Page 8 of 26 FirstFirst ... 67891018 ... LastLast
Results 141 to 160 of 508
Like Tree36Likes
Thread: Yamaha junoon different isses. Help required
    rizwan4340's Avatar
    Sep 2014
    26
    507
    6 Post(s)
    Default Yamaha junoon different isses. Help required
    Assalam o Alaikum everyone. I just joined pakwheels forum a few days back.
    I am Rizwan. 24 year of age.
    My current ride is Yamaha junoon 2009 model. 52000km plus mileage
    I have different issues now and need proper help. Juat because i don't want to waste my money and time as well.
    Now come towards topic.
    1. Tires. I want to replacw both tires. Front one the same service 2.50x18 but for rear tire. I want to replace it with 2.75x18 service long life cruiser style. I have original stock rims installed right now both rims are 2.50x18 supported. Now let me know if i need to repace the reae rim for new size 2.75x18 tire size?
    2. Head Lights. I am fed up with low lights. My current stock fitted body of head light isn't sufficient for night ride. I have changed the bulb to Taiwanese bulb but nothing changed. Guide me fe good light but with good loook.
    3. Rear shock abaorber. Shocks absorber. Mostly known as jumps are done now. I observerf oil leakage from bottom of jumps.
    4 engine is producing some horrible sounds. Need a best mechanic for bike in karachi
    It is Easy to hate But Love is More Powerful...
  2. #141
    muhammedahmed2's Avatar
    Jul 2014
    Rawalpindi
    18
    406
    6 Post(s)
    and after you got your clutch plates changed was there difference in kick pressure and overall pick of bike and after 800 plates how long did those last
  3. #142
    JUNOON007's Avatar
    Dec 2012
    Sargodha
    28
    1,074
    21 Post(s)
    Quote Originally Posted by muhammedahmed2 View Post
    Mine bikes meter is on 32k all things are genuine no problem with any thing
  4. #143
    JUNOON007's Avatar
    Dec 2012
    Sargodha
    28
    1,074
    21 Post(s)
    bahi tell me something about its clutch plates like how often they wear out,at what reading on odo meter on do they run out and how to tell they have run out and what has happend is that its kick is not working...i have to dhaka start it it has started happening since yesterday before the bike was running fine....when i drive it after dhaka start the clutch seems like it is holding the gears the mechanic says clutch plates have worn out and bahi also tell me after replaceing clutch plates does engine open?
    No engine will not open only side tapa will be opened
  5. #144
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    pick was much better top speed increase engine become smooth on high rpm
  6. #145
    rizwan4340's Avatar
    Sep 2014
    26
    507
    6 Post(s)
    or jab naye dalvaye to kitna kharcha aya i just went to maket hothora mecanic is saying 700 meh kam ho jye ga, yahamah wala is saying 1800-2100 ka kam ha and honda wala is saying '' many kha tha na kay junoon mat lo......cee gee! 126 lena tha'' ahahhaa dad says put bike on big stand and put a cloth over it.....and use cycle for rest of you life.. hun pakwheelers ka opinion rah gya ha
    Total cos of clutch plate change process is 800 almost. But remember 2 3 points . If your engine oil is recently poured in then clean the bottom side of engine and ask the mechanic to drain fuel in clean bottle as it need to be use again. Only brake side aluminum cover will be dismantled. First they will remove silencer then kick and then the side cover made of aluminium. Changing clutch plates is an easy process but fixing that aluminium cover need some experties to fit it in correct position as it is connected with spring and further connected with kick. After this you will find a huge difference in performance and changing in between gears.
  7. #146
    Jul 2014
    Rawalpindi
    18
    406
    6 Post(s)
    decided to wait till next weekend will inshallah take previous owner with me and thanks for all you guys help
  8. #147
    rizwan4340's Avatar
    Sep 2014
    26
    507
    6 Post(s)
    You are Always welcome.
  9. #148
    Eur0_2's Avatar
    Apr 2013
    278
    9 Post(s)
    salam to all ...
    recently i baught yamaha junoon 2006 model.. every thing is ok .except rear tyre.wanna chang it but first need suggession regarding tyre size quality etc.. so ap log kon sa recmend kro gy jis ke grip b ache ho or bike oundrpower b feel na ho tnx
    Catch Me If u can...
  10. #149
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by Eur0_2 View Post
    salam to all ...
    gohri or panter 2.75 18 are best for junoon and how your experience after cg
  11. #150
    rizwan4340's Avatar
    Sep 2014
    26
    507
    6 Post(s)
    salam to all ...
    Stock size is 2.50X18 and 2.75X18 is also suitable. There will be a little bit issue with fuel consumption but not that much. But road grip will be awesome.
  12. #151
    Eur0_2's Avatar
    Apr 2013
    278
    9 Post(s)
    Quote Originally Posted by saboor73 View Post
    jinab abi to party shru hoi ha aaj he to leya hai...hahahah will post my experience after a week ..
  13. #152
    Eur0_2's Avatar
    Apr 2013
    278
    9 Post(s)
    Quote Originally Posted by rizwan4340 View Post
    hmmm will check market soon .. ap k bike mn kon sa hai.. ?? junoon ke top speed kaya hai .fuel average..
  14. #153
    rizwan4340's Avatar
    Sep 2014
    26
    507
    6 Post(s)
    98 km/h achieved last month. Us k baad jab sy timing chain change kerwaya hey 85 90 km/h . Average 47 to 50 hey aur 2.50x18 he laga hua ghori sports
  15. #154
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    I had 2.75 in my junoon and the fuel avg was very good 55-60km/l was not a problem at all
  16. #155
    Jul 2014
    Rawalpindi
    18
    406
    6 Post(s)
    back tire silps a bit when you do hard breaking so i think it would be better to go for some VERY VERY Good quality tire and a bit fat one would be best
  17. #156
    rizwan4340's Avatar
    Sep 2014
    26
    507
    6 Post(s)
    Stock tires are good too but it must have good grooves. A fancy stylish tire won't give you proper grip but only look. For better grip choose best quality with better groove style. Reather than atyles of service cruiser.
  18. #157
    Eur0_2's Avatar
    Apr 2013
    278
    9 Post(s)
    Yar let me know what if i use suzuki raider headlight in junoon.. ia it good or not.
    rizwan bro i wanna ask some question regarding junoon.. i have junoon 2006 mdl with 32k on odo.. i baught it yesterday...
    i have some issue till now ..
    1.. felt vibration on left side footrest ... right side is smooth ..
    2.. jab mn 2nd gear sa first lgata hn to ya to blkul he neturl ho jata hai ya phir stuck ho jata ha 1st lgta ni .jb tk thore force sa na press kro.. what will be reason...???is some thing wrong with clutch or something else.. kal he tunning krvae hai.or oil b..
  19. #158
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    I have faced this problem go to any welding guy ask him to align the right foot rest by heating it don't let him do it without heating
  20. #159
    Eur0_2's Avatar
    Apr 2013
    278
    9 Post(s)
    but in my case vibration in left footrest right one is smooth no vibration..
  21. #160
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    so time junoon right foot rest touches gear lever(shifter) due to this gear stuck and as it stick with the gear lever it also causes the vibration try this if your feel vibration ask any mechanic to tight the nut which holds foot rest and bhai bike k darshan tou kardo
