Here's a video of a mad supercar that in the early '90s, was the fastest production car.
//youtu.be/http://www.youtube.com/watch?v=uA2_CnD5K9M
The version shown in the video is the Supersport, that upgrades power to 650+ BHP and drops weight by around 150 kgs. Just as a matter of reference, if the Veyron had the same power to displacement ratio, it would be touching 1500 BHP.
Bugatti EB110 meets Edonis | Car Review Group Test | evo
Bugatti EB110 SS - Supercars.net
In 1992 Bugatti anounced a new version of the EB110 called the Supersport. It was lighter and more powerful than the standard model which helped it reach 216 mph.
In 1992 Michael Schumacher purchased a yellow EB 110 Super Sport and it became one of the most famous cars.
An EB110 SS was raced at the at the 1996 24 Hours of Daytona.
<table class="cardetails" border="0" cellpadding="0" cellspacing="0"><tbody><tr><td class="label" align="left" valign="bottom" width="30%">
type</td> <td class="value" align="right" valign="bottom" width="70%">
Production Car</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
production years</td> <td class="value" align="right" valign="bottom" width="70%">
1992 - 1995</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
built at</td> <td class="value" align="right" valign="bottom" width="70%">
Camogalliano, Italy</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
body stylist</td> <td class="value" align="right" valign="bottom" width="70%">
Marcello Gandini</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
coachbuilder</td> <td class="value" align="right" valign="bottom" width="70%">
Aerospatiale France</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
production</td> <td class="value" align="right" valign="bottom" width="70%">
31</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
price $</td> <td class="value" align="right" valign="bottom" width="70%">
$ 380 000</td> </tr> <tr> <td class="boldlabel" align="left" valign="bottom" width="30%">
engine</td> <td class="boldvalue" align="right" valign="bottom" width="70%">
60 Degree V12</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
position</td> <td class="value" align="right" valign="bottom" width="70%">
Mid Longitudinal</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
aspiration</td> <td class="value" align="right" valign="bottom" width="70%">
4 IHI Turbos</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
valvetrain</td> <td class="value" align="right" valign="bottom" width="70%">
DOHC 5 Valves / Cyl</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
fuel feed</td> <td class="value" align="right" valign="bottom" width="70%">
Bugatti Multipoint Electronic Enjection</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
displacement</td> <td class="value" align="right" valign="bottom" width="70%">
3498 cc / 213.5 in³</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
bore</td> <td class="value" align="right" valign="bottom" width="70%">
81.0 mm / 3.19 in</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
stroke</td> <td class="value" align="right" valign="bottom" width="70%">
56.6 mm / 2.23 in</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
compression</td> <td class="value" align="right" valign="bottom" width="70%">
7.5:1</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
power</td> <td class="value" align="right" valign="bottom" width="70%">
484.7 kw / 650.0 bhp @ 8000 rpm</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
specific output</td> <td class="value" align="right" valign="bottom" width="70%">
185.82 bhp per litre</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
bhp/weight</td> <td class="value" align="right" valign="bottom" width="70%">
458.39 bhp per tonne</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
torque</td> <td class="value" align="right" valign="bottom" width="70%">
646.73 nm / 477 ft lbs @ 4200 rpm</td> </tr> <tr> <td class="boldlabel" align="left" valign="bottom" width="30%">
body / frame</td> <td class="boldvalue" align="right" valign="bottom" width="70%">
Aluminium Body over Carbon Fibre Tub Chassis w/Integrated Roll Cage</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
driven wheels</td> <td class="value" align="right" valign="bottom" width="70%">
4WD</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
wheel type</td> <td class="value" align="right" valign="bottom" width="70%">
BBS 7-Spoke, Center Lock Alloys</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
front tires</td> <td class="value" align="right" valign="bottom" width="70%">
245/40ZR-18 Michelin Pilot SX</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
rear tires</td> <td class="value" align="right" valign="bottom" width="70%">
325/30ZR-18 Michelin Pilot SX</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
front brakes</td> <td class="value" align="right" valign="bottom" width="70%">
Drilled & Vented Discs w/Servo Assist, ABS, Brembro Calipers</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
rear brakes</td> <td class="value" align="right" valign="bottom" width="70%">
steering</td> <td class="value" align="right" valign="bottom" width="70%">
Rack & Pinion</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
f suspension</td> <td class="value" align="right" valign="bottom" width="70%">
Double Wishbones w/Pull-Road Actuated Spring/Damper Units</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
r suspension</td> <td class="value" align="right" valign="bottom" width="70%">
Double Wishbones w/Double Coil Springs, Damper Units</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
1418 kg / 3126 lbs</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
wheelbase</td> <td class="value" align="right" valign="bottom" width="70%">
2550 mm / 100.4 in</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
front track</td> <td class="value" align="right" valign="bottom" width="70%">
1550 mm / 61.0 in</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
rear track</td> <td class="value" align="right" valign="bottom" width="70%">
1618 mm / 63.7 in</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
length</td> <td class="value" align="right" valign="bottom" width="70%">
4400 mm / 173.2 in</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
width</td> <td class="value" align="right" valign="bottom" width="70%">
1940 mm / 76.4 in</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
height</td> <td class="value" align="right" valign="bottom" width="70%">
1125 mm / 44.3 in</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
transmission</td> <td class="value" align="right" valign="bottom" width="70%">
6-Speed Manual</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
final drive</td> <td class="value" align="right" valign="bottom" width="70%">
3.18:1</td> </tr> <tr> <td class="boldlabel" align="left" valign="bottom" width="30%">
top speed</td> <td class="boldvalue" align="right" valign="bottom" width="70%">
~349.2 kph / 217.0 mph</td> </tr> <tr> <td class="label" align="left" valign="bottom" width="30%">
0 - 60 mph</td> <td class="value" align="right" valign="bottom" width="70%">
~3.35 seconds</td></tr></tbody></table><table style="width: 1px; height: 4px;" id="tabelle" class="layout-tab" cellpadding="0" cellspacing="0"><tbody><tr><td>
</td><td class="spacer">
</td><td><table class="content-tab" cellpadding="0" cellspacing="0"><tbody><tr class="first"><td class="leftcol">
</td><td class="rightcol">
</td></tr><tr><td class="leftcol">
</td></tr></tbody></table></td></tr></tbody></table>
