Page 2 of 5 FirstFirst 1234 ... LastLast
Results 21 to 40 of 87
Like Tree73Likes
Thread: Yahama YBR125 G is here
    waqasshahzad's Avatar
    May 2015
    30
    35
    5
    Default Yahama YBR125 G is here
    BOOKING PRICE 1,32400.00 PKR
    (confirmed by
    Shahid Khalid Corporation , Koray Stop, Walton Road, Lahore)
    Available in Two Colours
    Dark Metallic
    Yahama YBR125 G is here -1612024
    Vivid Cocktail Red
    Yahama YBR125 G is here -1612032
    Difference between YBR125 and
    YBR125 G
    Engine type
    4 stroke, Air Cooled, SOHC vs 4 stroke, Air Cooled, OHC
    Tire Size(Front)
    2.75 - 18 42P vs 3.00 - 18 4P
    Tire Size(Rear)
    90/90 -18 51S vs 90/90 - 18 5P
    Overall length
    1975 mm vs 1990 mm
    Overall height
    1085 mm vs 1080 mm
    Seat height
    775 mm vs 785 mm
    Wheelbase
    1285 mm vs 1300 mm
    YBR125G Additional FEATURES than YBR125
    1. Special Double Fender
    2. Rubber Guards
    3. Front Suspension designed for both On and Off Road Conditions
    4. Halogen headlight round
    SOHC VS OHC engine
    OHC means OverHead Cam in general, while SOHC means Single OverHead Cam or Single Cam.
    In a SOHC engine the camshaft is installed in the cylinder head and valves are operated either by the rocker arms or directly through the lifters (as in the picture).
    The main advantage of an OHC design is that valves are operated almost directly by the camshaft, which makes it easier to maintain precise timing at higher RPMs. It's also possible to install three or four valves per cylinder. For example, Honda successfully uses the SOHC design in its late V6 engines where 4 valves per cylinder are operated by a single camshaft. See the Acura TL 3.2L 24-valve SOHC V6 engine in the second photo (Acura is Honda's luxury vehicle division).
    The main disadvantage of an OHC or SOHC engine is that it requires a timing belt or chain with related components, such as tensioners and guides to run the camshaft(s). This means higher production cost and more complex design. A timing belt needs to be replaced at regular intervals, typically every 60,000-120,000 miles, which adds to maintenance costs. A timing chain can last longer, but it is sensitive to regular maintenance: if engine oil is not changed regularly, a timing chain stretches and wears out.
  2. #21
    asad01's Avatar
    Sep 2008
    Abbotabad
    53
    326
    6 Post(s)
    I was amazed at the ground clearance of YBR125G, I thought it was an adventure bike. The clearance is exactly the same as YBR125, which is 145 mm. I was hoping for something in the 175-200 mm range. Suzuki GS150 has a clearance of 165 mm and it is not enough for Northern areas hilly tracks. Don't get me wrong, a Chinese 70 cc bikes can go to Devsai and Lake Saif ul Malook, but the riders have to be very careful. On GS150 I have to be careful but not that careful. How can anyone call a bike with a 145 mm clearance an 'Adventure Bike' or an off-road bike is beyond my comprehension. Maybe there are people who call riding on a pothole infested road an adventure, but on hilly tracks, specially after rain, one needs high ground clearance.
    Anyways, since I will probably not see this bike until I visit Rawalpindi/Islamabad, I will appreciate if someone could take a close look at the bottom of the bike (under the engine) and put some light on the 'Engine Guard'.
    Asad
  3. #22
    DJNOMI's Avatar
    Aug 2012
    551
    5
    26 Post(s)
    Quote Originally Posted by hashsohail View Post
    WE WANT MT-125. (GOOGLE IT)
    I have never owned a bike, but it yamaha launches MT-125 or something similar a street bike with diamond frame and ninja style, i will be the first one to get it.
    Trail bikes a not needed, advance tech aggressive modern bikes are needed.
    also google the price of it or us k bad shanti rakhye
    [Proud Owner of Yamaha YBR 125 - MashaAllah] -- [Smartphones/Computers "Keera" ] -- [Fan of Traveling/Adventure]
  4. #23
    jagsten30's Avatar
    Jan 2014
    218
    2 Post(s)
    Quote Originally Posted by amjad635 View Post
    sirf hard seat nahein
    Kick maarna
    vibrations
    hard seat
    no features
    unjustified price
    yeh sab bardaash nahein hota
    hahahaha exactly bro..
