Page 12 of 13 FirstFirst ... 210111213 LastLast
Results 221 to 240 of 259
Like Tree114Likes
Thread: Yamaha YBR G not crossing 90 km/h
    aliarshad26's Avatar
    Mar 2013
    Faisalabad
    30
    770
    10
    13 Post(s)
    Default Yamaha YBR G not crossing 90 km/h
    Slaam to all @Xulfiqar, @vickytulla, @amjad635, @saboor73
    i bought YBR G model few days back
    now odometer reading is 1200 km
    i did running very carefully
    according to advice of friends i changed oil first at 250-300 then 700 and now at 1025 km with liqui moly 10w40
    i did running according to following steps
    first 200 km speed was 40 km/h
    200-500 speed 50-55 km/h
    500-800 60-65 km/h
    800-900 80km/h
    900-1025 tried to speed it up
    but not crossed 100
    speeding pattern is
    in 2nd gear 60 km/h
    3rd gear 80km/h (10000 rpm)
    4th gear 90km/h with 8000 rpm full throttle (some times 95)
    5th gear no use RPM decrease and also 5km/h speed decreases
    one thing that is teasing me that when i changed first oil a lot of metal particles were in oil and there also a "Needle" of just 1.5 inch was also present in oil
    i am very tensed what to do
    pakwheelers help me please
    Similar Threads:
  2. #221
    Naveed4speed's Avatar
    Aug 2006
    Sialkot
    26
    6,132
    7
    49 Post(s)
    2 Thread(s)
    Chlo shukar hai k ap satisfy hogai....
    FXXB and EJ8 on its way............
  3. #222
    biloo's Avatar
    Sep 2004
    33
    1,290
    16 Post(s)
    Quote Originally Posted by aliarshad26 View Post
    Today i went for oil change
    Presently i am using Liqui Moly 10W40 and its 1700 km driven
    but shopkeeper told that oil may cover more 1000 km
    but i will change at 2000 km
    he offered me a bundle pack
    he said that we are offering
    1) chain treatment, (first we (they) will wash chain with petrol and then apply liquid that may last 1 year) according to shopkeeper
    2) Before engine oil change, Engine Flush it with liquid chemical to Remove Sludge from engine
    3) Fuel Additive used in petrol tank it contains chemical which remove Carbon from cylinder head and cleans Carburetor and its effect lasts 1000 Kms
    4) Oil Additive used in Engine oil after engine flush with new oil it increases life of engine as it makes friction less and makes engine sound less
    These are claims made by him
    should i buy this package?
    You dnt need anythng else other than oil in your engine. Dnt waste your mney
    Sent from my SM-N910G using Tapatalk
  4. #223
    Mar 2013
    Faisalabad
    30
    770
    10
    13 Post(s)
    Ulysse is howmuch reliable ?
    Plzzz tell that person who has used it many times
    Sent from my SM-E700F using Tapatalk
  5. #224
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Ulysse does messes and gives inaccurate readings its not 100% accurate
  6. #225
    Mar 2013
    Faisalabad
    30
    770
    10
    13 Post(s)
    Quote Originally Posted by amjad635 View Post
    How much inaccurate is this amjad brother?
    Many of our pw fellows use this ulysse speedometer' they too plzzz share that howmuch accurate/inaccurate is ulysse speedometer is???
  7. #226
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    i had an thread to write in detail about it but i was not able to write i had proofs as well
    bro first of all if you want to experiment drive on road covered with trees it will give wrong
    reading and same if the there is cloudy weather
    and 100km/h it showed speed 96-97km/h on suzuki cultus corolla cg125 and cg dream
    how is possible that all different meters had almost same error and at speed like 110km/h
    it shows speed 105km/h even in low speeds when signal is not strong it gives wrong reading
    my pridor had wrong meter i admit but bikes like cg125 cg dream have pretty accurate meters
    its the fault with this application some time it gives accurate reading like i checked on 60km/h
    now on same bike at same speed it was showing less speed 57km/h i think it has signal issue
    and specially at hi speed it struggles for signal
  8. #227
    Aug 2006
    Sialkot
    26
    6,132
    7
    49 Post(s)
    2 Thread(s)
    I can agree with these facts...
  9. #228
    Mar 2013
    Faisalabad
    30
    770
    10
    13 Post(s)
    i also felt that This application tells 5 km less than reading on bike meter
    if ULYSSE speedometer is showing reading of 110km/h it means my bike has gone to 115km/h or more?
