Page 1 of 5 123 ... LastLast
Results 1 to 20 of 87
Like Tree73Likes
Thread: Yahama YBR125 G is here
    waqasshahzad's Avatar
    May 2015
    30
    35
    5
    Default Yahama YBR125 G is here
    BOOKING PRICE 1,32400.00 PKR
    (confirmed by
    Shahid Khalid Corporation , Koray Stop, Walton Road, Lahore)
    Available in Two Colours
    Dark Metallic
    Yahama YBR125 G is here -1612024
    Vivid Cocktail Red
    Yahama YBR125 G is here -1612032
    Difference between YBR125 and
    YBR125 G
    Engine type
    4 stroke, Air Cooled, SOHC vs 4 stroke, Air Cooled, OHC
    Tire Size(Front)
    2.75 - 18 42P vs 3.00 - 18 4P
    Tire Size(Rear)
    90/90 -18 51S vs 90/90 - 18 5P
    Overall length
    1975 mm vs 1990 mm
    Overall height
    1085 mm vs 1080 mm
    Seat height
    775 mm vs 785 mm
    Wheelbase
    1285 mm vs 1300 mm
    YBR125G Additional FEATURES than YBR125
    1. Special Double Fender
    2. Rubber Guards
    3. Front Suspension designed for both On and Off Road Conditions
    4. Halogen headlight round
    SOHC VS OHC engine
    OHC means OverHead Cam in general, while SOHC means Single OverHead Cam or Single Cam.
    In a SOHC engine the camshaft is installed in the cylinder head and valves are operated either by the rocker arms or directly through the lifters (as in the picture).
    The main advantage of an OHC design is that valves are operated almost directly by the camshaft, which makes it easier to maintain precise timing at higher RPMs. It's also possible to install three or four valves per cylinder. For example, Honda successfully uses the SOHC design in its late V6 engines where 4 valves per cylinder are operated by a single camshaft. See the Acura TL 3.2L 24-valve SOHC V6 engine in the second photo (Acura is Honda's luxury vehicle division).
    The main disadvantage of an OHC or SOHC engine is that it requires a timing belt or chain with related components, such as tensioners and guides to run the camshaft(s). This means higher production cost and more complex design. A timing belt needs to be replaced at regular intervals, typically every 60,000-120,000 miles, which adds to maintenance costs. A timing chain can last longer, but it is sensitive to regular maintenance: if engine oil is not changed regularly, a timing chain stretches and wears out.
    May 2015
    30
    35
    5
    Features
    Yahama YBR125 G is here -1612037Yahama YBR125 G is here -1612038Yahama YBR125 G is here -1612039Yahama YBR125 G is here -1612040
    May 2015
    30
    35
    5
    Specifications
    Yahama YBR125 G is here -1612041Yahama YBR125 G is here -1612042
    IceCold's Avatar
    Aug 2006
    33
    610
    20 Post(s)
    I still fail to see the point of this bike in a market like ours. How many people in Pakistan like to go on adventures on their motorcycles? The segment would be very small. Why is Yamaha targeting small segments of the market and not the average rider who wants a decent motorcycle for every day office routine but cannot afford more than a 100000?
    Anyway good luck with this bike. This is the first of its kind in Pakistan, i hope it impresses people who actually do like to go on of road tours and push their machines to the maximum. @vickytulla
    ifoo_786's Avatar
    Aug 2011
    Fateh pur
    27
    5,955
    53 Post(s)
    30 Thread(s)
    awesome bike. my type bike
    If travelling was free............ You know what i mean
    arsi_mast's Avatar
    Jan 2009
    25
    228
    3 Post(s)
    I want a test drive...