    Hum woh NAHI jo DURR jain HALAT kai KHOONI manzar sai!
    Us DAURR mai JEENA lazim hai jis DAURR mai JEENA mushqil hoo!
  5. #24
    altisdualvvti's Avatar
    May 2012
    21
    1,965
    42 Post(s)
    Quote Originally Posted by DJNOMI View Post
    True I think if it comes to pak then the Price will be around 300k easily
    Sent from my GFIVE G10 mini using Tapatalk
  6. #25
    DJNOMI's Avatar
    Aug 2012
    551
    5
    26 Post(s)
    Quote Originally Posted by altisdualvvti View Post
    We are going off topic mt 125 in my opinion does not make sense in 3 lac in pakistan market why not wait for fz series which will be 150cc and will be lesser in price around 170~180k
  7. #26
    May 2012
    21
    1,965
    42 Post(s)
    I m just giving my guess maybe it is cheaper then 300k
  8. #27
    Shafin619's Avatar
    Sep 2012
    21
    2,699
    95 Post(s)
    2 Thread(s)
Size:  58.5 KBName:  uploadfromtaptalk1440989056535.jpg
Size:  55.3 KBName:  uploadfromtaptalk1440989086193.jpg
    Sent from my SM-N900 using Tapatalk
    4 wheels move the body 2 wheels move the soul
  9. #28
    awaiz43's Avatar
    Oct 2014
    Rawalpindi
    29
    238
    i totally agreed with ur comments.. the clasic CG is the main choice in Pakistan Yamaha should bring simple routine bike with good engines like YBR and features.
  10. #29
    awaiz43's Avatar
    Oct 2014
    Rawalpindi
    29
    238
    kafi time se wait hy bhai yeh regular ya base model kn launch kr rhy hyn?
  11. #30
    vickytulla's Avatar
    Oct 2009
    8,414
    38
    876 Post(s)
    31 Thread(s)
    The only and the biggest resaon I will encourage Yamaha on every platform is that they are investing on Pakistan and Pakistani, I strongly agree they are not targetting the masses who are under spell of AHL and Chona70s.
    Now about this Bike my personal view is "Holly molly what the heck is this" it kind of a worse of to worlds, fron end of a trail and ground Clearance of a city bike I mean what is the over all gain = 0
    Second = 10 Horse power, currently I am using 17Horse power trail and I still feel like using the lousiest trail when It comes to offroad.. Just imagine what will happen to this little thing when it will be pushed in real offroads..
    Quote Originally Posted by IceCold View Post
    I still fail to see the point of this bike in a market like ours. How many people in Pakistan like to go on adventures on their motorcycles? The segment would be very small. Why is Yamaha targeting small segments of the market and not the average rider who wants a decent motorcycle for every day office routine but cannot afford more than a 100000?
    Anyway good luck with this bike. This is the first of its kind in Pakistan, i hope it impresses people who actually do like to go on of road tours and push their machines to the maximum. @vickytulla
  12. #31
    hash737's Avatar
    Jan 2010
    1,062
    31 Post(s)
    Google the price of YBR 125 in United Kingdom, uskay baad ap bhi shanti rakhyea
    P.S 4,000 Pound Sterling (Pak rupees 0.65 Million)
    EXACTLY the same thing, no changes whatsoever.
    MT-125 is same as YBR just body type is change and a few goodies like Water Cooled engine.
  13. #32
    hash737's Avatar
    Jan 2010
    1,062
    31 Post(s)
    You guys have got it COMPLETELY wrong.
    YBR 125 Costs 4,000 Pound in United Kingdom.
    Exactly the same thing costs us 1 lakh 30 thousand in pak. (Literally Exactly the same model features)
    Do not compare international prices as Motorcycles are expensive in Europe.
    MT-125 if launched it will be priced not more thn 1 lakh 50 thousand.
