Results 1 to 7 of 7
Thread: YBR-G First Oil Change
    ahm2303's Avatar
    Jul 2016
    21
    2 Post(s)
    Default YBR-G First Oil Change
    I have heard that first oil should be done after 300 kMs but the owner manual says first oil change should be done after 1000 KMs. So, for whom should I go for owner manual or mechanic's saying ???
    hassantahir2's Avatar
    Mar 2016
    Faisalabad
    22
    812
    17 Post(s)
    ^ Go for oil change at 300KM that's the correct time to change the oil on a new engine.
    Sent from my D2502 using PW Forums mobile app
    Four wheels move the body
    Two wheels move the soul
    ahm2303's Avatar
    Jul 2016
    21
    2 Post(s)
    Any reason ??? I mean why Yamaha recommend to change after 1000 KMs
    And which oil should I use ?
    abdulrehmanrauf's Avatar
    Oct 2009
    33
    770
    31 Post(s)
    Bro @ahmer2303 ask yourself and then decide.
    As a layman, I only know that first 300 kms are the most critical part for an engine life. Major proportion of engine parts grinding is being done in this time, so I ask myself whether I should allow these grind tiny particles in engine till 1000 kms or I should lose some bucks and drain them out with a fresh oil.
    Plus I think the guide book comes with bikes mostly follow Japanese standards and you know these bikes have to bear much extreme conditions here in Pakistan.
    Quote Originally Posted by ahmer2303 View Post
    Bara CG-125 bana phirta hai jou Sprinter say derta hai ....
    ahm2303's Avatar
    Jul 2016
    21
    2 Post(s)
    Okay so which oil is suitable yamalube or something else ??
    Quote Originally Posted by abdulrehmanrauf View Post
    Oct 2009
    33
    770
    31 Post(s)
    Within warranty I think you should stick to Yamalube...after its expiration...
    Any good brand may be Zic M7, Shell, Valvoline incase you find it, Liqui Moly but it is too costly now, with grade of 10W-40 only...a big no to 20W-50. Your bike engine is brand new.
    ahm2303's Avatar
    Jul 2016
    21
    2 Post(s)
    Okay Thanx Bro
Tags for this Thread
