Page 4 of 5 FirstFirst ... 2345 LastLast
Results 61 to 80 of 87
Like Tree73Likes
Thread: Yahama YBR125 G is here
    waqasshahzad's Avatar
    May 2015
    30
    35
    5
    Default Yahama YBR125 G is here
    BOOKING PRICE 1,32400.00 PKR
    (confirmed by
    Shahid Khalid Corporation , Koray Stop, Walton Road, Lahore)
    Available in Two Colours
    Dark Metallic
    Yahama YBR125 G is here -1612024
    Vivid Cocktail Red
    Yahama YBR125 G is here -1612032
    Difference between YBR125 and
    YBR125 G
    Engine type
    4 stroke, Air Cooled, SOHC vs 4 stroke, Air Cooled, OHC
    Tire Size(Front)
    2.75 - 18 42P vs 3.00 - 18 4P
    Tire Size(Rear)
    90/90 -18 51S vs 90/90 - 18 5P
    Overall length
    1975 mm vs 1990 mm
    Overall height
    1085 mm vs 1080 mm
    Seat height
    775 mm vs 785 mm
    Wheelbase
    1285 mm vs 1300 mm
    YBR125G Additional FEATURES than YBR125
    1. Special Double Fender
    2. Rubber Guards
    3. Front Suspension designed for both On and Off Road Conditions
    4. Halogen headlight round
    SOHC VS OHC engine
    OHC means OverHead Cam in general, while SOHC means Single OverHead Cam or Single Cam.
    In a SOHC engine the camshaft is installed in the cylinder head and valves are operated either by the rocker arms or directly through the lifters (as in the picture).
    The main advantage of an OHC design is that valves are operated almost directly by the camshaft, which makes it easier to maintain precise timing at higher RPMs. It's also possible to install three or four valves per cylinder. For example, Honda successfully uses the SOHC design in its late V6 engines where 4 valves per cylinder are operated by a single camshaft. See the Acura TL 3.2L 24-valve SOHC V6 engine in the second photo (Acura is Honda's luxury vehicle division).
    The main disadvantage of an OHC or SOHC engine is that it requires a timing belt or chain with related components, such as tensioners and guides to run the camshaft(s). This means higher production cost and more complex design. A timing belt needs to be replaced at regular intervals, typically every 60,000-120,000 miles, which adds to maintenance costs. A timing chain can last longer, but it is sensitive to regular maintenance: if engine oil is not changed regularly, a timing chain stretches and wears out.
  2. #61
    SyedMoazzam's Avatar
    Jul 2012
    Rawalpindi
    2,271
    39 Post(s)
    Waiting for fz16 till next year. Untill then GS zindabad
  3. #62
    f4fraz's Avatar
    Dec 2013
    34
    668
    17 Post(s)
    Quote Originally Posted by vickytulla View Post
    The only thing which worries me for saying yes go ahead is = GS150 has a power edge and power matters big time. Qaulity wise its a far ahead the GS150.
    Hello Vicky
    If I explain your wording to let me understand...
    Suzuki GS-150 is still not bad option after arriving Yamaha YBR-125.
    OK. If I or someone buy Suzuki GS-150 that means its not wrong decision (some how if ppl think or said).
    But if wait for Suzuki to bring sporty look maybe in same engine?
    I hope you understand my concern and confusion stand.
    Please help
  4. #63
    arsi_mast's Avatar
    Jan 2009
    25
    228
    3 Post(s)
    Quote Originally Posted by umerchaudhary View Post
    Buy a second hand or import if want to feel proper taste of trail. And bro who told you I was going to buy it. If I will buy in offroad category by yamaha pakistan in same power I will wait for to buy TTR 125 LE.
    Does yamaha have any plans to launch TTR 125 LE next year????
  5. #64
    12gauge's Avatar
    Oct 2013
    176
    68 Post(s)
    3 Thread(s)
    AoA Everybody.
