Results 1 to 6 of 6
Thread: YBR odo-meter accuracy issue
    ahm2303's Avatar
    Jul 2016
    21
    2 Post(s)
    Default YBR odo-meter accuracy issue
    Hi
    I have bought ybr-g few days ago now it is 600 km driven almost. I have noticed that odo-meter is showing more speed than the actual bike speed so I compared it with the GPS speedometer with different apps there is a difference of about 7-8 points at higher speeds. So anyone have faced the same issue and should I claim the odo-meter or do something else ?
    rxlover's Avatar
    Apr 2016
    43
    Brother could you clarify that is the issue in speedometer or odometer?
    Sent from my LG-D800 using PW Forums mobile app
    rxlover's Avatar
    Apr 2016
    43
    Speedometer shows speed while odometer shows distance travelled.
    rxlover's Avatar
    Apr 2016
    43
    If you are talking about speedometer, then it is normal for bikes to have +-10 % error in speedometer(mostly speedometer show more than the actual speed)
    ahm2303's Avatar
    Jul 2016
    21
    2 Post(s)
    Sorry, Issue is in speedometer and it is almost of 7 points. GPS shows 90kph and speedometer shows 96 or 97, So does it need to be changed, I don't think so that every meter has this much difference???
    asjdsm's Avatar
    Apr 2009
    30
    3,470
    57 Post(s)
    3 Thread(s)
    Quote Originally Posted by ahm2303 View Post
    Almost sab ma itna hi difference ha.
    Mechanical device ha at higher speeds their accuracy deteriorate
    Sent from my Nexus 5 using Tapatalk
