Page 2 of 7 FirstFirst 1234 ... LastLast
Results 21 to 40 of 139
Thread: Vitz engine swap! 1.0 to 1.3 or 1.5 (2nzfe,1nzfe)
    nabeeltahsin's Avatar
    Sep 2006
    31
    68
    Default Vitz engine swap! 1.0 to 1.3 or 1.5 (2nzfe,1nzfe)
    Fellas!
    I plan to swap my 1szfe(1.0vvti) engine to 2nzfe(1.3vvti) or 1nzfe(1.5vvti).My Chasis is SCP10.
    I do have past experiences on older cars, experienced and knowing buddies are welcome give me pros and cons.
    Regards.
    The best car safety device is a rear-view mirror with a cop in it.
  2. #21
    Sep 2006
    31
    68
    To: Type R
    Hmmmmm....where do u live? which city i mean? and for which car r u importing this engine?
  3. #22
    devilzmafia's Avatar
    Jan 2008
    Canberra
    1,397
    @nabeeltahsin
    Bhai mere,get a cheap 4AGE,7AFE or 4EFE/4EFTE....i think these 1nzs are gonna be pretty expensive...but they do have their advantage as they will fit on your vitz bolt to bolt and power wont be lost.
    i might get NA swap for my vitz aswell...this 1szfe is pretty underpowered...i couldnt travel properly on motorway with auto tran,ac on and four people.
  4. #23
    Jan 2008
    Canberra
    1,397
    Other than that Altis` engine would be a very good choice too...dont noe whether it fits bolt to bolt...and dont noe about the price aswell,but i think it wud be expensive !!
    Also Altis has alot of power.I can asure you that you`ill be literaly ra**** cl9s and r18as(1.8 ivtec)
  5. #24
    TypeR's Avatar
    May 2004
    28
    2,318
    3 Post(s)
    I live in lahore ! and its for my belta !
  6. #25
    atb160's Avatar
    Oct 2006
    34
    146
    If you want to go to the hassle of swapping rather than buying a 1.5, go with the 1.8. 4A and 7A - I don't know how easily they'd be mounted in your car. But as for the NZ, the 1.3 and 1.8 both come in the corolla, so should be similar.
    Brakes are not the only thing you will need to replace. You'll have to replace the dampers, springs, swap bars, probably have to add strut bars both front and rear to add structural rigidity and reduce body flex. Will have to put bigger tires and maybe 6 inch wide wheels, more if possible.
    The good thing about the vitz is that TRD makes a lot of parts for it, so a lot can be done fairly easily.
    Best of luck.
  7. #26
    MODS's Avatar
    Oct 2007
    Keeping a Vigil on PW in
    86
    285
    1079 Post(s)
    Thread moved to Correct Section
    ACT responsibly Pakwheelers!
  8. #27
    aabirgti's Avatar
    Nov 2005
    Islamabad/Walsall-UK
    31
    990
    hmmm i hav been plannin an engine swap for a long time in my vitz but i was wanting the 2zz-ge 1.8 180hp engine from the celica gts which sum1 in england fitted but in pak sum1 fitted a 1.6 n it was a bolt on fit but had a fuel problem. i suggest a 1.5 rs as its gonna give the least probs with other engines u hav to do alot of changes n with the 1.5 there r alot of aftermarket mods for it
    YES, i drive a Miata and NO, im not a hairdresser!!! Eunos Roadster S-limited, Bilstein, Torsen LSD, Borla Dual Exhaust, Nardi steering, Genuine red leather!
  9. #28
    ASSHAL's Avatar
    Jun 2008
    24
    300
    @nabeeltahsin
    dude i dun hav ny suggestions 4 u bt seriously go 4 it nd wud luv 2 see an altis engine in it it will surely give a beating 2 cl7 nd 1.8 civic will b a nobrainer ifrnt of it
  10. #29
    tauseefmutwahir's Avatar
    Oct 2006
    Peshawar / Knoxville, TN
    33
    1,298
    @nabeel
    if u can go for the altis engine, brakes are already abs but if u want u can get steel braided lines for ure brakes or some aftermarket brake pads but let me also tell u this that most of the senior members of this site and a lot of the junior members have swapped higher powered engines in their cars and done minimal upgrades to their brakes.... go for it... one step at a time..
  11. #30
    TypeR's Avatar
    May 2004
    28
    2,318
    3 Post(s)
    If anyone wants to buy my 1NZ-FE let me know !
  12. #31
    wasay_ahmed's Avatar
    Nov 2006
    29
    4,959
    12 Post(s)
    put 4AGE in ur vitz
    DIY The Best Workshop on the Holy Planet!
    Every thing changes,Its only the "change" which never changes.
  13. #32
    foxy_the_beast's Avatar
    Aug 2007
    Rawalpindi
    23
    340
    i will say that put 4age or 4efte.but ther iz no space for h22 but still just imagen if u put h22 wat willl happen....
    -DONT CUT ITS HANNI"S-
  14. #33
    Nov 2006
    29
    4,959
    12 Post(s)
    3SGTE better option than H22 and it would remain TOYOTA aswell lolz anyways if daily driven then 4age
  15. #34
    Site Banned Follow
    smartracer_225's Avatar
    Dec 2007
    Pindi gheb
    36
    833
    @foxy_the_beast
    check your mail....
    @cool viper
    u also,
  16. #35
    cool_boy_in_vipersrt10's Avatar
    Jan 2007
    Birmingham
    27
    1,169
    as suggested by ser_gtr...if u want sum real power go wid the 2zz-ge 1.8l VVTL-i...wid 190 bhp...cmes in JDM celice...it will b bolt on and will give nice power to weight ratio...
    Long Live Pakistan , <3 <3 <3
  17. #36
    Retaliator's Avatar
    Apr 2006
    Rawalpindi
    8
    1,445
    13 Post(s)
    bhai i ve got a great idea
    why dont u put the 1.8 ltr engine and replace its fly wheel wid a smaller one.
    it ll give u the speed and less braking power will be required.
  18. #37
    helliceo's Avatar
    Mar 2005
    Rawalpindi
    24
    3,334
    therez a person in rwp , scheme who has 1.8 turbo charged engine in his cream clr Vitz
    Saad Akhtar Khan...
  19. #38
    razapower's Avatar
    Nov 2004
    40
    403
    helliceo
    what engine was it?
    can you give some details?
  20. #39
    aabirgti's Avatar
    Nov 2005
    31
    990
    @helliceo
    pls tel me more abt that vitz ive been tryin to get hold of a 2zzge but its way too expensive
  21. #40
    smrn's Avatar
    Jan 2007
    36
    209
    I saw a few 1NZ-FEs in Peshawar Shoba bazaar last week.
    The price range was from 60,000 to 85,000.
    M/T in clean condition was for 65,000.
    Above were the demands, with complete ECU/Wiring and transmission. Did not negotiate.
