Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Cold Vitz..!!
    xohaib's Avatar
    Jan 2006
    122
    2 Post(s)
    Default Cold Vitz..!!
    hey guyz,
    i have a vitz 2001 automatic & its facing a problem.. in cold whether like of these dayz when i start my car on PETROL usally in morning, engine dont run properly, it produces a sound like phak,, phak,, phak like dat of a 2-STROKE engine and even if i accelerate it in Neutral the engine only produces sonds but no proper resoponse on its RPM and if i switch the gear to D or R engine turns off.. On CNG it all do the same & my car also shakes...
    To solve this problem i have already,
    changed its fuel filter,
    removed the CAT converter,
    changed all Oils & air filter,
    tunned engine several times on both CNG % PETROL,
    and other side works,,,, but of no use...
    Daily i have to leave the engine running for 7-8 minutes,, until its blue light of cold engine goes off... AFTER that engine runs fine, no sound & perfect accleration...
    Again if i start it after 2-3 hours from engine OFF it do all again...
    Dont know whats the matter with it so i need suggestions from some experts...
    Looking forward Storm to help me out...
    Thanx in advance...
    jz
    jz is offline
    jz's Avatar
    Dec 2004
    26,106
    5
    185 Post(s)
    12 Thread(s)
    about the phuk phuk thats cng getting mixed with petrol,try not to press the throttle alot while starting n its always wise to let the car's engine warm up n then go for a spin
    www.facebook.com/performancepartslahore
    hash4u's Avatar
    May 2005
    38
    24,378
    18
    406 Post(s)
    13 Thread(s)
    13
    a colleague of mine had the same problem and he took it to the 3s dealership. it was tapit adjustment but his cars tapits were jammed....he had to leave his car for a day or two
    imtishal's Avatar
    Sep 2006
    42
    3,881
    11 Post(s)
    which engine oil are you using? In winters,oils with less vicosity work better.
    Qaiser Pal,I have not failed.But found 1 of 10,000 ways which doesn't work.....Toyota driver "I couldn't repair my brakes,so i made my horn louder"..When i was born i was so surprised that i didn't talked to one and half year..since light travel faster then sound,people appear bright until you hear them speak..If u can't convince them,confuse them
    K2Vitz's Avatar
    Sep 2008
    33
    88
    Cold engine light should disappear after about 2 minutes from start in Vitz. May be u are using high viscosity oil; also check the tapits as suggested above. Good luck
    “Do or do not ? ? ? ? there is no try . . . no success”
    ap2aum's Avatar
    Jun 2007
    46
    68
    check your thermostat valve. it could be stuck...or not there at all.
    Rawfay's Avatar
    Sep 2007
    26
    1,034
    same problem with me. I usually give one self and leave it then on the 2nd one it starts perfectly
    1. Live and LET Live !
    awais_tallal's Avatar
    Sep 2007
    33
    14
    i had vitz 2000 having the same sorta problem but it was not weather realted.. after a couple of months it use to suffer from same kinda problem you mentioned, i had done everything to get over with it but in vain, then a CNG mechanic told me just unplug the battery wires for 2 minutes and put it back and check out, it gets cleared the memory it has and after that... it went all ok try it..
    ronz2202's Avatar
    Jun 2007
    33
    451
    8 Post(s)
    dont know about cng related probs but you should try to keep the engine stalled for atleast 5 mins when you start the car in the morning
    - Drive it like you stole it!
    hash4u's Avatar
    May 2005
    38
    24,378
    18
    406 Post(s)
    13 Thread(s)
    13
    wrong. modern cars/oils dont need extensive warm up. i use synthetic oil and crank the car and start driving even if it is 0 degrees
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    i know it'll sound silly but have you tried getting the air flow sensor cleaned/checked. it's p;ossible that it is not sending a correct reading to the ECU which is causing the fuel mixture to be off which is leading to this issue.
    alternatively the thermostat valve should be checked (like ap2aum said), plugs cleaned & correctly gapped, fuel & air filters changed, fuel pump replaced and car reset (as awais_tallal said).
    let us know what happens.
  12. #12
    Skyline_Drift_Master's Avatar
    Oct 2004
    Select City
    29
    9,104
    Don't know about VITZ but in petrol V6 Audi's, BMWs Straight 6 (petrol) and Mercs 6 cylinder (all petrol) do that sometimes also because when you switch on the engine in cold and switch it off in cold, the engine sprays some kind of coolent onto injectors, due to the fact engine it cold already, that coolent won't dry off and result is that next time you try to start the car, it won't start. Even if it does start, it will shake for 3-4 mins. Try changing injectors or something. Don't know if it's the same problem with VITZ but have had that problem with our family BMW sometimes. Have to take the plugs out and clean then off for a clear spark, put back in and then the car starts fine but does shake for a bit...
    That's my side of the story...
    Thy name is Sumair Thy love Skyline Thy is very interested in DRIFTING Thy has PHD in drifting from the university of Street Racing!!
  13. #13
    xohaib's Avatar
    Jan 2006
    122
    2 Post(s)
    thnx all of u 4 ur interest....
    i usally use Shell Oil that in Blue Bottle
    and some times Caltex Havoline Formula Plus...
    @ hash4u:
    how much it cost 4 tapit adjustment?? and waz this problem solved after it???
    @ awais_tallal :
    i cant understand ur solution?? when to unplug the battery wires?? everytime i start the car??
    @ Storm:
    any good mechanic u know in lahore who can check my air flow sensor ???
  14. #14
    xohaib's Avatar
    Jan 2006
    122
    2 Post(s)
    @ Skyline_Drift_Master:
    i dnt know much about changing the injectors but have recently changed plugs with Bosch 4-Tip..
  15. #15
    aantherax's Avatar
    May 2006
    33
    3,032
    4 Post(s)
    Efi engines does'nt need 3 - 4 minutes of warm up time they just need 10 seconds (read in an owner's manuall of toyotta) you sould take your ride to your nearest Toyota 3S they are gonna sort it out.
    ~ Be a responsible citizen and always drive safely ~
  16. #16
    uzairdogar's Avatar
    Sep 2006
    27
    343
    hey bro i had that problem once in my civic, i took of the negative terminal of the battery for like 2 mins, to reset all the sensors, after that i had no problem, check engine light wasnt even on, but i tried it and it worked perfectly, u can try it has no harm, worked for me might just wrk for u, and do tell me plz if it worked,
  17. #17
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    sorry, not aware of any good mechs in lahore.
  18. #18
    xohaib's Avatar
    Jan 2006
    122
    2 Post(s)
    i am thinkin of gettin my Air Flow sensors checked... after that i will inform has the problem solved or not...!
  19. #19
    K2Vitz's Avatar
    Sep 2008
    33
    88
    Whenever you do any modifications in your car; it is important to disconnect the negative (-) terminal of battery to reset the ECU of the car. As you installed CNG, you must reset the ECU by removing negative terminal for about 3 minutes. Try this before doing anything else. Your problem could be solved like this. 8-|
  20. #20
    Rawfay's Avatar
    Sep 2007
    26
    1,034
    any updates?
