Results 1 to 3 of 3
Thread: Vitz Lovers plz give ur opinion
    faisal2193's Avatar
    Dec 2006
    38
    118
    Default Vitz Lovers plz give ur opinion
    Dear Members, two days back i washed my vitz engine. after that i started car at night, check light appeared and reamained on. while this car never showed check light before. so plz guide what to do or what can be the reason. However I washed engine with quiete care, mean i did safety for electronic parts/devices. Plz reply.
    Newbie Follow
    ifte's Avatar
    Aug 2008
    63
    It could be some electrical problem. May be water got into any electrical part or spoiled some sensor. When you turn ignition key to on postion, check light is always shown, after start, if everything is ok then it disappears. In your case everthing is not ok. After washing the engine always use the blower to dry water before starting. You could show it to an auto electrician.
    "Son of Adam! You Are nothing but a Number of days, whenever each day passes then part of you has gone." (Al Hassan Al Basry RA)
    Rawfay's Avatar
    Sep 2007
    26
    1,034
    try this..
    Remove the negative terminal on the battery..leave it for 2-3 mins attach it again and it'll go away. then drive it for 5-10 minutes, normally it shouldn't come up again. It works for me on CNG. If your car is on petrol then their shouldn't be any problem.
    Good Luck!
    1. Live and LET Live !
