Engine
Type 998cc, liquid-cooled, 16-valve, DOHC, inline four-cylinder
Bore x Stroke 77 x 53.6mm
Compression Ratio 12.7:1
Carburetion Fuel Injection with YCC-T and YCC-I
Ignition Digital TCI
Transmission 6-speed w/multi-plate slipper clutch
Final Drive #530 O-ring chain
Chassis
Suspension/Front 43mm inverted telescopic fork w/adjustable preload, compression damping, rebound damping; 4.7" travel
Suspension/Rear Single shock w/piggyback reservoir; adjustable for hi-/lo-speed compression damping, rebound damping, spring preload; 5.1" travel
Brakes/Front Dual 310mm discs; radial-mount forged 6-piston calipers
Brakes/Rear 220mm disc w/single-piston caliper
Tires/Front 120/70-ZR17
Tires/Rear 190/50-ZR17
Dimensions
Length 81.1"
Width 28.3"
Height 43.7"
Seat Height 32.9”
Wheelbase 55.7”
Rake (Caster Angle) 24.0°
Trail 4.0”
Fuel Capacity 4.75 gal.
Dry Weight 390 lbs.
source : wikipedia
