF like Dexron III etc.
Hope you follow the advice!