  10. #229
    aa78's Avatar
    Dec 2011
    704
    10 Post(s)
    ^ Vehicular speedometers typically read higher than actual speed reading (by up to 6%) for ensuring vehicle (bike/car) stays below speed limits when driver/rider thinks he/she is going at actual speed limit. Changing of tyres, front and rear pinions, etc affect the speed reading and change the difference between speedometer and actual reading. If one is inclined to make speedometer reading more accurate, one could alter such parameters for this purpose but bike response will also be altered.
    GPS readings are more accurate when measured while having clear line of sight access to the sky (open roads with minimal electricity lines, no cloud cover, no excessive vegetation, etc). If you have 8+ satellites, your readings will be very accurate.
  11. #230
    Mar 2013
    Faisalabad
    30
    770
    10
    13 Post(s)
    Respectable Pakwheelers and YBR owners has anyone tried tune up of YBR at home?
    i want to purchase full tools and accessories required for a bike to tune up (YBR and Honda CD 70)
    please tell me list of tools
    @Naveed4speed, @amjad635,
    Specially naveed bhai if you can help me by asking your mechanic friend names and sizes of tools
    Specially the small screw driver used to set fuel mixture and increase/decrease fuel.
    some i remember are that
    1) Feeler gauge
    2) Screw drivers
    3) T pana for chain settings
    4) tool to open the lid of tappet
    remaining you people please guide
  12. #231
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    T pana of 10mm & 8mm is useful, ybr tappet cover is 24mm for this you will require combination spanner
    ring spanner of 8-9mm will be required for loosing tappet locknut and you will require tappet key/adjuster
    and open end spanners of 8-11mm are useful tools can be used for opening gear lever of cd70 & for its
    tappet cover 17mm combination spanner
    i would not recommend for doing tuning until and unless you have take all the knowledge and you are confident
    of doing tappet adjustment
  13. #232
    Mar 2013
    Faisalabad
    30
    770
    10
    13 Post(s)
    Yamaha YBR G not crossing 90 kmh -1641979Yamaha YBR G not crossing 90 kmh -1641980Yamaha YBR G not crossing 90 kmh -1641981Yamaha YBR G not crossing 90 kmh -1641982Yamaha YBR G not crossing 90 kmh -1641979Yamaha YBR G not crossing 90 kmh -1641980Yamaha YBR G not crossing 90 kmh -1641981Yamaha YBR G not crossing 90 kmh -1641982
    I saw this tool box in a Advertisement on internet
    Will this work for tune up purpose
  14. #233
    shahzaib112's Avatar
    May 2013
    Rawalpindi
    448
    Price of this tool set?
  15. #234
    omar4494's Avatar
    Aug 2005
    1,255
    15 Post(s)
    I don't know about this but I bought another tool set little like it. Very bad experience. A little more pressure and they deform or break. , so my suggestion is instead of online go to a good hardware store try it than and there and buy.
  16. #235
    Mar 2013
    Faisalabad
    30
    770
    10
    13 Post(s)
    Quote Originally Posted by shahzaib112 View Post
    750 Rupees
  17. #236
    Aug 2006
    Sialkot
    26
    6,132
    7
    49 Post(s)
    2 Thread(s)
    Ali arshad bhai this tool set is not needf for ybr engine tuning....
  18. #237
    Aug 2006
    Sialkot
    26
    6,132
    7
    49 Post(s)
    2 Thread(s)
    And ali bhai ab to apki bike 110 pe jati hai.
    Ab to title change krdo ... 😆
  19. #238
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    yeah valid point Naveed4speed, But thread should remain with same title
    its time aliarshad create a thread for his ybr-g and share his overall experience
    there and continue that thread
    problem for which this thread was created is resolved
  20. #239
    Mar 2013
    Faisalabad
    30
    770
    10
    13 Post(s)
    how to change the title of thread
    and bike speedometer tells 105 km while Ulysse speedometer tells 110 km?
  21. #240
    Mar 2013
    Faisalabad
    30
    770
    10
    13 Post(s)
    Quote Originally Posted by Naveed4speed View Post
    ave
    @Naveed4speed
    brother guide me a complete set of tools for Honda 70cc and YBR
    i m fed up of mechanics
    i started to wash and wax my bike at home , many times better than professional service stations
    now help me in getting rid of mechanics
