Results 1 to 5 of 5
Thread: Vitz Issues
    faisal2193's Avatar
    Dec 2006
    38
    118
    Default Vitz Issues
    Dear vitz owners.. I have recently owned a vitz 2000 A/T in cherry red. I have some queries hope u all would share ur experience and a good advice.
    1. The car drops a little mobiloil drop at ground when it is parked. I checked with a local mechanic he said that its chamber seal is might broken. so any experience about it.
    2. The driver door gets open while it is locked. i mean when the car automatically locks the four doors. and if we pull the inside door opener hook it moves the door lock pin upwards and the door opens. I want to ask iz it a builtin feature of any malfunctioning.
    3. Some time when car switches from petrol to CNG, engine gets shutdown. then again i had to start and accelerate to enable it to switch on CNG.
    Oblige for Replies.
    fyq
    fyq is offline
    fyq's Avatar
    Jan 2008
    31
    2,324
    13 Post(s)
    for cng issue, ur car need a tune up. u can ask at
    https://www.pakwheels.com/forumreply_az_TopicID!72942~ForumID!10~pw.html fir cnd related problems.
    let the music play
    ronz2202's Avatar
    Jun 2007
    33
    451
    8 Post(s)
    Dont know about the rest....but the door opening one is a built in feature of toyota vitz, the driver never gets the door locked from inside, however if you try to open from the outside it wont!
    I really like this feature
    - Drive it like you stole it!
    sd
    sd is offline
    sd's Avatar
    Sep 2005
    25
    1,400
    3 Post(s)
    door opens inside. yaa chamber seals may be broken, cng dont know. i hate cng, i use petrol in my vitz. MASHALLAH ab taak meri vitz mai koi prob nai ayii. i bought it in 2003 in japan yokahama 0 meter, and imported here in khi in 2006.
    Why drink and drive when you can smoke and fly?
    >>>>D£Ŧƛᵯƛ§Ø ƁØ¥§<<<<
    mafzaltareen's Avatar
    Sep 2005
    2,269
    2 Post(s)
    1.check engine chamber seals
    2.its built-in feature
    3.its also normal try to keep the car at 2000 rpm while converting to gas
    http://www.facebook.com/V8Rx8
