Page 8 of 13 FirstFirst ... 678910 ... LastLast
Results 141 to 160 of 259
Like Tree114Likes
Thread: Yamaha YBR G not crossing 90 km/h
    aliarshad26's Avatar
    Mar 2013
    Faisalabad
    30
    770
    10
    13 Post(s)
    Default Yamaha YBR G not crossing 90 km/h
    Slaam to all @Xulfiqar, @vickytulla, @amjad635, @saboor73
    i bought YBR G model few days back
    now odometer reading is 1200 km
    i did running very carefully
    according to advice of friends i changed oil first at 250-300 then 700 and now at 1025 km with liqui moly 10w40
    i did running according to following steps
    first 200 km speed was 40 km/h
    200-500 speed 50-55 km/h
    500-800 60-65 km/h
    800-900 80km/h
    900-1025 tried to speed it up
    but not crossed 100
    speeding pattern is
    in 2nd gear 60 km/h
    3rd gear 80km/h (10000 rpm)
    4th gear 90km/h with 8000 rpm full throttle (some times 95)
    5th gear no use RPM decrease and also 5km/h speed decreases
    one thing that is teasing me that when i changed first oil a lot of metal particles were in oil and there also a "Needle" of just 1.5 inch was also present in oil
    i am very tensed what to do
    pakwheelers help me please
    Similar Threads:
  2. #141
    Mar 2013
    Faisalabad
    30
    770
    10
    13 Post(s)
    Quote Originally Posted by abobobilly View Post
    @aliarshad26! You are facing problems. You don't need mechanics. You need YOU, and a bit of common sense.
    It took me a couple of years to realize that if you your ride to be perfect, then do all its work yourself. It may not be perfect the first couple of times you do it, but it will be, once you get enough experience on your hands. Even if you mess something up, the thought that "YOU" were the cause, will cool you down because, let's admit it, seeing someone else mess up your ride is more furious.
    If you think i am just speaking some words, then you need to visit my own CG125 thread, where quite a few of my experiences are shared. What you are facing with your new YBR-G, i was facing with my CG125. And from the past 5-6 months, i have been doing ALL the tune-ups (oil change, tappet adjustment, even carb tunning and mixture settings) myself, and i am telling you, even when i am not quite satisfied with my word, i am happy because i can change the settings however i want, whenever i want. And i have changed my carb's mixture settings like 5 times, in past 3 weeks. (I keep a screw driver in my bag, and wherever i feel that the mixture is not right, i part the bike on the side of the road and set the mixture again.).
    From all the things you have mentioned, your bike seems just fine. You are looking for perfection, which you won't find anywhere. So stop wasting time.
    Bike starting issue: Do the valves adjustment yourself, and also the mixture settings (without opening up the carb). A LOT of tutorials on YouTube. Incorrect mixture settings and very tight valves are also one of the reasons your bike may not be starting up properly. The worst case scenario might be a bent valve, but that can't happen in a brand new bike, unless you are hammering it way too hard.
    Top Speed Issue: If it goes to 95km/h ... your ride is just fine. Screw those idiots who claim to get 130km/h out of their a**. Its technically not even possible, when ALL the other rides in the same 125cc class are unable to achieve that speed. Even a CG125 these days is maxing out at 105km/h, and that bike is like a paper weight infront of your heavier YBRG.
    If I were you, i will stop wasting my time with any Mechanics, and take matters in my own hand. Buy the necessary tools, and DO IT YOURSELF.
    aap ki baat se kafi hosla hua hy k is dunya mein main he akela ni jis ki new bike mein thori boht problem hy
    jahan tak perfection ki baat hy to baat yeh hy k last 10-12 years se meray pass CD 70 hy jo nearly 99.9% times first kick start thi
    i take a lot of care of bike
    i never used 1 single of spare part china, or local always Genuine
    so in the habit of perfect bike
    chalo ab kal he tool kit le ata hoon
    lakin yeh zaroor kahoon ga k yamaha ki customer care services and after sale services YAMAHA ko progress ni karney den ge
    ya behavior change karna ho ga ya phir Good bye
    i mentioned many times about top speed, actually i am not kind of Rocket driver, baat yeh hy k pehley oil change pr kuch needle type cheeze bahr ayee thi
    main ander ander se yeh soch raha hoon k Engine ko Damage ho gya hy aur is waja se daily issues ho rahe hen
    however i will try at least one time to tune up my bike my self
    Thanks a lot for such a long and detailed reply
  3. #142
    Naveed4speed's Avatar
    Aug 2006
    Sialkot
    26
    6,132
    7
    49 Post(s)
    2 Thread(s)
    Sir kuch b nai bike ko.
    It just needs a good setings....
    FXXB and EJ8 on its way............
  4. #143
    Mar 2013
    Faisalabad
    30
    770
    10
    13 Post(s)
    Quote Originally Posted by Naveed4speed View Post
    ok
    before selling bike
    1 dafa poora zor lagana hy is ko "Rah-e-Rast" per laney k liye
    sale bhi ni karna chahta Q k 25000 ka nuksaan hota hy
    rate 111000 laga hy market mein
  5. #144
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Arshad kindly don't take my this post a discouragement but i really recommend
    first of all take a thorough research on net on how to tune bike cd70 and cg125
    than attempt for tuning air mixture tutorials are also available and YES there is ybr
    video also there but its animated rather search you should find guides for tuning of ybr
  6. #145
    abobobilly's Avatar
    Jul 2010
    1,359
    111 Post(s)
    4 Thread(s)
    Process for Valve Adjustment: Yamaha YBR 125 Owner Blog : Yamaha YBR 125 blog valve clearance adjustment tappets
    NOTE:
    + Leave the bike to cool overnight (for best results). At least 8 Hours of Rest should be give to the engine. But Don't start doing Valve Clearance on a very cold engine. It'll never be done right.
