Page 3 of 3 FirstFirst 123
Results 41 to 45 of 45
Like Tree21Likes
Thread: Difference between VXR and VXL
    baqali's Avatar
    Aug 2013
    29
    Default Difference between VXR and VXL
    Solution
    Can any one guide the difference between VXR and VXL on Wagon R.
  2. #41
    huraiz's Avatar
    May 2012
    Birmingham
    562
    Bahi there is one thing called key less entry and there is another thing keyless vehicle. Kyon preshan hote Ho Sab. Remote or smart fob all have a physical key present so you can open the doors manually.both my cars are keyless on both cars there is hidden actual steel key in fob and there is at least one covered key hole on door handle which you can use to open door in case of flat battery etc.Now the reason it's called key less car,you don't need to physically insert key anywhere,you only need fob with you and sensors will detect it and you can simply press the button to start the car.Tell you what it can be a real pain in backside if battery's are low,other than that it's best thing in world.
  3. #42
    kashifjaved86's Avatar
    Aug 2015
    Faisalabad
    30
    324
    7 Post(s)
    Quote Originally Posted by usman_arooq2 View Post
    :facepalm:
    keyless entry ki types hain, remote keyless entry, smart entry, pincode entry jasy cars ki types hain, hatchback, sedan, suv. aap ki behas wasy ha jasy koi kahy suzuki pothar car ne ha, jeep ha(aisi mentality waly logon ko SUV term ka b pata ne hota).
    jo list aap ny post ki us ma majority brands k is system k name ma word "smart" use karty hain.
    metal ki na hony wali baat b galt ha, agar battery low ho ya system malfunction kary tw kya window glass break kar k gari ma enter ho gy?
    Difference between VXR and VXL -1666977
    aap ki aasani k leay post kiya ha, how it works k first paragraph ki last lines parho, mechanical key is present as backup likha jahan.
    aap parhty zaroor ho lekin jasa k ma ny bar bar kaha k complete ne parhty, na apni research ka leay, na hi jisy reply karna ho us post ko is leay bar bar sharmindagi ka saamna karna parta.
    adhura ilm tabahi hota ha, misal suni ho gi, neem hakeem khatra e jaan.
    wasy ya baat post k start ma likhni chaheay thi kyun k aap ny tw adhi post hi parhni.
    Quote Originally Posted by junox View Post
    Tm mjhy lgta hy intehai vehlay or Nikammy ho har forum py tum fazool ki behas or larai kr rhy hoty ho,,, kuj kr lo zindagi choti c hy
    its enough for you ................
  4. #43
    SALMANWASEEM's Avatar
    Aug 2009
    987
    5 Post(s)
    this is a useless debate,in vxr u need to install the security system and in vxl there is a factory fitted security system with buttons on the key case and it is much better than the aftermarket steelmate security systems,in short VXl has keyless entry
    There is a sufficiency in the world for man's need but not for man's greed
  5. #44
    Newbie Follow
    usman_ashraf11's Avatar
    Jun 2016
    Default RE:
    Quote Originally Posted by Sarkaar View Post
    VXL has security alarm and keyless entry. if door is open by any other mean except through key or button then horn will start buzzing after 3 secs. So there is no need to install after market security alarm in VXL.
    how i can test that security alram is working or not
  6. #45
    arsalannn's Avatar
    Aug 2006
    28
    380
    4 Post(s)
    Quote Originally Posted by usman_ashraf11 View Post
    without pressing the unlock button on the key, open the door and wait a few moments. horn will start honking untill you either unlock with the button on key or insert the key in the ignition.
    Sent from my SAMSUNG-SM-G850A using PW Forums mobile app
    yes!!!
