Results 1 to 15 of 15
Like Tree2Likes
  • 1 Post By abdulrehmanrauf
  • 1 Post By margallar
Thread: How to set ybr carburetor idel fuel setting.
    frkadeel's Avatar
    Oct 2009
    Multan
    26
    133
    2 Post(s)
    Default How to set ybr carburetor idel fuel setting.
    Aoa, dostoo koi koi mujhe ye guide karsakta hai k main apne ybr k carburetor k fuel setting kase karsakta hun ? Keun k meri bike 50 tp 55 km ki avg darahi thehobc fuel py sirf bake fire ka masla tha to macanic k pass geya us ne setting chair di tak c is ki avg 40 to 45 km ho gahi hai yamaha k office b geya tha unho ne b setting kara k di but avg or b kam ho gahi..... Yaar ab main kia karun??? Is k carb k nechay ek screw hai fuel mixing ka mujhe bs itna bata do k agar main is ko clock wis ghumahun to fuel zaida hoga ya kam? Or anti clock wis ghumane c kia hoga?
    Founder Of MBC(Multan Bikers Club)
    margallar's Avatar
    Oct 2009
    9,957
    6
    283 Post(s)
    4 Thread(s)
    clockwise, reduces fuel in the mix, anticlockwise increases. adjust it where the bike idles fastest, then lower idle. go on a ride, if you feel any deficiency, adjust more.
    this will take you an hour to do it well. i guess all you need is a flat head screwdriver, never worked on a ybr tho
    haters gonna hate, potatoes gonna potate
    Mohidasghar's Avatar
    May 2012
    28
    Mery bikt tu 2 chorri mn 35 ka average de rhi ha.
    frkadeel's Avatar
    Oct 2009
    Multan
    26
    133
    2 Post(s)
    anyone else ???????? #vickytulla #onefifty #camry47
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    is this issue present in ybr from day 1 or it happens after damn mechanics touch it
    don't know why idiot mechanics play with air mixture screw and change its settings without any
    reason my honda cg dream while tuning mechanic changed its setting and opened it way open
    i listening backfiring sound from silencer i was worried but when i saw the mixture screw i
    understood its because of that went again to him for tuning now he has tried to restore screw
    to factory setting and bike is performing well no backfiring and bike was heating on previous
    settings as he had sat the mixture too lean and bike had lost its actual power
    Air Mixture Screw
    turned clock wise results in = Rich Mixture
    turned anti clock wise makes = Lean
    the best settings are where you get the best idle out of mixture screw
    neither too rich or too lean
    turning clock wise closes air hole thus making rich mixture outward anti clockwise
    allows air thus making lean mixture
    frkadeel's Avatar
    Oct 2009
    Multan
    26
    133
    2 Post(s)
    Quote Originally Posted by amjad635 View Post
    Air Mixture Screw
    #amjad635 bhi kia ybr main b mixture screw isi rule pir kaam karta hai ???
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    maine nahein dekha ybr ka screw par aisi h kaam karta hoga
    clock wise rotation screw ko band ya tight karti hai so ybr
    ka mixture screw agar tight karoge toh zyaada rich
    ab last mera pass jo bike thi uske settings jaise maine li note karli thi
    mere pass cd70 thi uske mixture screw ki position thi 1.40 turn outward
    or anti clockwsie from fully close mixture screw
    one turn is complete 360 degree turn
    abdulrehmanrauf's Avatar
    Oct 2009
    33
    770
    31 Post(s)
    I would like to make little correction.
    As margallar bro said above...clockwise, reduces fuel in the mix, anticlockwise increases.
    It is similar to GS/Sprinter that is a butterfly carb so the mixture screw the other way than of CG aur CD carbs.
    Technically if any carb has mixture screw at the end where its is connected to pipe which is connected to head then clockwise turns of screw reduces the fuel. CD or CG carbs have mixture screw at the end which is connected to air filter box so it works the opposite way.
    Quote Originally Posted by frkadeel View Post
    Bara CG-125 bana phirta hai jou Sprinter say derta hai ....
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Quote Originally Posted by abdulrehmanrauf View Post
    brother that could very well be possible unfortunately i am not much aware of mechanism of suzuki & yamaha motorcycles
    but what we 100% know is function of air mixture screw it allows or block air and sets air mixture ratio
    regarding mechanism of screw turning yeah may be they are different & opposite in different kinda carbs
    you have raised very good point
    margallar's Avatar
    Oct 2009
    9,957
    6
    283 Post(s)
    4 Thread(s)
    Air Mixture Screw
    Both backfires and overheating are a symptom of running too lean...
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    yes bro those two are symptoms and they should not be taken lightly i just hate mechanics
    why do they disturb these settings i have picture proof of what he did i used to adjust cd70 or pridor
    mixture myself but in cg carb mixture screw is underneath carb a bit difficult to access
    and i bought bike used so did not think of noting its mixture screw settings else when i bought my last
    bike cd70 i had noted its mixture settings
    Picture when ruined settings you can see mixture screw is too much out
    means it was too lean that is why faced backfiring & heating issue
    How to set ybr carburetor idel fuel setting -1602884
    picture after recent setting still needs little bit adjustment slight clock wise turn
    but i am running it as its running fine
    How to set ybr carburetor idel fuel setting -1602887
    and this is picture of untouch mixture screw
    How to set ybr carburetor idel fuel setting -1602888
    Really hate mechanics why do they change settings mechanic i went is honda warranty mechanic
    we go to tune our bikes to maintain it and keep it performing best but mechanics most of time
    do reverse they ruin bike you see a little mistake has such an bad impact on bike performance
    we hear this complain alot of backfiring & heating in cg & many might be just facing because of
    nonsense of mechanic not only you listen backfire sound from silencer & extra heatup of engine
    but loss in bike performance acceleration is affected as well
  12. #12
    frkadeel's Avatar
    Oct 2009
    Multan
    26
    133
    2 Post(s)
    any one now exect about ybr ??
  13. #13
    margallar's Avatar
    Oct 2009
    9,957
    6
    283 Post(s)
    4 Thread(s)
    grab a screwdriver, adjust it, go for a full throttle run...readjust...repeat..until it feels perfect....if you are scared, mark the initial position with paint or something
    stop going to mechanics for everything
  14. #14
    hamikhan's Avatar
    Jun 2014
    Other
    1,259
    37 Post(s)
    YBR carb is exact like suzuki bikes carb what is your location in multan i also lives in this city i can better guide you in this matter
  15. #15
    frkadeel's Avatar
    Oct 2009
    Multan
    26
    133
    2 Post(s)
    Quote Originally Posted by hamikhan View Post
    @hamikhan im from new multan .....where u from ?
Tags for this Thread