    This seems like a very nice offering by YAMAHA. a predominantly a street oriented bike with increased suspension travel to accommodate off-road tracks is a very nice idea indeed. I wonder if YAMAHA has also changed its gearing ratio to offer more Torgue at low RPMs.
    Regards.
  6. #65
    Alir1's Avatar
    Aug 2013
    232
    2 Post(s)
    Name:  ImageUploadedByPW Forums1441270034.305424.jpg
  7. #66
    Alir1's Avatar
    Aug 2013
    232
    2 Post(s)
    Name:  ImageUploadedByPW Forums1441270166.971513.jpg
Size:  85.1 KBName:  ImageUploadedByPW Forums1441270212.095834.jpg
Size:  94.1 KBName:  ImageUploadedByPW Forums1441270269.904692.jpg
Size:  108.5 KBName:  ImageUploadedByPW Forums1441270321.772892.jpg
Size:  70.5 KBName:  ImageUploadedByPW Forums1441270378.082315.jpg
  8. #67
    Alir1's Avatar
    Aug 2013
    232
    2 Post(s)
    Name:  ImageUploadedByPW Forums1441270638.936059.jpg
Size:  101.0 KBName:  ImageUploadedByPW Forums1441270699.335244.jpg
  9. #68
    abdulrehmanrauf's Avatar
    Oct 2009
    33
    771
    31 Post(s)
    Sachiiii??
    Quote Originally Posted by Alir1 View Post
    Bara CG-125 bana phirta hai jou Sprinter say derta hai ....
  10. #69
    Alir1's Avatar
    Aug 2013
    232
    2 Post(s)
    Sach he
  11. #70
    f4fraz's Avatar
    Dec 2013
    34
    668
    17 Post(s)
    Source please
  12. #71
    May 2015
    30
    35
    5
    Quote Originally Posted by f4fraz View Post
    Source please
    https://www.facebook.com/RoadPrinceMotorcycles
  13. #72
    gemini85's Avatar
    Jun 2011
    Rawalpindi
    1,115
    15 Post(s)
    2 Thread(s)
    waiting for "First YBR 125-G of Pakwheels" Thread
    Man's heart away from nature becomes hard.
  14. #73
    altisdualvvti's Avatar
    May 2012
    21
    1,966
    42 Post(s)
    Quote Originally Posted by gemini85 View Post
    I saw one today while going to market.I hope that person will be pakwheeler and will make a thread for us.
    Sent from my GFIVE G10 mini using Tapatalk
  15. #74
    vickytulla's Avatar
    Oct 2009
    8,421
    38
    876 Post(s)
    31 Thread(s)
    GS lacks lots of gadgets and Alloys and sporty modern looks... but if you are kind of a practical person and mainly do long routes your best choice would be offcourse GS-150
    For City use and once in a blue moon touring YBR-G is equally good.
    Hello Vicky
    Please help
  16. #75
    f4fraz's Avatar
    Dec 2013
    34
    668
    17 Post(s)
    Thank you bro
    In case if I wait for next gen bikes then there are chances of getting family type modern bike?
    OR
    the modern bike should only for youngsters or singles?
  17. #76
    umerchaudhary's Avatar
    Apr 2007
    32
    1,202
    4 Post(s)
    2 Thread(s)
    Why RoadPrince 150cc same in looks like Piaggio Robinson 150cc which was launched last year and also got fail response.
  18. #77
    alkandar's Avatar
    Mar 2006
    654
    7 Post(s)
    2 Thread(s)
    Yahama YBR125 G is here -1615685
  19. #78
    alkandar's Avatar
    Mar 2006
    654
    7 Post(s)
    2 Thread(s)
    Yahama YBR125 G is here -1615686
  20. #79
    alkandar's Avatar
    Mar 2006
    654
    7 Post(s)
    2 Thread(s)
    Yahama YBR125 G is here -1615696
  21. #80
    MySchizoBuddy's Avatar
    Feb 2010
    278
    Wow tons of roadprince posts in the yamaha thread.
    Admin please remove them from here and move them to a seperate thread on Other bike section
Tags for this Thread
