Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By mfaizandawood
Thread: Yamaha YD-125 engine replacement with 200CC engine
    Newbie Follow
    qayyumabid44's Avatar
    May 2016
    Default Yamaha YD-125 engine replacement with 200CC engine
    I want to change my Yamaha YD-125 engine with new 200cc engine to get better speed and performance. Will it work? and will I have to change some other parts as well? What will be the expected cost with used or new engine?
    Need Suggestions pleaseYamaha YD125 engine replacement with 200CC engine -1683330
    mfaizandawood's Avatar
    Feb 2015
    Gujranwala
    273
    yes ur bike have the same fitting as cg, deluxe and piaggio and yes u can swap a bigger engine in it easily, not much changes are required just carb and if u want better water cooled engine than a radiator with fitting is a job to do that's it
    And yes @vickytulla can help u in engine matters.
    https://www.facebook.com/bikemodifiersclub/
    vickytulla's Avatar
    Oct 2009
    8,418
    38
    876 Post(s)
    31 Thread(s)
    I think he called I shared him the details..
    Quote Originally Posted by mfaizandawood View Post
