Results 1 to 10 of 10
Thread: Vitz radiateor problem.
    f_m
    f_m is offline
    f_m's Avatar
    Dec 2008
    36
    56
    Default Vitz radiateor problem.
    Dear All
    My vitz-99 radiator has a minor seapage from already repaired (By depoxy magic)area .
    Should i try it again by applying the magic or some one has a batter idea.
    The mechanic says that magic will not stand long due to heat and he suggested to change the radiator bottom portion.
    Please advise
    hash4u's Avatar
    May 2005
    38
    24,378
    18
    406 Post(s)
    13 Thread(s)
    13
    like i wrote yesterday to another pakwheeler
    go to a "radiator wala"........they dont bite
    will take 300 rupees and put aluminium "tanka" on it
    aantherax's Avatar
    May 2006
    33
    3,032
    4 Post(s)
    yaar replace the radiator put a new one
    ~ Be a responsible citizen and always drive safely ~
    suzukialtomehran's Avatar
    May 2005
    Sargodha
    26
    7,286
    16 Post(s)
    Well I think You Shoud Replace with new one becuz i have this problem 1 year back and ended up with a new radiator.
    Two of the best quotes of Punjabi : 1. Rull tan gae aan! Per Chass aa Gae ai!, 2. Gal Pya Dhol Ty Wajana Penda ay.
    Porsche_Maker's Avatar
    Oct 2006
    6,388
    Its Plastic or Aluminium Top/Bottom??
    Simply visit Radiator person they will change that part only will only take around 1200~1500 Rs. for replacement otherwise they will only charge 400~500 if not hard damage to water tanks and also will clean ur Radiator.
    Life is a chain of moment of enjoyment and Obedience to Allah, not only about survival
    aantherax's Avatar
    May 2006
    33
    3,032
    4 Post(s)
    what ever you do, you will need to replace it dont waste 1200 or 1500 by changing its top or bottom just put a new one i have had the same issue and ended up getting a new radiator for honda city and wasted 2000 Rs before getting a new one to replace its top then bottom and bla bla ...
    alizzz79's Avatar
    Aug 2006
    37
    2,722
    8 Post(s)
    install a new one otherwise u will have heating problem ...
    Do You Know The Meaning Of Speed Lanes ???
    Oct 2006
    6,388
    Installing a new generator will be around 30+k if from 3S or if u buy original then around 25+k, adn if u again come to so called Kabli (Used) then it same as Repairing old one or getting that so called kabli from Kabariya.
    I have no personal radiator shop and i know that those solutions doesntlast very long but atleast those are solutions available.
    f_m
    f_m is offline
    f_m's Avatar
    Dec 2008
    36
    56
    Thank u all,
    I have changed the bottom portion with a steelbody. It cost 1200.Now fine.
    Thanksagain
    Oct 2006
    6,388
    keep look on all pipe joints and Radiator for few days and check by talking car to uphill or keep idling for some time.
