Page 5 of 26 FirstFirst ... 3456715 ... LastLast
Results 81 to 100 of 508
Like Tree36Likes
Thread: Yamaha junoon different isses. Help required
    rizwan4340's Avatar
    Sep 2014
    26
    507
    6 Post(s)
    Default Yamaha junoon different isses. Help required
    Assalam o Alaikum everyone. I just joined pakwheels forum a few days back.
    I am Rizwan. 24 year of age.
    My current ride is Yamaha junoon 2009 model. 52000km plus mileage
    I have different issues now and need proper help. Juat because i don't want to waste my money and time as well.
    Now come towards topic.
    1. Tires. I want to replacw both tires. Front one the same service 2.50x18 but for rear tire. I want to replace it with 2.75x18 service long life cruiser style. I have original stock rims installed right now both rims are 2.50x18 supported. Now let me know if i need to repace the reae rim for new size 2.75x18 tire size?
    2. Head Lights. I am fed up with low lights. My current stock fitted body of head light isn't sufficient for night ride. I have changed the bulb to Taiwanese bulb but nothing changed. Guide me fe good light but with good loook.
    3. Rear shock abaorber. Shocks absorber. Mostly known as jumps are done now. I observerf oil leakage from bottom of jumps.
    4 engine is producing some horrible sounds. Need a best mechanic for bike in karachi
    It is Easy to hate But Love is More Powerful...
  2. #81
    rizwan4340's Avatar
    Sep 2014
    26
    507
    6 Post(s)
    Quote Originally Posted by JUNOON007 View Post
    Rizwan bro ap ki bike ki cindition zabardast hay lakin chain cover par rust hay jo bike ki beauty kharab kar raha hay
    Chain cover IN SHA ALLAH main change keru ga bas chakar lagy ameen autos ka. Baqi ALHAMDULILLAH sab sahe hey
  3. #82
    rizwan4340's Avatar
    Sep 2014
    26
    507
    6 Post(s)
    Should i use any silver spray paint or change the chaincover. I think change the cover will look more good. But spray paint is cheaper option.
  4. #83
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    rizwan I think I have found the reason that why you bike light has low focus on road the headlight your are using is the third quality part DYL was selling part in three quality did you changed the headlight or it was factory fitted on your bike
  5. #84
    rizwan4340's Avatar
    Sep 2014
    26
    507
    6 Post(s)
    Quote Originally Posted by saboor73 View Post
    Actually it is fine now. Main issue was some kind of bad wiring and current leakage from neutral. I took one external battery of 12 v and dismantled the front of head light and replaced the bulb with 35w 12v Malaysian brand . And then checked the result of almost 4 bulbs and 3 reflectors in dark room. Finally the bulb i mentioned above, gave me superb output so this is my current setup . Beside this i will install new dry battery and bigger charger for good result. I am just in touch with one electrician but couldn't find time to visit his shop.
  6. #85
    muhammedahmed2's Avatar
    Jul 2014
    Rawalpindi
    18
    406
    6 Post(s)
    INSHALLAH BAHI thanks for all your help going to take photos in a bit now just washed it and waiting for it to dry
  7. #86
    rizwan4340's Avatar
    Sep 2014
    26
    507
    6 Post(s)
    Quote Originally Posted by muhammedahmed2 View Post
    Apply some coconut oil on chrome parts. Just take a piece of cloth dip it in oil and gave ur bike's body a massage
  8. #87
    Jul 2014
    Rawalpindi
    18
    406
    6 Post(s)
    1 more thing i forgot to add....the backlight does not work when i press the backbreak...i asked mechanic to fix it he said that it is factory problem it is a fault in it even if you change the setup of it it will not light up...does you backlight work when you press the back brake
  9. #88
    rizwan4340's Avatar
    Sep 2014
    26
    507
    6 Post(s)
    This is the wire responsible for front break back light. Check it if it is properly connected inside. I replaced it once but it's not working now..
