Results 1 to 4 of 4
Thread: Big rear tire for my yamaha ybr
    fastkhan's Avatar
    May 2010
    Peshawar
    29
    11
    Default Big rear tire for my yamaha ybr
    Hello pakwheelers
    I want to change the rear stock tire with fat (bigger tire) to my yamaha ybr as the current stock tire is killing the look but i confused about the size tire. Plz anyone tell me max allowable tire size (rear tire) for my motorcycle. And plz also suggest which brand should i go for?
    Sent from Samsung galaxy tab 3 using Tapatalk
    post911's Avatar
    Jul 2012
    Other
    189
    3 Post(s)
    I think instead of getting a fatter look,
    U should go for Panther rear tyre which is around 1650rs,
    The benefit of switching from stock ybr servis rear tyre to Panther tyre will be significant in terms of
    More traction while turning,
    Cause Panther rear tyre design is more grippy as compared to shitty design of stock ybr rear tyre.
    Last but not least
    The Panther tyre has 6ply belt around the edges which I believe is not the case with stock shitty ybr servis tyre.
    Getting a fatter tyre will give u trouble with the chain guard,
    U might end up taking the chain guard off just to accommodate the fatness of wider tyre.
    a4anees's Avatar
    Jan 2016
    95
    The maximum size you can put on is 120-90 but you have to remove the chain cover & it will decrease the top speed too.
    Sent from my GT-I9100 using PW Forums mobile app
    I dont talk much because my bike's engine do it for me.
    umerchaudhary's Avatar
    Apr 2007
    32
    1,203
    4 Post(s)
    2 Thread(s)
    Quote Originally Posted by post911 View Post
    Last but not least
    Servis tyre is 6ply too.
