Page 15 of 27 FirstFirst ... 5131415161725 ... LastLast
Results 281 to 300 of 531
Like Tree561Likes
Thread: The Red Yamaha YBR 125
    jadoon1992_vxlimited's Avatar
    Dec 2008
    24
    3,391
    7
    69 Post(s)
    6 Thread(s)
    Default The Red Yamaha YBR 125
    sallam everyone. i hope you all are fine. sold my 2011 gs to a friend and booked a ybr on 18th may. got the delivery on 23rd may. bike have done around 120 kms till now and loving the quality and the brakes. as the bike is in running phase, riding it below 50 but its very smooth.The Red Yamaha YBR 125 -1579769 positive and negative comments are welcomed.
    The Red Yamaha YBR 125 -1579820
    people need to grow up sometimes and act MATURE !
  2. #281
    Dec 2008
    24
    3,391
    7
    69 Post(s)
    6 Thread(s)
    2nd tunning done on 2300 kms. tappets were very loose. bike is More responsive and smooth now. the mixture setting is not changed yet. getting around 50 km/l easily.
  3. #282
    ghourifahad's Avatar
    Apr 2011
    26
    28
    From which service center you got it done brother?
  4. #283
    Apr 2011
    26
    28
    Quote Originally Posted by jadoon1992_vxlimited View Post
  5. #284
    Dec 2008
    24
    3,391
    7
    69 Post(s)
    6 Thread(s)
    Quote Originally Posted by ghourifahad View Post
    First tunning was done from Al-Haram Akbar road and 2nd from Zulfiqar autos Nazimabad
  6. #285
    musawheeler's Avatar
    Dec 2014
    17
    121
    So what's the top speed now bro?
    The more speed you want from your ride, the more you must know its engine.
  7. #286
    Dec 2008
    24
    3,391
    7
    69 Post(s)
    6 Thread(s)
    Quote Originally Posted by musawheeler View Post
    did not push the bike to its limits but 100-105km/hr pr easily cruise krti haiii on normal throttle. will let you know jb sahe he full rpms pr gear shift kr k top speed try krun ga . enjoying the smooth ride. 60-70 km/hr pr he chalata hun normally because the roads here are not for such high speeds.
  8. #287
    Apr 2011
    26
    28
    I would like to know what did they do in the first tuning brother? then what in the second one?
  9. #288
    Dec 2008
    24
    3,391
    7
    69 Post(s)
    6 Thread(s)
    in 1st tunning, all the nut bolts are checked, air filter cleaning, draining the fuel from the carb, oil change and oiling all the cables. in 2nd tunning, tappet and mixture adjustment along with the complete procedure mentioned in the manual
  10. #289
    muharis's Avatar
    Aug 2011
    9
    Alhamdulillah got my YBR red color done 24 KM. I am facing few problems.
    1) Kick is very hard is it okay?
    2) Would you recommend to adjust clutch setting as after engine gets hot I have to stop my bike using breaks or foot even after clutch is pressed. (normal clutch setting problem). should I adjust or will it get OK after some running.
  11. #290
    waqasshahzad's Avatar
    May 2015
    30
    35
    5
    Quote Originally Posted by muharis View Post
    You can get your clutch adjusted , but Kick is not suppose to be that hard . Please check your motor oil.
  12. #291
    Dec 2008
    24
    3,391
    7
    69 Post(s)
    6 Thread(s)
    is the kick issue solved or it is still hard?
  13. #292
    muharis's Avatar
    Aug 2011
    9
    Kick is much better now. but when engine is cold like in morning it is still a bit hard after engine gets hot kick is normal.I think it will get better with running.
    Clutch issue resolved by setting clutch wire at the lever end.
  14. #293
    Dec 2008
    24
    3,391
    7
    69 Post(s)
    6 Thread(s)
    yes bike will be fine after it completes a few hundred kms
  15. #294
    Dec 2008
    24
    3,391
    7
    69 Post(s)
    6 Thread(s)
    The Red Yamaha YBR 125 -1625671The Red Yamaha YBR 125 -1625672The Red Yamaha YBR 125 -1625673
  16. #295
    Dec 2008
    24
    3,391
    7
    69 Post(s)
    6 Thread(s)
    ​muffler and dunlop 100-90/18 tyre installed
  17. #296
    smag123's Avatar
    Oct 2014
    22
    31
    Muffler and tire looks great...How is the sound of the muffler? if u can share its video it would be greatful (Y)
  18. #297
    Naveed4speed's Avatar
    Aug 2006
    Sialkot
    26
    6,132
    7
    49 Post(s)
    2 Thread(s)
    Ap se ye umid nai thi 😆
    FXXB and EJ8 on its way............
  19. #298
    Dec 2008
    24
    3,391
    7
    69 Post(s)
    6 Thread(s)
    Quote Originally Posted by smag123 View Post
    will share the video soon. thanks alot
  20. #299
    Dec 2008
    24
    3,391
    7
    69 Post(s)
    6 Thread(s)
    Quote Originally Posted by Naveed4speed View Post
    Ap se ye umid nai thi 
    The Red Yamaha YBR 125 -1625746
  21. #300
    shahzaib112's Avatar
    May 2013
    Rawalpindi
    448
    iphone pe chlat hoga no idea as I use android.
    us pe without edge-4g nai chlta.
    sorry correct me if i am wrong was just going through this thread saw ur cnvrsatn.....i use tht speedometer app without any internet lollypop s4 nd it just uses gps without any internet nd shows speed.internet is not required or must for gps...gps is a separate hardware...i u clickon location it shows different options power saving(only net) high accuracy(GPS plus net) nd GPS only bro
