Results 1 to 8 of 8
Thread: Toyota Vitz 2005
    farazz619's Avatar
    Mar 2009
    37
    Default Toyota Vitz 2005
    Guyz, I've purchased Vitz 2005 in December 2009 and yesterday, its main seal in engine was leaking. I went to Toyota Walton Motors and they said that this is problem in all Vitz 2005 that there main engine seal leaks ... Im so tensed !!! Please suggest me good mechanic in Lahore ...
    sukheraa's Avatar
    Feb 2004
    47
    617
    go to waris road there is kindof vitz making factory.
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    What is the 'main engine seal'? :s
    https://www.facebook.com/OsamaAbbasPhotography
    TypeR's Avatar
    May 2004
    28
    2,318
    3 Post(s)
    I have 2005 vitz and no such problem !
    farazz619's Avatar
    Mar 2009
    37
    Engine main seal is under the engine ... between two front wheels .. Ive heard that to replace that, one has to loose gear box and half engine phr yeh seal change hoti ha ... it takes complete day to change the seal ...
    chinyoti's Avatar
    Sep 2005
    27
    11,956
    5
    107 Post(s)
    5 Thread(s)
    is it the head ki seal??
    Get over the fact that Xli lacks power windows, Its an Xli because it lacks thoose features or else it would be a Gli or an Altis if had all the goodies.
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    If it needs half of the engine removed, it's more likely to be a head's gaskit?
    But i think he means that MOST of the stuff has to be removed in order to get there, so it could be the seal between the engine and the oil pan? :s
    farazz619: How do you know that, that 'main engine seal' is leaking? :s What made you think that or jump to that conclusion.. I'm not taunting or w/e, i'm asking, so we get to know what 'seal or 'w/e' you're talking about and tell you.
    i have a 2005 vitz, no such problem here as well.
    farazz619's Avatar
    Mar 2009
    37
    This is what mechanic told me but I will get second opinion and third, may be.
    Infact, oil is leaking from engine down below so I dont think its head gaskit, I think its the 2nd option which you discussed "Syncview" i.e. it might be the seal between engine and the oil pan.
    Do u recommend Toyota Auuthorised Dealers?? I purchased this car from Good Year Showroom at MM Alam Road.
