Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
Like Tree11Likes
Thread: Yamaha YBR 125 - Problems / Solutions Thread
    DJNOMI's Avatar
    Aug 2012
    551
    5
    26 Post(s)
    Question Yamaha YBR 125 - Problems / Solutions Thread
    AoA Members,
    This thread is dedicated for YAMAHA YBR 125 Problems only and if anybody had resolved their issues they can share solution with other members on thread also all complaints people are facing can be share with members and I will keep updating them in this thread so it can be easy for all members to know the solution of their problems.
    Problems:
    Missing Issue:
    Description of this issue is bike will start missing at higher RPM and can start in any gear if you throttle it above 8-8.5 RPM it can vary user to user.
    Bike Jerk Issue:
    Normally it does not happen but sometime if you are going at high speed and try to change gear upward or backward for a Nano second you bike will seems like stop and start or you can say it will jerk (Jhatka Marye gi Bike)
    Solutions:
    Missing Issue:
    For all members those are in breaking period it is suggested that till 1000 KM ride your bike as per manual instruction after first tuning ride it with full throttle and check if missing issue was resolved after first tuning, this is not manufacturing fault but fuel and air intake adjustment is required which can be done by experienced mechanic but again don?t change any settings and keep yourself calm in break-in period.
    Bike Jerk Issue:
    This issue can be clubbed with Missing factor right now this issue is not very common but I think it will be resolved once fuel intake and air intake is adjust which resolve missing factor.
    @admins please make this thread sticky for help of every member.
    [Proud Owner of Yamaha YBR 125 - MashaAllah] -- [Smartphones/Computers "Keera" ] -- [Fan of Traveling/Adventure]
  2. #21
    Newbie Follow
    okwardleopard's Avatar
    Nov 2016
    Default problem reporting
    i have ybr and have been riding it for about 700km yet. i am facing a problem my bike does not go into neutral position that easily instead it shifts into 2nd gear can someone tell me the problem
  3. #22
    ahm2303's Avatar
    Jul 2016
    21
    2 Post(s)
    When you are in 1st gear give gear lever a soft touch not full in back direction it will neautralize the gear. And also read manual thoroughly to have a smooth performance of the bike.thanx
  4. #23
    Newbie Follow
    bajisitani's Avatar
    Nov 2016
    Default Electrostatic Charge
    can any one please tell how can i remove electrostatic charge from my YBR body..it attract dust and pollen within seconds.
