Results 1 to 9 of 9
Thread: Toyota Vitz 2003
    mudi85's Avatar
    Oct 2006
    31
    6
    Default Toyota Vitz 2003
    i need help cause my car is giving only 70km in one cylinder. how much does Vitz give man on CNG?? and where can i get the tuning done?
    mudi85's Avatar
    Oct 2006
    31
    6
    30 views and no one answered my question hummmm......:^)
    fahadmiester's Avatar
    May 2005
    Peshawar
    30
    1,474
    3 Thread(s)
    let me answer,
    1:get the cng out run it on petrol
    2:when u push the accelerator pedal be gentle
    3:tune your car
    4:again get the cng out run it on petrol
    no comments
    wahab590's Avatar
    Jun 2006
    30
    865
    cylinder ka size kia hai?
    zafarak's Avatar
    Sep 2007
    46
    14
    Cylinder size or how much gas you get in one complete fill?
    Your kit and emulator/advancer brand/specs?
    Provide complete info, only then someone would be able to advise you.
    mudi85's Avatar
    Oct 2006
    31
    6
    have 55 kg cylinder and and the advancer is ulyses plus of salustri
    antiflag's Avatar
    Apr 2006
    34
    253
    yours should give you around 100-120 km in the city.. any way.. try pulling the accelerator by one hand and adjust the PEAK SCREW (silver color screw on top, that connects the pipe from the cng to the air intake) with a screw driver, keep closing it till the your car starts to stumble/resist. and open as much so you can fully rev the engine up.
    Block your intake with a tape, almost 50%
    Start your car and leave the engine running, if the engine is not smooth and there's alot of vibration, adjust the IDLE SCREW (Golden color, FAT Screw on the side of the CNG KIT) try to close it/open it turn by turn until your car becomes smooth.
    Patience and true understanding of the engine is required in order to achieve the maximum output and minimum mileage.
    Why is not called "Terrorism" When USA or Israel Does it " AntiFlag
    mudi85's Avatar
    Oct 2006
    31
    6
    @antiflag which place do u recommend to go for cng setting??
    rozzzzz's Avatar
    Oct 2005
    21,925
    12
    140 Post(s)
    5 Thread(s)
    very low milage
    MOTOR MANIACS ... An automotive service and repair workshop
    https://www.facebook.com/pages/Motor-Maniacs/721830141231922
