Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 89
Thread: Yamaha YD 100 4 Stroke Info Required
    internal_auditor's Avatar
    Jan 2008
    Faisalabad
    29
    6,197
    Default Yamaha YD 100 4 Stroke Info Required
    Assalam-o-Alaikum!
    I want to buy new 2010 model Yamaha YD 100 4 stroke (not junoon) so i want to know about its maintenance costs, fuel economy and quality, durability. I currently have CD 70 so please compare this yamaha 4 stroke with cd 70 on above factors (maintenance costs, fuel economy and quality).
    Thanks in advance
    It is impossible to please everybody.
  2. #41
    khanthegr8's Avatar
    Oct 2009
    Okara
    31
    1,805
    5
    73 Post(s)
    Quote Originally Posted by internal_auditor View Post
    @khan jee 1st tuning kar wa lo
    Maybe I'd be wrong, but I believe tuning karwane se kuch khaas fark nahi padta bike ko, Lubrication hi karni hoti hai unho ne ya drive chain tight karni hoti hai, wo khud kar lay banda.....Four Stroke bike ko to i think just filter saaf karne ki zarurat hoti hai.....humne bike city me hi chalani hoti hai, just 10 km/day wo b shokiya, verna nahi, so id on't think so tuning is that much necessary
    Main tay Honda ee lay saa'n !!!
  3. #42
    Jan 2008
    Faisalabad
    29
    6,197
    Quote Originally Posted by khanthegr8 View Post
    Ok. As you wish
  4. #43
    Automotorsport_Lover's Avatar
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    When u buy a new bike its screws, nuts and bolts etc are not thight.. theyr all loose, overall every setting of ur bike is soft/loose like brakes, clutch, chain etc.
    At ur first tunning thry will tighten up these all things, ask them to thight every screw/ nut/ bolt of ur Handle assembly, screw up the HUB/ Axles etc. Bcoz by factory the screws etc arent thightened up enough its allways bttr to get them checkd.
    Also first tunning would increase ur bikes avg.
  5. #44
    Jan 2008
    Faisalabad
    29
    6,197
    Quote Originally Posted by Automotorsport_Lover View Post
    Yep right and also its free and when to change its filter ? Is it like CD 70 after 2000 kms ?
  6. #45
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    Changing Airfilter is totally depended on the area u live in, the more Dust, the more changes required. Air is sucked into the carburator through ur air filter and carb is v.expennsive and sensitive part of every ride.. so its better to change air filter every month if u live in Lahore considering the dust and pollutuion.
    And if u have some extra time and love 4 ur ride, cleaning the filter every week is too gud practise to have! The better ur ride breathes, the better milage it gives plus throttle response is better pus engine life is indirctly increased.
    (Bad combustion in the engine produces more carbon deposits on piston and cylinder-- a well tunned and clean air filter bike wud have less deposits inside the engine)
  7. #46
    Jan 2008
    Faisalabad
    29
    6,197
    ^ Thanks
  8. #47
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    NP bro.. Cheers
  9. #48
    khanthegr8's Avatar
    Oct 2009
    Okara
    31
    1,805
    5
    73 Post(s)
    Hmm....chalo tajurba kar ke dekhtay hain, I've had CG 125 2010 model, after the 1st tune up bike ka sound hi marr gaya sara, non qualified mechanics...Screws etc etc tight karte karte kabhi Plass mar diya mudguard per, kabhi silencer pe scratch daal diye kabhi kiya to kabhi kiya, laanat bhejo aesi tuning pe.......jis me apki sari bike hi scrathy kar di jaye.....
  10. #49
    Jan 2008
    Faisalabad
    29
    6,197
    The fuel avg is gone down. Now the latest calculated average is 40 kmpl. And 730 kph on the odo. Let's see after 1st tuning
  11. #50
    hamza64's Avatar
    Jan 2010
    Rawalpindi
    27
    36
    what is your average speed?is it inside the economy zone?
    A word to the wise ain't necessary - it's the stupid ones that need the advice.
  12. #51
    hamza64's Avatar
    Jan 2010
    Rawalpindi
    27
    36
    my bike has done 1400 km and the it is still giving 55km/l from the very first day
  13. #52
    khanthegr8's Avatar
    Oct 2009
    Okara
    31
    1,805
    5
    73 Post(s)
    Quote Originally Posted by hamza64 View Post
    I think kuch bikes ki setting or fitting hi zabardast hoti hai jis waja se unki performance pehle din se hi achi hoti hai, 2009 model which i bought brand new started giving me an average of 32KM/liter by default....And laterly 38KM/liter.....
    Maine tuning to nahi karayi thi bus petrol kam karwa liya tha uska phir 48KM/liter avergae milti thi.....
  14. #53
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    ^^ Well i was also of the view that bikes have some increased petrol setting in the begining but after experiencing my self and comparing with internal_auditor and hamza64's posts im not much sure now, my bike giving me 50km/Ltr + avg during running, 290Kms done so far... When the reserve kicks in ill let u know exactly that how much she did above 50Kms...
  15. #54
    khanthegr8's Avatar
    Oct 2009
    Okara
    31
    1,805
    5
    73 Post(s)
    Mere khyal se ye sab mechanic k experience pe depend karta hai ke wo apki bike ki settings kesi karta hai, aksar mechanic petroleum consumption kar dete hain jiski waja se bike bethna shuru ho jata hai, I think with this 100 CC bike 50km'liter is not a bad average.......CD 70 gives an average of 55 km/liter by default
  16. #55
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    And ill give u people a very interesting news v.soon..
  17. #56
    khanthegr8's Avatar
    Oct 2009
    Okara
    31
    1,805
    5
    73 Post(s)
    this news is regarding to Yamaha YD 100 4 Stroke or other automobile
  18. #57
    massterr100's Avatar
    Mar 2006
    34
    661
    7 Post(s)
    once i cheked fuel milage of my YD4 04model on highway unnder economy zone and it gave me 72km/L
    IGNITE YOUR LIFE WITH WHEELS.
  19. #58
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    @ All
    Finally today my bike's fuel ended and reserve started; during running process my Junoon gave me 58 Km/Ltr! No tunning no nothing, just factory settings and city drive.. usually driving at 45 Km/Hr all the time. Is nt it gr8 4 a 100cc bike?
    <!-- / message --><!-- sig -->
    After obtaining 58KM/ltr in city drive im pretty sure this bike can give such a milage at long routes! Gr8 milage!
  20. #59
    khanthegr8's Avatar
    Oct 2009
    Okara
    31
    1,805
    5
    73 Post(s)
    @ All
    Then you are the lucky one, but you got to confess this also, some bikes are been assembled in such a perfect manner that they give accurate performance in every aspect ...... enjoy the ride good luck
  21. #60
    Mar 2006
    34
    661
    7 Post(s)
    Automotorsport_Lover<SCRIPT type=text/javascript> vbmenu_register("postmenu_2241313", true); </SCRIPT>
    Bro aap k pass JUNOON hai ya YD4?
