Page 2 of 10 FirstFirst 1234 ... LastLast
Results 21 to 40 of 181
Thread: YAMAHA Bikes ki BAADSHAH company
    JustFarooq's Avatar
    Apr 2006
    Faisalabad
    33
    1,037
    29 Post(s)
    Default YAMAHA Bikes ki BAADSHAH company
    i like YB-100 very much but due to 2 stroke its ignored otherwise its best bike ever made by any company i drove my yb100 across 100km/h many times sometimes it goes upto 120km/h n i bet no bike is like that its road grip is amazing its pick is more than any road bike brake wise its good in short its a great bike in every aspect instead fuel economy n one thing i forgets that its time of reaching from 0 to 100km/h is just 5-6 sec.But we sold that bike.kaafi puraani ho gai thi isliye.. now i m planing to buy junoon plz give me ur comments abt this bike bcos i like yamaha bikes very much Bikes ki BAADSHAH company jo hai if any body have pics n specification of that bike i.e junoon then plz post it here ill wait. thanx in advance
    ALLAH U MMA SALLE ALAA MUHAMMADIN WA BAARIQ WASALLAM
  2. #21
    air_explorer's Avatar
    Aug 2005
    31
    1,316
    @farooq, add me duke277@hotmail.com
    thanx
    Valle!! the great with his YZRM1 looks more coool!
  3. #22
    xtremist's Avatar
    Jan 2005
    27
    777
    Junoon is a good bike and almost VIBRATION LESS...very smooth...but way way overpriced...just for some plastic on it...you can also consider SPrinter in this regard...its more fuel efficient and more powerful but not soo sexy looks...but still ok...and its for just Rs 54800
    and if you can add 4k more to ur junoon budget i.e approx 64k, then just buy a GS 125 which is 5 speed and theres no match for junoon...think abt it..
    btw heres a comparison of sprinter,junoon and Cd 100:-
    SPRINTER:-
    Specification:
    Engine Type 4 Stroke, Air Cooled, Single Cylinder, OHC
    Displacement 109 cm3
    Bore x Stroke 53.5mm x 48.8mm
    Compression ratio 9.6 : 1
    Carburettor MIKUNI BS22, Single
    Starter System Kick
    Transmisson 4 Speed Constant
    Air cleaner Polyuretnane foam emelent
    Cluctch Wet Multi Plate type
    Primary Reduction 3.666 (77/21)
    Final Reduction 2.500 (35/14)
    Idle Speed 1,500 -+100r/min
    Frame Type Sigle Backbone
    Drive Chain 428, 102 links
    Caster Trail 26/67 mm
    Suspension Front Telescopic coil spring, oil damped
    Suspension Rear Swinging arm coilspring
    Brake Front drum
    rear drum
    Overall length 1,900mm
    Overall width 755mm
    Overall height 1050mm
    Wheelbase 1225mm
    Ground Clearance 165mm
    Dry Mass 119KG
    Tire front 2.50 -6PR tube
    Tire rear 2.75 - 6PR tube
    Fuel Tank 10.5 Litre
    Ignition type Electronic Ignition (CDI)
    Ignition timing 10 BTDC at 1,500 rpm
    Dry Weight 91kg
    Battery 12v9
    JUNOON:-
    Specification:
    Engine: 4 stroke OHC
    Displacement: 97.1cm3
    Bore and Stroke: 50 x 49.5mm
    Compression Ratio: 9.0:1
    Fuel Consumption: 55 KM/L
    Transmission: 4 speed constant mesh
    Starting: Kick starter
    Frame: Backbone
    Ground Clearance: 160mm
    Dry Weight: 86KG
    HONDA 100:-
    Specification:-
    Engine 4stroke OHC cooled by air
    Displacemnt 97.1cm3
    Bore*Stroke 50*49.5
    Compression Ratio 9.0:1
    Clutch Weight contains different plate
    Transmission Continous 4 speed mesh
    Starting Kick starter
    Frame Double craddle tubler type
    Measurement 1983*735*1045mm
    Ground Clearance 160mm
    Tyre at front 2.75-18 6 PR
    Tyre at back 2.75-18 6 PR
    Dry Weight 98KG
    Da OnE aT iTz XtReMez....
  4. #23
    Aug 2005
    31
    1,316
    Yamaha Junoon specs from my side,
    YAMAHA Bikes ki BAADSHAH company -692122
  5. #24
    Aug 2005
    31
    1,316
    @farooq ,yeah right as xtremist said "and if you can add 4k more to ur junoon budget i.e approx 64k, then just buy a GS 125 which is 5 speed " and then keep searching for its spare parts & sell it with a huge loss,right?
    thanx
  6. #25
    JustFarooq's Avatar
    Apr 2006
    Faisalabad
    33
    1,037
    29 Post(s)
    @ exteremist
    bhai realy its a junk bike i.e. jisko dekhne ko dil na kare usko drive karne ka kia maza?batao
  7. #26
    Aug 2005
    31
    1,316
    lol @ jisko dekhne ka bhi dil na kare.good going farooq.
  8. #27
    xtremist's Avatar
    Jan 2005
    27
    777
    @ air explorer!
    yaar in specs ko parhnay k liyay magnifying glass bhi dena tha bhaya!!
