[highlight]UPDATE..
R15[/highlight]
Passing on the âR seriesâ DNA
- Humachine Technologies & Sensual Racing Form -
The YZF-R1 and YZF-R6 are equipped with under cowls that are based on the image of a diffuser, to give them the best form for aero-management. These are not cowls for simply enclosing the engine, but forms composed of blade surfaces that actively control airflow. This spirit has been directly inherited by the YZF-R15.
âHarmony between rider and machine.â YAMAHA's Human Technology involves studying the form of the motorcycle actually in motion with the rider on it. The R series is the embodiment of 1) a wide frontal space that protects the rider, 2) an easy to ride seating area that gives riders the freedom of movement and allows them to steer effectively, 3) the glamorous tail treatment that takes into account the management of airflow behind the rider, and 4) a sensual racing form that brings all 3 of these elements together in a harmonious package. These characteristics have been splendidly reproduced in the YZF-R15.
Additionally, the designs were developed in the same modeling room where YZF-R1 designers worked. Information was shared, ensuring that the R lineage would be transmitted. In addition, the model also incorporates a multitude of adjustments for the Indian market including seat shape that allows for tandem riding (integrated with the main seat), tandem grips that are easy to grip and also contribute to the supersport design, and a riding position that takes into account comfort, etc. In other words, the YZF-R15 is characterized by a hybrid design that combines the world-class design of the âRâ series with localized functions. The YZF-R15 was created to lead the supersport category in India.
Specs:
Drawing on 10 years of YZF series development with a new fuel-injected engine and Deltabox frame The new YZF R15 invites you to âenjoy ridingâ
Engine:
Engine type Liquid-cooled, 4-stroke, SOHC, 4-valve
Cylinder arrangement Single cylinder
Displacement 149 .8cc
Bore x Stroke 57Ă58.7mm
Compression ratio 10.4:1
Maximum power 17PS / 8,500rpm
Maximum torque 15 N.m / 7,500rpm
Starting system Electric Start
Lubrication wet sump
Engine oil capacity 1.0 liters
Fuel tank capacity 12 liters
Fuel supply system Electronic fuel injection
Ignition system T.C.I
Primary / Secondary reduction ratio 3.042 / 3.000
Clutch type Constant-mesh wet multi-plate
Transmission type Return type 6-speed
Gear ratios 1st=2.833, 2nd?1.875, 3rd:=1.364,
4th=1.143, 5th=0.957, 6th=0.84
Chasis
Frame type Deltabox Frame
Caster / Trail 26° / 100mm
Tire size (Front / Rear) 80/90-17 / 100/80-17
Brake type (Front / Rear) Hydraulic, single disc (Front / Rear)
Suspension type (Front / Rear) Telescopic / Linked type Monocross
Headlight 12V35W / 35W?35W
Dimensions
Overall length x width x height 1,995mm x 670mm x 1,070mm
Seat height 790mm
Wheelbase 1,290mm
Minimum ground clearance 160mm
Dry weight / Curb weight 120kg / 131kg
