Page 2 of 2 FirstFirst 12
Results 21 to 21 of 21
Thread: Cold Vitz..!!
    xohaib's Avatar
    Jan 2006
    122
    2 Post(s)
    Default Cold Vitz..!!
    hey guyz,
    i have a vitz 2001 automatic & its facing a problem.. in cold whether like of these dayz when i start my car on PETROL usally in morning, engine dont run properly, it produces a sound like phak,, phak,, phak like dat of a 2-STROKE engine and even if i accelerate it in Neutral the engine only produces sonds but no proper resoponse on its RPM and if i switch the gear to D or R engine turns off.. On CNG it all do the same & my car also shakes...
    To solve this problem i have already,
    changed its fuel filter,
    removed the CAT converter,
    changed all Oils & air filter,
    tunned engine several times on both CNG % PETROL,
    and other side works,,,, but of no use...
    Daily i have to leave the engine running for 7-8 minutes,, until its blue light of cold engine goes off... AFTER that engine runs fine, no sound & perfect accleration...
    Again if i start it after 2-3 hours from engine OFF it do all again...
    Dont know whats the matter with it so i need suggestions from some experts...
    Looking forward Storm to help me out...
    Thanx in advance...
  2. #21
    devilzmafia's Avatar
    Jan 2008
    Canberra
    1,397
    its normal ...
