Results 1 to 11 of 11
Thread: VITZ A/T DETAILS
    faisal2193's Avatar
    Dec 2006
    38
    118
    Default VITZ A/T DETAILS
    Dear Members. I have owned a Vitz A/T Car. Its my ever first A/T Car. kindly brief its transmission details like as far i know D for normal, obviously R for reverse and N for Neutral. Rest of the transmission are for which purpose. kindly describe about O/D (over drive). Regards.
    mafzaltareen's Avatar
    Sep 2005
    2,269
    2 Post(s)
    d=all four gears works
    2=the transmission remains in first two gears and gives extra pick to the car
    l=only first gear is used and it is used for extreme power when you are climbing a rampage
    o/d off=in o/d off mode the car remains in first three gears and is used to get better pick up till the speed of 100-110
    http://www.facebook.com/V8Rx8
    HumanGenius's Avatar
    Mar 2007
    22
    4,547
    P R N D 2 L is most likely your transmission.
    P=Park, locks the transmission with a parking pawl/pin and the front 2 wheels are locked. If the handbrake is down and gear in Park, your car wont go anywhere regardless of the in/decline.
    R=Reverse
    N=Neutral, all 4 wheels free and used primarily for towing purposes.
    D=All gears active, in a Vitz it means 4 gears.
    2=Transmission is restricted only to 2 gears and the gearbox will not allow the car to exceed 2nd gear. Used for towing and climbing/going down inclines. Max speed around 30-45km/h
    L=Transmission is restricted only to 1 gear and the gearbox will not allow the car to exceed 1st gear. Used when maximum engine power is needed. Max speed around 20-30km/h
    od is overdrive and gives an extra gear for efficiency & speed I believe.
    What good is a Genius without the Human aspect?
    akifnaseer's Avatar
    Sep 2006
    38
    326
    In addition:
    2 & L are for more powerful engine braking. Thats what the owners' manual says.
    O/D is the overdrive gear, equivalent to 4th gear.
    Inspire's Avatar
    Jan 2008
    30
    604
    2 Post(s)
    yaar O/D juzt enable 4th gear simple if o/d off and ur transmission is in D it will go till 3rd gear not move to 4th unless u ON O/D..
    Sep 2005
    2,269
    2 Post(s)
    @inspire
    i agree
    ali55's Avatar
    Jun 2008
    31
    92
    Vitz looks like a RAT.
    Lewis is pure, raw, undiluted talent of a massive order.Lewis Hamilton is the best. Dont argue with me or I am going to kick your teeth down your throat.
    waris_arsh's Avatar
    Jul 2007
    27
    447
    5 Post(s)
    Vitz rocks
    TuNpArTy's Avatar
    Mar 2006
    35
    949
    so in other words if you are on a highway itz better to turn on O/D so that you get best mileage and you dont burn up anything in your with O/d Off since 3rd will not be sufficient for the long rountine!
    isnt that the case guys?
    regards
    Farhan
    A Car should not leave its mark on the road, but in ur head!
    sK
    sK is offline
    Site Banned Follow
    sK's Avatar
    Jan 2005
    22
    40
    O/D should be "ON" most of the time for better mileage as it engage all the four gears, whether its City or HighWay driving.
    Sep 2005
    2,269
    2 Post(s)
    o/d should be done only when you need extra pick not in normal drive and will result in low fuel average!