    @ farooq!
    go and ask some guy with enuff knowledge of bikes...u think LOOKS are everything? let me tell you one thing more dude...YAMA 4 stroke and junoon have nothing to separate except body...when YAMA4 got flopped,yamaha introduced Junoon with a very good looking body...if the engine is so strong,then why was YAMA4 not selling?
    and about GS 125,bro this bike has very good looks...dont say that...atleast better looking than CG 125..
    i just gave you my opinion and ppl who know abt that bike will certainly prefer it...even i think GS 125 is better than CG 125..here are specs of GS 125
    Engine Type 4 Stroke Air Cooled, OHC
    Bore 57mm (2.24 in)
    Stroke 48.8mm (1.921 in)
    Compression ratio 9.3 : 1
    Starter System Kick
    Transmisson 5 Speed Constant Mesh
    Overall length 1945mm (76.6 in)
    Overall width 780mm (30.7 in)
    Overall height 1035mm (40.7 in)
    Wheelbase 1270mm (50 in)
    Ground Clearance 170mm (6.7 in)
    Dry Mass 115 KG
    Tire front 2.75 -1B 42p
    Tire rear 3.00 - 1B 47p
    Fuel Tank 12 Litre
    Drive Chain RK428 FDZ, 116 links
    Battery 12v, 14.4KC
    Front Suspention Telescopic, Coil Spring, Oil damped
    Rear Suspention Swing arm, Coil Spring, Oil damped
    Head Light 12V 35/35 W
    Brake Light 12V 21/5 W
  9. #28
    Aug 2005
    31
    1,316
    @xtremist, i didnt upload those specs for you,you can only see sprinter nothing else
    n tell me one thing,who told you that Yamaha released that Junoon bcoz their YAMA4 got flopped,name that person plizz & also elaborate A GUY WITH ENUFF KNOWLEDGE .
    & last,farooq said JISKO DEKHNE KA DIL NA CHAHE,about sprinter.
    thanx
  10. #29
    xtremist's Avatar
    Jan 2005
    27
    777
    ohh ok....my bad...i thought he gave these remarks abt GS 125..
    btw yaar abt YAMA 4 , how many of those do you see on roads? was that a success? i dont think so.!!!
    and Sprinter's shape isnt that bad...ppl say this bcoz now we have got a sexy competitor in shape of junoon...otherwise sprinter's shape is good (excpet headlight,i know it looks a bit ugly)...but look at specs...engine wise sprinter is far better
  11. #30
    JustFarooq's Avatar
    Apr 2006
    Faisalabad
    33
    1,037
    29 Post(s)
    @ exteri
    bhai aap se kis ne kaha k gs125 ki look achi hai bhai g kuch to hosh k naakhun lo kon si apni alag hi dunya bassa rakhi hai ap ne bhai g koi nahi kehta k yama 4 flop hai markeet ka visit karo to tum ko pata chale ga k sprinter ki sale ziada hai ya yama 4 ki junoon to bohat aage hai in sab k pehle yama 4 se hi maqaabla kar k dekho main poochta hoon kon c kami hai junoon main if u know just one thn plz reply here then ill show u about sprinter kitni kharaabian hai us main
  12. #31
    Aug 2005
    31
    1,316
    @xtremist,yar did u say that GS125 is better than CG125 or GS125 is better than CG125 Deluxe?
    thanx
  13. #32
    xtremist's Avatar
    Jan 2005
    27
    777
    @ farooq!
    bro look at the specs...Sprinter has bigger compression ratio which means taller gear ratios...ok?
    2ndly sprinter is far cheaper than junoon...junoon for abt 63-64k and sprinter for abt 54800Rs..
    3rdly sprinter has almost an equal mileage to that of 70..it gives 60-65km/liter and junoon gives 50-55 km/liter...
    in shape yes i think junoon is better....and in ENGINE smoothness too ,junoon wins..
    in road grip,both are , i think equal...
    @ air
    bro my friends own 3 of these 125s....GS 125,CG 125 and Deluxe...we have tested all...Suzuki 125 has better pick than Dluxe but almost equal to CG 125....but has a good top speed..well i'd personally prefer it due to 5 speed function.and OHC engine...
  14. #33
    Aug 2005
    31
    1,316
    @xtremist,i have personally tested GS125,GS150 but still I'd prefer CG125 or CG125 Deluxe for sure,keeping in mind the performance,resale,spare parts,maintenance issue.
    thanx
  15. #34
    JustFarooq's Avatar
    Apr 2006
    Faisalabad
    33
    1,037
    29 Post(s)
    @ exteri
    one of my friend have junoon i drove it then i came to know that junoon rox baaqi sab bakwaas hai it gives him abt 60+ milage rahi qeemat ki baat to pehle sprinter ki qeemat bhi junoon k lagh bhag thi but they reduced the prices due to bad selling but yaha still keep its prices log paagal to nahi yaar jo junoon purchase kar rahe hain n its selling like hot cake in de markeet in multi colours
  16. #35
    Aug 2005
    31
    1,316
    @farooq yamaha junoon is no doubt a complete package with respect to looks,performance & maintenance,Junoon is worth of what it costs.
    I have been noticing a rapid increase in number of Junoons here in Karachi,where people are afraid to buy new japanese bikes.
    thanx
  17. #36
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    @air explorer...
    bhai ye jo bike meray avator main hay ye sale ho jaye to purana R6 hi lenay k chakar main houn...and yes i have fridden them both for a quite period of time
    >>Time Doesnt Heal Wounds...A Kawasaki ZX-6R does <<
  18. #37
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    correction to my last post...i have ridden R6 for some time
  19. #38
    Aug 2005
    31
    1,316
    @foosa ,allright,but dont say that except R1 & R6 ,nothing can be called a bike.
    thanx
  20. #39
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    i was talking about yamahas only...there are better bikes than R6 and R1 like the suzuki gsxr-750 and honda fireblade...far better then both of them...but in yamahas i only like R6 and R1
  21. #40
    Aug 2005
    31
    1,316
    @foosa,bhai most people are desirous to occupy sport bikes ,but they can't due to our local circumstances,thaswhy we have been trying to figure out the better one released here in local market.
    thanx
