Results 1 to 7 of 7
Thread: Which engine oil & filter for Vitz
    antiflag's Avatar
    Apr 2006
    34
    253
    Default Which engine oil & filter for Vitz
    Guys, please let us know the different kinds of oils and their uses, e/g : Synthetic, semi-Syn, regular, magnetic, etc etc and please suggest which oil & filter to use for Vitz ( with prices ) thanks alot.
    Why is not called "Terrorism" When USA or Israel Does it " AntiFlag
    ati41's Avatar
    Oct 2007
    45
    234
    Synthetic Oil is best but it is also a lot more expensive. Synthetic oil is helpful ONLY if you do a lot of hard driving such as pushing ur car hard to the redline on regular basis.
    In my opinion you would be perfectly fine with regular mineral oils. You would be fine if you go for an engine oil with API Rating of SL ( SM is best). Do not go for APIL rating of API SG (more information on API ratings can be obtained from www.upmpg.com/motor_oil_rate_gas.htm).
    As for viscosity ( such as 10w-40, 20w-50) STICK to the manufacturer reccomendations mentioned in the owners manual.
    antiflag's Avatar
    Apr 2006
    34
    253
    @ ati41
    Thanks, for the info. Could you please help me understand, the manual says 5w30 is only recommended for very low tempratures, and since its usually 10-15Degrees in khi, i would be better off with a rating of 10W, but how far does the 30 go? i mean should i go for 10W30 or 10W40, cos it gets hot here in feb/march? magnetic,synthetic? which one or which company?
    K2Vitz's Avatar
    Sep 2008
    33
    88
    Open the following site. You will get all information about engine oils.
    http://www.carbibles.com/engineoil_bible.html
    According to our conditions at this time use 5W40. Use either Zic XQ or Mobil 1 (expensive but the best). Will increase FE a bit to compensate the expense. Use only genuine Toyota filter; do not compromise for cheaper craps.
    :d
    “Do or do not ? ? ? ? there is no try . . . no success”
    xtreme1racer's Avatar
    Dec 2006
    32
    1,007
    Magnetic is not a Oil Type !!
    Other than that
    Use the above link and this:
    Mineral Oil (Normal)=4 - 5000 Km (max mileage per change)
    Semi Synthetic Oil (Normal)=7 - 8000 Km (max mileage per change)
    Synthetic Oil (Normal)=9 - 10000 Km (max mileage per change)
    I Came, I Saw, I Conquered!---------------------------------------------------------------------------------------------------------------------------Divide and Conquer!----------------------------------------------------------------------------------------------------------------------------------------PAKISTAN ZINDABAD!
    ** BOYCOTT ALL THE CRAPPY AND OVERPRICED CARS AND JOIN THE BOYCOTTING GANG, for a better and improved Pakistan!! **
    There is only Democracy - Demo and Crazy ... what do you want ??
    antiflag's Avatar
    Apr 2006
    34
    253
    Thanks Guys,
    @ xtreme1racer
    Kindly let me know which company's oil is available in the following catagories that you mentioned.
    e.g: Mineral ( Caltex,shell etc?) Price?
    Semi Synthetic=?
    Synthetic =?
    thankx again.. very informative site
    Cheers
    antiflag's Avatar
    Apr 2006
    34
    253
    Ok guys, one more thing:
    So magnetic is not a type, so is magnetic(Castrol,Havoline(deposit shield) just normal mineral oils, are they any good as compared to non magnetic? or is it just the marketing tactic?
    About Synthetic, since i think i have normal oil, i just have to put synthetic, or flush the oil first with my new synthetic oil, or use something else for flushing? pls guide
