Results 1 to 12 of 12
Like Tree2Likes
  • 1 Post By Sarkaar
  • 1 Post By saboor73
Thread: Hi-Octain in Wagon R
    m_kaisar's Avatar
    May 2006
    Faisalabad
    39
    833
    5 Post(s)
    Default Hi-Octain in Wagon R
    I want to ask is it okay to use Hi Octain fuel in wagon r after intervals to get the fuel lines cleaned as there's a myth that hi octain is good to get the enjectors & fuel lines cleaned.
    Kindly advise some expert on its usage in new wagon r or slightly used as 8k to 9k kma driven.
    The revolution is not an apple that falls when it is ripe. You have to make it fall.
    (Che Guevara)
    mehran's Avatar
    Dec 2010
    Rawalpindi
    45
    1,374
    As far as I know, there is no harm in using Hi Octane once in a while. It should give slightly better mileage and no knocking in the engine. Try it.
    Sarkaar's Avatar
    Mar 2006
    30
    2,003
    38 Post(s)
    No need for Hi-Octane for k10b, it does not have high compression ratio, i used regular petrol and felt knocking only once and it was due to weather changes, my WR has 20k kms on odo
    Corolla Altis 1.6 2016-to date
    Wagon R VXL 2014-2016
    MBilalBhatti's Avatar
    Nov 2011
    157
    2 Post(s)
    Quote Originally Posted by Sarkaar View Post
    I think K10b's compression ratio is 10:1 which is not that low. However if engine is not knocking on regular petrol then there is no point of adding Hi-Octane as it will result in clogging EGR valve with carbon unless not mixed in appropriate proportion with super.
    This is your life and it's ending one minute at a time!
    saboor73's Avatar
    Oct 2013
    10,550
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by MBilalBhatti View Post
    Wagonr doesn't have egr valve
    Nov 2011
    157
    2 Post(s)
    Quote Originally Posted by saboor73 View Post
    I think one with bosch ECM have EGR valve and denso don't. Not sure what ECM is in Wagon R K10B
    saboor73's Avatar
    Oct 2013
    10,550
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    ECM Is other name of ECU
    ECU= electronic control unit
    ECM = electronic control module
    mbilalpk's Avatar
    Aug 2015
    7
    True. I was referring that I am not sure if K10B in Wangon R has an ECM\ECU manufactured by Denso or Bosch.
    saboor73's Avatar
    Oct 2013
    10,550
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    K10b is very cheap ly built engine it doesn't even have Iat sensor I doubt it would have egr valve
    fayyazasghar2008's Avatar
    Nov 2008
    43
    130
    My wagon R has continous knocking like sound, Muxh worried about that. dont know u are talking about the same sound. Also I have tried Hi-octane but sound remains. Veery much worried. Please tell me is it an engine problem. Car is perfectly fine otherwise.
    rozzzzz's Avatar
    Oct 2005
    21,925
    12
    140 Post(s)
    5 Thread(s)
    you can mix it or use the high octane if u have knocking issue
    secondly updated fuel in pakistan will be good to keep it running fine .....
    MOTOR MANIACS ... An automotive service and repair workshop
    https://www.facebook.com/pages/Motor-Maniacs/721830141231922
  12. #12
    ufi2007's Avatar
    Nov 2009
    536
    2 Post(s)
    Using high octane of Rs 400 with Rs 600 of super gives pick increase and better mileage. WagonR vxl 2016 15 k driven.
    Sent from my CAM-L21 using PW Forums mobile app
Tags for this Thread