    18mentos1801's Avatar
    Jun 2015
    Select City
    46
    7
    Yahama YBR125 G is here - 566bff175f223dc87a2348a8b0101fc4Yahama YBR125 G is here - bea7ebd303c03e6df6fdfa823e5aca81Yahama YBR125 G is here - 6309da8c0928c92d417ec6da02f816f3Yahama YBR125 G is here - 80217259f3d3361b36d27d1d1d73e1c9Yahama YBR125 G is here - d8a5eca66fc9c1532984e4bee9fb62a2
    Source:Automark magazine fb page
    Pc Hanif Memon
    Sent from my iPad using Tapatalk
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    very nice looking motorcycle i have only one complain they should have launched it with spokes
    and with this price would have remain lesser than ybr sport & off road is good with spokes
    IceCold brother what wrong in variety its good they are launching bike of every type
    there is ybr-z model which is general daily use motorcycle for pakistani people they can
    easily ride with 3 people and take ammi sis etc bro i was asking for that model too a friend
    of mine told me who is yamaha dealer he said they are not launching it now because they want
    these models to make a market a bit as they are of different type motorcycles yamaha is pretty
    much confident on ybr-z sales so they are not launching it now as if they had launched it very first
    ybr sport & off road would have been neglected by people
    gemini85's Avatar
    Jun 2011
    Rawalpindi
    1,115
    15 Post(s)
    2 Thread(s)
    Amjad bhai is there any performance difference between ybr and ybrg. I know its too early to ask about it. But if u compare specs of both bike.
    Man's heart away from nature becomes hard.
    gemini85's Avatar
    Jun 2011
    Rawalpindi
    1,115
    15 Post(s)
    2 Thread(s)
    Hand guard and block pattern tyres are also missing. But ybrg is beautiful indeed
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Quote Originally Posted by gemini85 View Post
    bro some difference are obvious YBR-G has advantage of better performance & comfort on Off-Road
    You can visit yamaha website compare the features engine wise they are same but difference is there
    in suspension and other tweaks that suits off road
    but that does not mean ybr-g is not suitable to ride on road it will perform same good on road but has some
    advantages that makes it combination of both On Road & Off-Road Machine
  12. #12
    gemini85's Avatar
    Jun 2011
    Rawalpindi
    1,115
    15 Post(s)
    2 Thread(s)
    So in terms of performance and comfort its seems better ther ybr..?
  13. #13
    altisdualvvti's Avatar
    May 2012
    21
    1,966
    42 Post(s)
    Chalo atleast a new type of bike in Pakistan great going Yamaha
    Sent from my GFIVE G10 mini using Tapatalk
  14. #14
    May 2012
    21
    1,966
    42 Post(s)
    Same question
  15. #15
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Well it should be little bit more comfortable
  16. #16
    IceCold's Avatar
    Aug 2006
    33
    610
    20 Post(s)
    Quote Originally Posted by amjad635 View Post
    Nothing wrong in the variety. My point is that they are targeting a rather small segment of the market and not the other one which can be a really huge segment. Average people also want change but a change that they can afford and also one that is practical for every day use.
    They had launched the top end product which is gaining market as i can tell you about Lahore every day i see at least 3 to 4 YBR in DHA, Cantt and Garden town area so the sales have definitely gone up, they should now try to focus and capture CG-125 market segment within a price bracket of 100000. Let Honda face the heat so that they could too get off from their lazy asses and actually bring in a change in that ancient technology But apparently as you said Yamaha does not seem to be in the mood just yet.
  17. #17
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Brother top lines in your post proves yamaha strategy seems right
    but i don't agree last line in your post think bro why would yamaha want honda to
    get off from their lazy asses infact they would want honda remains stick to their decade
    old motorcycles honda thinks yamaha plans for new motorcycles would fail but on the other
    hand yamaha struggling and efforting to bring change in market and change sick minds of people
    YBR-Z would be launched a in year its an very good replacement for cg125 lets just hope here Yamaha
    price it exactly same as cg125 or even few k less than cg125 that will really force people think and people
    with some sense would think of buying yamaha 125 with latest tech and important feature like electric start
    at the moment biggest problem for yamaha is expensive parts
  18. #18
    jagsten30's Avatar
    Jan 2014
    218
    2 Post(s)
    eagerly waiting for yamaha 125z because (ab hard seat bardash nahi hoti)
    Hum woh NAHI jo DURR jain HALAT kai KHOONI manzar sai!
    Us DAURR mai JEENA lazim hai jis DAURR mai JEENA mushqil hoo!
  19. #19
    hash737's Avatar
    Jan 2010
    1,069
    31 Post(s)
    WE WANT MT-125. (GOOGLE IT)
    I have never owned a bike, but it yamaha launches MT-125 or something similar a street bike with diamond frame and ninja style, i will be the first one to get it.
    Trail bikes a not needed, advance tech aggressive modern bikes are needed.
  20. #20
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Quote Originally Posted by jagsten30 View Post
    sirf hard seat nahein
    Kick maarna
    vibrations
    hard seat
    no features
    unjustified price
    yeh sab bardaash nahein hota
Tags for this Thread
