Closed Thread
Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 58
Like Tree2Likes
Thread: Yamaha 100cc, going upto 125km/h
    saadleo's Avatar
    Nov 2008
    26
    851
    3 Post(s)
    Default Yamaha 100cc, going upto 125km/h
    My yamaha 100cc, 1989 model, after new engine is going upto 125 km/h,
    and with double persons its going upto 115,
    now the below pic is taken by my friend at 110, due to his wrong tyming
    i will try to upload the pic a 125 km/h,
    INSHALLAHYamaha 100cc going upto 125kmh -17806
    Yamaha 100cc going upto 125kmh -17807
    The best views are seen from inside motorcycle helmets.
  2. #21
    KamranAslam's Avatar
    Apr 2006
    Select City
    14,249
    7
    295 Post(s)
    11 Thread(s)
    9
    ^^^ Agree: its been a while since i started taking pictures regularly, but its been always a big dare for me to take a pic of a meter above 110 on a motorbike.
    I will say the poster is a next Golden
    I am only responsible for what I say, not for what you understand..
  3. #22
    PKB
    PKB is offline
    PKB's Avatar
    Sep 2009
    Vienna
    26
    199
    and drive safe means wear a helmet, jacket, gloves and shoes. Then u can even ride 300+ kmph if theres no speed limit on the way where u ride
    Fear is no Policy - Surrender is no Option
  4. #23
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    @saadleo replace the clutch plates of ur bike...........the result will be diffrent
    ***SPEED+ACCURACY+AGGRESSION=YAMAHA RX115***
  5. #24
    saadleo's Avatar
    Nov 2008
    26
    851
    3 Post(s)
    @RX115
    bro can u guide me in this matter?.. e.g where to get these?, which mechanic is good?, cost?
  6. #25
    saadleo's Avatar
    Nov 2008
    26
    851
    3 Post(s)
    @KamranAslam
    well yup it is daring to take pic over 110 on local bikes. since u neva knw wen the next vehicle may stop infront ov u, or piston jammes.... which happened with me, but THANKGOD i was not taking the pic at that tym n so i got it under control
  7. #26
    Apr 2006
    Select City
    14,249
    7
    295 Post(s)
    11 Thread(s)
    9
    piston jammes
    ^^^ Becarefull with this Yamaha 100 is pretty popular with piston jammes on high speed.
    My Elder brother is quite experiance with these piston jammes with some good number of scares
    Questions: Is the Lube box oil is working i.e. Oil pump is working or not ??
  8. #27
    massterr100's Avatar
    Mar 2006
    34
    661
    7 Post(s)
    Quote Originally Posted by KamranAslam View Post
    bhya kisi b 2 strok me auger ous k mutabik lubricant oil use nai kro ge to result piston jam hi mile ga. proper mikdar se aap bike ko 2hrs continuously maximum speed per chlao ge to b piston jam nai ho ga aur na hi bike over heat ho gi
    IGNITE YOUR LIFE WITH WHEELS.
  9. #28
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    @saad buy it from murree road. try to locate japanese or imported clutch plates. or try the fiber clutch plates these r also good. price range is 250/RS.
    where do u live in ISB.i have a good mechanic but its bit far away in down town(BHARA KAHO). I used to get fixed my my RX115 AND GTO125 from him.
    i am here to help u if required,i work in blue area near usmania hotel
  10. #29
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    @kamran@master r very right. there is proper lubricant mixture is required to get the desired performance.
    and if the mixture isnt proper the result will be same as bro kamran said.
    plz avoid to take pics at that speed its risky.
    my bikes easilly cross the meter of 160/kmph and also wanna snapshot of that exotic scene but...............cudnt get it coz i dont have proper helmat cam or other device to take it.....
  11. #30
    saadleo's Avatar
    Nov 2008
    26
    851
    3 Post(s)
    yup, now the lubricant box is working well, dobara sahi krwaya ha. pehlay ni kam krta tha thats y it jammed. ab theek krwaya hoa ha, easiliye tou pictures leta hn )).
  12. #31
    saadleo's Avatar
    Nov 2008
    26
    851
    3 Post(s)
    @RX115
    bro i study in UNIVERSITY OF LAHORE(ICAf), blue area.
  13. #32
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    @saad if u ever wanna try to take ride of mine RX115 than u r more then welcome.i work in AAJ NEWS. near usmania hotel,blue area
  14. #33
    saadleo's Avatar
    Nov 2008
    26
    851
    3 Post(s)
    bro that wuld really be a great pleasure for me. tell me when u will be available?. i have a gap between my classes from 12.30 to 2.00
  15. #34
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    @saad ok i,ll let u know when got free in ur given time.
  16. #35
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    Yes those pre 90 Yamis were great machines, current models suck.
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
  17. #36
    saadleo's Avatar
    Nov 2008
    26
    851
    3 Post(s)
    yup, yesterday night i beat a random 125 on 9th avenue. my bike was just lyk a heavily muscled horse, which just needs a signal to climb upto to the skies...
  18. #37
    saadleo's Avatar
    Nov 2008
    26
    851
    3 Post(s)
    RX 115
    bro can u find me those clutch plates?.. as i m not experienced in that. jb bhi ap jain us trf tou yeh kaam bhi krskte hain kia??
  19. #38
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    @saad did those random cg,s knew that yamaha gonna race.......lol
    sure i can do this for u in coming week
  20. #39
    saadleo's Avatar
    Nov 2008
    26
    851
    3 Post(s)
    Deleted!
  21. #40
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    @saad my point of view was lil dif........kuch log road per apni masti main magan ja rahay hotay hain or un ko pata bi nahi hota k koi un se race laga chuka hay......lol
Closed Thread