    YBR 125G has impressed me very well. i wont mind buying it as i live in islamabad, i wont mind taking it off road in the mountains from time to time
  14. #33
    abdulrehmanrauf's Avatar
    Oct 2009
    33
    770
    31 Post(s)
    Apparently in my opinion, this G version is similar to Sports version just like we have CG-125 vs CG Dream or Sprinter standard vs Raider. I agree there are certain differences in technical areas but as @IceCold and @vickytulla said this is not a pure off roader but a beautiful good looking and a changed looking bike.
    Quote Originally Posted by vickytulla View Post
    Bara CG-125 bana phirta hai jou Sprinter say derta hai ....
  15. #34
    f4fraz's Avatar
    Dec 2013
    34
    651
    17 Post(s)
    Me to in the favor of MT.
    and no matter what ppl r saying about our choice is right or wrong and about the price.
    I dont understand why we get criticized when we bring some different ideas or suggestions...
    Anyways my vote from 1st day is for MT and 2nd number is FZ 150cc.
    No doubt Yamaha bring the 2nd product to fast.
    But I will count YBR + G + Z in the same product category. same or similar engine with different body types.
    The product change will be count when a blank change will show.
    The change will be
    MT
    FZ
    Tricity
    What you wish guys???
  16. #35
    DJNOMI's Avatar
    Aug 2012
    551
    5
    26 Post(s)
    what point you want to make?? as i said MT 125 will be crap paying such price for 125 CC Water cooled engine and better shape that's it ?? why not wait for 150 CC fZ series which will be less than 2 Lac ... and believe me MT 125 porye pakistan main 100 units bi nai biknye in this price we are getting YBR cheaper but yes in international model it has EFI engine whereas in Pak we are getting Carburetor.
    above all People are asking for base model as it been discussed many times it will be launched in early 2016 .. so Yamah is here with some plan my friends give them time YBR 125G whatever it is but at least after 3 months they launched 2nd model though i agree it does not make any sense but still it will be addition in their product line
    P.S: MT 125 in 150K in your dreams only possible if No EFI No Water Cooled local parts ... may be than it can happen
  17. #36
    May 2012
    21
    1,965
    42 Post(s)
    YBR 125G has impressed me very well. i am looking to buy this bike soon as i live in islamabad, i wont mind taking it off road in the mountains from time to time
    Sorry for going off topic but when Honda launched crz sports hybrid in Pakistan u said that u were going to buy it.Did u brought it?
  18. #37
    aa78's Avatar
    Dec 2011
    696
    10 Post(s)
    UK YBR is GBP2600. It has UK VAT and other taxes included in price.
    Ref: YBR125 2014 - Motorcycles - Yamaha Motor UK
    YBR125 from ? 2,599.00
    All prices include On-the-Road preparation charges, delivery to dealer, number plates, pre-delivery inspection, petrol and VAT at 20%. Government first registration fee and Vehicle Excise Duty is excluded and will be charged additionally at the prevailing rate.
    UK YBR is not the same as Pak YBR. UK one is EFI, not carby YBR. Also, there is difference in features, fittings and quality (nearly all reduced/stripped away to decrease cost) as is usual with all Japanese assemblers in Pakistan.
    Please stop spreading false information trying to portray Pak YBR as a steal compared to UK YBR. The products being compared are not the same.
    Yamaha coming here and introducing YBR and its derivatives is a refreshing change and should be encouraged wholeheartedly. However, fanboys should refrain from spreading false information which will misguide others on PW and make them regret their future purchase due to built-up false expectations. It will be a disservice to Yamaha and their bike line up in Pakistan.
  19. #38
    arsi_mast's Avatar
    Jan 2009
    25
    228
    3 Post(s)
    Shape is also a concern but i'm more concerned about hp, i was thinking about buying this ybr g model but talked to some guys about ybr and they told me it is underpowered you should stick with your gs150 which is better in power... Looking forward for a powerful engine by yamaha... this is a good looking bike but definitely not suggested for touring...
  20. #39
    khan.mehmood's Avatar
    Oct 2012
    55
    I also which if they could do it, but I dont think so they ever gona look at what people has to say and what the want.
  21. #40
    May 2015
    30
    35
    5
    Guys As compare to YBR125's SOHC engine, YBR125G ko OHC engine honay ka koi benefit ho ga ya nai ? @vickytulla @amjad635 @IceCold @asad01 @DJNOMI@Shafin619
Tags for this Thread
