Results 1 to 12 of 12
Thread: ------------Vitz o2 Sensor help require-----------
    susman_mukhtar's Avatar
    Jul 2006
    Al-Khobar , Lahore
    23
    1,264
    Default ------------Vitz o2 Sensor help require-----------
    hey guyz
    yesterday i went to heaven cng at jail rod to tune the cng kit
    bcoz the pick at cng was almost dead(considering didnt serviced the cng for 2 years)
    the guyz changed the lambda changed the motors changed the kit changed the wires but no luckk...
    at last he said that it is the oxygen sensor........he said to replace it
    Shop No 1
    AFZAL AUTO ELECTRICIAN (samnabad)
    diagnostics
    sir i dont to vitz take her to butt cng at at chuburji
    shop no 2
    diagnostics
    sir take it to super auto marker(behind suraya azeem hospital)
    i cant do any help its the sensor problen
    shop no 3
    iqbal auto electrician
    diagnostics
    sir go to bilal gunj and change the part
    he said if the o2 sensor was faulty the car wouldnt have any pick on PETROL TOO
    but on petrol car is running fine
    BILAL GUNJ
    TITO KI DUKAN
    diagnostics
    o2 sensor 1500
    air flow sensor behind airfilter 1000
    he said if the o2 sensor is not faulty as cars pick on petrol is fine but on cng its not....
    problem
    car pick on petrol fine
    on CNG not fine almost dead if at signal and car on cng
    would have to turn ac off and then there would be some pick...
    SO WHAT DO U GUYZ SAY IS THE o 2 sensor faulty or what???
    should i get it changed
    the main question as the cng guy said change the o2 sensor and then get it tuned by me
    my question
    if the o2 sensor is faulty and not giving the correct o2
    why the car is fine on petrol????
    THANKS in advance
    looking forward from replies from many vitz and cng experts like
    STORM sir,Logas sir,racer f1 sir gttir ,and many more expert people whose name i have for gotten
    Everyone thinks of changing the world/country.No one thinks of changing themselves.
    If someone says that they have never made a mistake in their life, this shows that they haven't tried anything new-Albert......Chevy for life!!
    Still not liking the Forum page as well as the Front page.
    aantherax's Avatar
    May 2006
    33
    3,032
    4 Post(s)
    Check if your CNG Regulator and CNG Cylinder has some oil in it. Secondly check :
    Air filter
    Plugs
    Plug wires
    Throttle Body
    B/c having all these part even in 45 % condition would be good enought for petrol. I am 100% sure there is no sensor issue with your ride. If you were in khi i would have taken you to my machenic
    ~ Be a responsible citizen and always drive safely ~
    Rawfay's Avatar
    Sep 2007
    26
    1,034
    I don't know whts the problem in your case. The low pick in the beginning is quite common, for that you need to frequently tune it on perfect settings thts it.
    Maybe you should try the following.
    1. Get the throttle body serviced.
    2. Change the plugs
    3. Get your CNG kit fully serviced and also the cylinder if possible.
    4. Oil change along with all the filters
    1. Live and LET Live !
    Jul 2006
    Al-Khobar , Lahore
    23
    1,264
    so u guyz think that theres is no sensor problem??
    Retaliator's Avatar
    Apr 2006
    Rawalpindi
    8
    1,445
    13 Post(s)
    heres what else u can do but i dont know which will solve ur problem:
    the O2 sensor is okay i thnk. u need an O2 sensor emulator. i dont know from where u can get it...
    take ur car to any electrician u trust or toyota ppl and tell them to bypass O2 sensor.... see what happens...
    take catalytic convertor out if its not taken out already...
    plz tell the brand names of the components u r using... maybe u r not using the right ones.
    Retaliator's Avatar
    Apr 2006
    Rawalpindi
    8
    1,445
    13 Post(s)
    does the engine check light comes on?? if no then no prob wid sensor..i think ur lambda system is creating problems
    aantherax's Avatar
    May 2006
    33
    3,032
    4 Post(s)
    @susman_mukhtar
    Kuch exp. ki basis par keh raha hon apna Cng cylinder aur Kit dono khulwa kar service karwao oil hoga us main lazmi.
    Plugs check karlo agar zarorat hai to replace karoo.
    Air Filter to change hi kardoo
    Plug wires ko check karwana electrition say zarorat ho to badal daina aur gari ki throttle body khulwa kar usko carb cleaner say dhulwa kar fit karwa doo aur phir CNG setting kara loo sab set hogayega
    smrn's Avatar
    Jan 2007
    36
    209
    susman
    Was the problem since the start of CNG installation?
    Is your car back firing, does the air filter get holes in it like it has melted ?
    blueanwar's Avatar
    Apr 2005
    42
    224
    Hmm! since the car is fine on petrol it suggests that all the sensors r working fine or with in their specified range.
    Because the problem lies in the acceleration while the
    stock ignition map is in use, it looks like the mixture is wrong. Rich/lean both would bog the car's acceleration down.........The reasons of wrong misture:
    1. wrong inputs of sensors
    2. Wrong setting of the power T
    1. wrong inputs means faulty sensor but if that would had ben the case then the car should not be working fine on petrol also. but the advancer's issue should not be ignored in this matter.
    2. The T can only be adjusted through the software of the kit provider.
    Make sure that the unit is not getting an extra rich signal from the o2 while the car is in lean condition actually.
    bobbylink's Avatar
    May 2007
    37
    85
    2 Post(s)
    there is no need to change o2 sen just tell us about your cng system which brand is instalde in ur ride or try to tune it with oregnal softwaer cause some lambda systems softwers can show fult code in dignostic culam or check that staper motor near air intacke may not working properly for check try to replsce with new one some time its not working completely so not proper cng pass throw it to engine intake.
    BoRn 2 r!de (Dr!Ve $@Fe|Y ;-)
    xain91's Avatar
    Aug 2008
    26
    763
    yes yes igot ur prob
    the same thing happened with my platz a/t
    wat u need is to go to the shop at beginning of choburji mrkt as u hav been rold, he would take only 200 or 300 and service ur o2 sensor. then u may notice a great increase pick and smoother switchin to cng after startin
    im 100% sure it will fix ur prob fully.
    or e mail me i will tell u in detail
    I used to want to change the world. Now I just want to leave the room with a little dignity.
  12. #12
    ngen's Avatar
    Oct 2008
    38
    166
    Your O2 sensor is fine if there are no issues on petrol. O2 sensor controls the air/fuel mixture therefore works with injectors ... when using cng the car does not use the injectors. so O2 is fine.
    As mentioned by others above.
    Get oil removed from your cng tank and kit.
    look for air leaks in the cng piping. Air leaks means there is more air and less gas going in the engine which will not make it run as well as it should.
    check your spark plugs, air filter.
    you should see improvement.
    good luck.