  10. #89
    Jul 2014
    Rawalpindi
    18
    406
    6 Post(s)
    yes this was a bit louse tightened it i was talking about the back brake bahi when i press the back brake then the brake light does not light up
  11. #90
    JUNOON007's Avatar
    Dec 2012
    Sargodha
    28
    1,074
    21 Post(s)
    Quote Originally Posted by rizwan4340 View Post
    Bro original chain cover is no more available wrap this chain cover in some paper which is available in the market
  12. #91
    rizwan4340's Avatar
    Sep 2014
    26
    507
    6 Post(s)
    Well i am in karachi. And i am sure u will find out its original chain cover if i wish to. There is a maun shop named amin autos in tibbat centre or adjacent. They have original accessories of yamaha.
  13. #92
    JUNOON007's Avatar
    Dec 2012
    Sargodha
    28
    1,074
    21 Post(s)
    If you have picture of that 35w bulb plx share it
  14. #93
    rizwan4340's Avatar
    Sep 2014
    26
    507
    6 Post(s)
    Back light depends on both brakes. Front and rear. For front break i showed you the wire. For rear brake just check the switch sityated near break paddle. It will be an adjustable black plastic screw and a spring connected with a wire and further attached with break paddle. Just adjust that switch if it is available in bike. If not then go to any electrician and ask him to install rear brake light switch.
  15. #94
    rizwan4340's Avatar
    Sep 2014
    26
    507
    6 Post(s)
    I don't have pic right now but it is just like the normal bulb. Like the original one.
  16. #95
    rizwan4340's Avatar
    Sep 2014
    26
    507
    6 Post(s)
    I think that top one is the 35w 12v Malaysian bulb then at left it is original 32w 12v and right side 25w 12v stanley.
  17. #96
    safdar.khan's Avatar
    Oct 2014
    Faisalabad
    Default yamaha junoon issues
    junoon bilkul sahai haalit main 2007 model 29-31 k main milna chayeee is ke yehee maket hay. motorcycle bohut achee hai sirf proper aur yamaha se qualified mechanic ki availability bahut kam hy.hamare haan honda is lye kamyaab hy kion ke is ka system simple hy.
    yamaha junoon ka sab se bara issue is ke electrical wiring hy,kion ke is ka system bettery charge karat hay aur current battery ke through CDI unit aur engine ko jata hai. Agar battery kharab to motor bike band ho jatee hay.Is ka current direct karne wali electrician bhi available hain,faisalabad main to available hain.
    Isee wajah se is ke market honda ke mukable main kam hay.Other spare parts ziada costly nahi hain,lakin availability special shopes per he hay.
    is ke current generation coils bhi oil ke ander hain (Wet Coils) aur 12 hain jab ke honda ke dry hain aur kam hain (approx 6) is lye agar coil kharab ho jain to mechanic special chaye hota hai.normally oil ke ander hone ke waja se kharab nahi hote.
  18. #97
    JUNOON007's Avatar
    Dec 2012
    Sargodha
    28
    1,074
    21 Post(s)
    Quote Originally Posted by safdar.khan View Post
    Safdar bro welcome on pakwheel
    Ap ko kis nay bataya hay k junoon ka current battary k through cdi ko jata hay.
    Maray pas 2010 model hay aur battery ko agar nikal bhi do to kuch nahin hota sirf horn aur indicator nahin cbaltay
    Main personally yah kam kar chuka hun
  19. #98
    rizwan4340's Avatar
    Sep 2014
    26
    507
    6 Post(s)
    Nice post safdar bhai
  20. #99
    rizwan4340's Avatar
    Sep 2014
    26
    507
    6 Post(s)
    Junoon bhai... battery wali pics ka muntazir hu.
  21. #100
    JUNOON007's Avatar
    Dec 2012
    Sargodha
    28
    1,074
    21 Post(s)
    Yar main to 25w walay say hi guzara chala raha hun 4 sal tak original bulb chala lakin phir holder melt ho gaya aur us nay bulb bhi nechay say melt kar dia is 35w walay ki price kia hay?
