Results 1 to 11 of 11
Thread: need answer of some question for vitzzzzz
    Afnan_009's Avatar
    Feb 2009
    Quetta
    27
    128
    Default need answer of some question for vitzzzzz
    following r questions?
    1)yar my vitz have problem in brakes i.e jab ma zoor say brake lagata hoon to grgrgrgrgrggrrgrgrgr awazz ati hay need solution?
    2)yar gari missing kar rahi hay mechanic ko check karaya hay he told that injectors and tanki ka filter ma kachra aaa gya hay wo saaaf karna paray ga
    3)whats this in engine
    need answer of some question for vitzzzzz -574240
    need answer of some question for vitzzzzz -574241
    murtaza_murti's Avatar
    Sep 2008
    23
    10,354
    53 Post(s)
    4 Thread(s)
    Which model is it?
    - '06 Toyota Belta 1.0L X - '68 VW Beetle 1300 DP - '89 Nissan B12 E16
    Naweed's Avatar
    Jul 2008
    50
    3,469
    12
    122 Post(s)
    3 Thread(s)
    GRRRRRRRRRR you are referring to should be ABS and it is designed to act so ....
    Reasons for missing could be many ... plugs, leads, injectors, filter, fuel pump, coil, engine condition, any of the related sensors, etc .. go to a qualified mechanic and get the job done but only when you get a satisfactory diagnosis. Hit and trial method may be expansive with no results.
    "You have not lived today until you have done something for someone who can never repay you."
    Afnan_009's Avatar
    Feb 2009
    Quetta
    27
    128
    yar it is 2001 model
    agar sensor waghara ka problem hota to engine check light to jalti
    yeh gari hay grrrrrrrrr awaz jab say aaaaa rahi hay jb ma nay pads change keay hain
    need answer of some question for vitzzzzz -914890
    UmarAzam's Avatar
    Mar 2007
    27
    520
    5 Post(s)
    It means its abs is working fine It should produce sound like this in normal conditions when pressed hard so no worries abt it
    Eat my dust
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    1. Grrr is the ABS
    2. replace fuel fitler in tank, clean plugs and replace injectors
    3. in the last pic th etwo top things are for the airconditioner & gas, can't recall what the last thing is for (the plug with wires)
    Afnan_009's Avatar
    Feb 2009
    Quetta
    27
    128
    what is the price of filter and injector kia is ko replace karna mushkil ya asan kam hai saf karne se kam nahi chale ga
    f_m
    f_m is offline
    f_m's Avatar
    Dec 2008
    36
    56
    dear dont be panic, change the oil filter it will not cost u much ,about RS400 /- It may help u out. I have recently changed it. Not sure about the injector
    Best of luck
    Afnan_009's Avatar
    Feb 2009
    Quetta
    27
    128
    nahi yar oil change kar k dekha hay problem still there
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    As u encircled the picture,i think it is a inlet air temperature sensor.
    Never loose hope in life,every step gives u something.
    chinyoti's Avatar
    Sep 2005
    27
    11,965
    5
    108 Post(s)
    5 Thread(s)
    @afnan, as sameer bhai already said, that ggrrr mean that the abs is okay, if it does not then there is a problem,
    the pic in ur asking wats this, has sumthing to do with the a.c condensor nd gas check aur that switch is the one which often leaks in Corollas. that is also related to the a.c
    Missing petrol EFI, umm maybe only Injectors need replacement, or only the fuel filter is choked, or mayb the fuel Pump (motor), get all these things checked, as ur mechanic said cleaning it mite help try that also. or also check wid sum reliable TOYOTA showroom as they are gud wid EFI cars, Road side mechanics dunt noe mch abt EFIs
    Get over the fact that Xli lacks power windows, Its an Xli because it lacks thoose features or else it would be a Gli or an Altis if had all the goodies.
