Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
Like Tree7Likes
Thread: Yamaha yd-100 4 stroke overhaul
    faheemakbar18's Avatar
    Aug 2013
    Sadiqabad
    22
    684
    2 Post(s)
    Default Yamaha yd-100 4 stroke overhaul
    Aslam O Alikum guys, hope you are doing fine
    I have Yamaha 4 stroke yd-100 (simple not junoon). its 2009 model and has done 28k Km. I bought it slightly used (1km used)
    I would admit I didnt give it much care. oil changed very late. tuned very late. mean every maintenance was done late
    Now it has lost its luxury of pick and performance. kick would flip. clutch issue etc etc. and give bad smell when parked.
    my mechanic (Yamaha 1s center) has said this require immediate overhaul of full engine cost Rs 8500/- . clutch plates ring piston rod etc will be added . if I delay it it will cost more
    (He advised it last month for Rs 6500 and I delayed) today he quoted 8500 as more work is required now.
    even though i didnt much care it but isnt it too early for overhaul ? is it wise going for it or engine swap is better. how much would it cost
    anyone experienced overhaul please shed some light
  2. #21
    Aug 2013
    Sadiqabad
    22
    684
    2 Post(s)
    So i went for overhaul of engine, costed Rs 6450 including new backlight, 2 indicator rubber and covers, all locks replaced and mobil oil
    Now its break-in period
    He suggested for 1st 500km, keep it under 50 and then get it tuned/oil replaced
  3. #22
    saboor73's Avatar
    Oct 2013
    10,544
    25
    349 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by faheemakbar18 View Post
    What was replaced while rebuilt?
  4. #23
    Aug 2013
    Sadiqabad
    22
    684
    2 Post(s)
    seals
    ring piston kit
    valve set and seal
    mobile oil
    chain kit (internal)
    clutch plate
    2 other things cant remember name
    and baqi chota mota saman
  5. #24
    saboor73's Avatar
    Oct 2013
    10,544
    25
    349 Post(s)
    14 Thread(s)
    6
    25
    seals
    ring piston kit
    valve set and seal
    mobile oil
    clutch plate
    Be easy on clutch for 50-60 clutchs go on open road and gently touch 50km/h and deaccelerate to 10km/h (without pressing clutch) do it 3-4 for best break in
  6. #25
    Aug 2013
    Sadiqabad
    22
    684
    2 Post(s)
    for 50-60 clutches? didnt get that @saboor73
    this method of 50-10 looks fine, I ll try out tomorrow InshaAllah
    That mechanic was saying that the reason of your clutch plates going bad is you treat it like other bikes, yamaha clutch is very soft in yd100 engine, you rarely need to use it.
  7. #26
    saboor73's Avatar
    Oct 2013
    10,544
    25
    349 Post(s)
    14 Thread(s)
    6
    25
    In mechanic language "clutch per halka haat rakho" (be patients ride easy)
    About mechanic he is idiot I use to abuse heck out of my bike still my clutch lasted 45k km the usually point of clutch failure in pak is no break in of clutch BTW what engine oil you poured?
  8. #27
    Aug 2013
    Sadiqabad
    22
    684
    2 Post(s)
    dyl lube, my city is small and availability is the issue, caltex havoline was available in bigger packing and liquimoly wasnt even available
    pso was 20w50 as well. not generator 15w-40
  9. #28
    Aug 2013
    Sadiqabad
    22
    684
    2 Post(s)
    one thing the mechanic said, you can put load (2-3 people) in break in period, is it right
  10. #29
    saboor73's Avatar
    Oct 2013
    10,544
    25
    349 Post(s)
    14 Thread(s)
    6
    25
    No he is wrong
  11. #30
    hamikhan's Avatar
    Jun 2014
    Other
    1,259
    37 Post(s)
    Use zic M5 20W40 semi synthetic engine oil it is the best in all oils & price is only 270pkr for 700ml
  12. #31
    Aug 2013
    Sadiqabad
    22
    684
    2 Post(s)
    Quote Originally Posted by hamikhan View Post
    many pakwheelers said zic make bike engine heatup and loose power
  13. #32
    Aug 2013
    Sadiqabad
    22
    684
    2 Post(s)
    Quote Originally Posted by saboor73 View Post
    followed this technique for 4 times
    now bike just need a signal and it go like rocket.
  14. #33
    saboor73's Avatar
    Oct 2013
    10,544
    25
    349 Post(s)
    14 Thread(s)
    6
    25
    Good to hear that you are enjoying your bike