    + When you want to start doing the process, Turn ON the engine and warm it up for like 30 seconds or 1 minute ... just enough so that you can keep your hand the engine without feeling uncomfortable.
    + NOW follow the process above.
    For Carb's mixture adjustment, look at some videos on YouTube to understand how carbs work. After understanding that, you will only have to turn a nut to set the mixture.
    Its not difficult, but technical, and yes requires A LOT of patience. You will never get it right on first try so don't be disappointed if you don't. I was able to adjust my tappets properly on 5th or 6th try. It took me more time to understand the Carb's mixture. So be dedicated. Do it for the sake of your knowledge and understanding, as you are learning a skill. So try to learn it with a passion, if you can.
    Riders on the storm ... literally.
  7. #146
    abobobilly's Avatar
    Jul 2010
    1,359
    111 Post(s)
    4 Thread(s)
    Also, winters are here. On your next oil change, you should pour a 10W-40 instead. It'll keep your engine running more 'freely' in this cold (which is about to get even colder) weather.
    If you can bear the cost, Liquimoly's 10W-40 costs nearly Rs.1000 per 1L bottle. If you don't find it, then find some other 10W-40 instead, which should be much cheaper than that.
  8. #147
    Aug 2006
    Sialkot
    26
    6,132
    7
    49 Post(s)
    2 Thread(s)
    Sir sada petrole use kren.
    Cold starting ka masla hota hai hi octane....
  9. #148
    adeeljatoi's Avatar
    Jan 2015
    Multan
    23
    18
    waise iski tunning ki zarurat nai thi. just oil change krwatay rehtay. and find a good mechanic.
  10. #149
    Mar 2013
    Faisalabad
    30
    770
    10
    13 Post(s)
    Quote Originally Posted by adeeljatoi View Post
    Aqal Experience se ati hy aur Experience ki cost boht hoti hy
  11. #150
    Mar 2013
    Faisalabad
    30
    770
    10
    13 Post(s)
    Really hi-octane per cold start ka issue hota hy ya aap ka khyaal hy
    Q k ab tank mein nearly 90% normal petrol he hy
  12. #151
    Aug 2006
    Sialkot
    26
    6,132
    7
    49 Post(s)
    2 Thread(s)
    Bro maine hud hi octane use kia hai.
    And ye cold start mai tang krti hai....
  13. #152
    daniyal.jatoi's Avatar
    Dec 2013
    Multan
    27
    48
    Petrol Tank main jalti maachis ki teeli daal k try ki?
    Sag-e-Darr-e-Ahl-e-Bayt
  14. #153
    Dec 2013
    Multan
    27
    48
    Pra Jee, Mobil 1 use karo to batana. 20W-40, 20W50, ya 5W-50. Waiting to hear back from you.
  15. #154
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by aliarshad26 View Post
    Jitna ziada octane ka fuel Hoga utna ziada resist karega burn hone waqt cold start mai problem karega
  16. #155
    Aug 2006
    Sialkot
    26
    6,132
    7
    49 Post(s)
    2 Thread(s)
    Danyal bhai ap bht genuise hoge aur apk way of explanation se nzr b arha hai...
    Mgr apk sirf apne kie hue experience define kr rhe hai wo b bre khubsurat andaz mai.
    Kisi din apni bike k tank mai spark phenkna phir puchunga jalti hai k nai.
    Hard earned money se li hogi to aisi bat kbi nai kroge dobara....
  17. #156
    Aug 2006
    Sialkot
    26
    6,132
    7
    49 Post(s)
    2 Thread(s)
    Us bhai k bike k sirf seting ka masla hai...
    Mgr ap log hr bar koi na koi nai bat kr k unko confuse kr rhe ho....
    Tajarbe to neem hakim b krleta hai mgr wo hatra e jan hota hai....
  18. #157
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    Quote Originally Posted by daniyal.jatoi View Post
    what kinda nonsense comment is this
  19. #158
    Mar 2013
    Faisalabad
    30
    770
    10
    13 Post(s)
    Quote Originally Posted by amjad635 View Post
    Amjad brother why to be tensed
    words reflect One's personality
    let people say anything as they want
    you can never correct them all
  20. #159
    Dec 2013
    Multan
    27
    48
    Seriously! . Main nai to bike k tank main teeli laganay ko kaha tha. Lagta hai aap nai kahin aur laga li. There's a thing called sense of humor jo shayad aap main nahe. I won't bother answering your post again. Get a life bud.
  21. #160
    Aug 2006
    Sialkot
    26
    6,132
    7
    49 Post(s)
    2 Thread(s)
    Theres a realy thing called sense of humor and sense of humore if used at a perfect time and place is called sense of humor rest its called nonsense.
    Weather i have to get a life or no...
    Its not you who have to decide.
    Thank you for participating...
