Results 1 to 12 of 12
Like Tree2Likes
  • 2 Post By LEDLIGHTMAKERZ
Thread: 2009 Yamaha R1
    Ducati's Avatar
    May 2008
    Johannesburg
    86
    5,444
    4 Post(s)
    Default 2009 Yamaha R1
    Yamaha's 2009 YZF-R1 sports flagship made its world debut this week in a glittering presentation in front of 3000 Yamaha US dealers at the famous Mirage Hotel in Las Vegas.
    It's scheduled for South African release at the end of the first quarter of 2009 but Yamaha SA is unsure at this stage of pricing or which colours we'll get.
    All four Yamaha MotoGP riders - Valentino Rossi, Jorge Lorenzo, Colin Edwards and James Toseland - took part in the launch, each riding a different colour bike on to the stage and being interviewed about its relationship to the YZF-M1 MotoGP machineA 'big bang' engine combines the torque of a twin with the top-end rush of a four.
    And that starts with its crankshaft. The 2009 R1 is the first road bike with a crossplane crankshaft, which has its con rods are spaced at 90 degrees instead of the traditional 180 degrees, with uneven firing intervals of 270, 180, 90 and 180 degrees.
    The result is what's called a "big bang" engine, with a more linear power delivery than a conventional "screamer" engine, combining the low and mid-range torque of a twin with the hard-revving top-end rush of a four-cylinder engine.
    Yes, it's more difficult (read expensive) to make and yes, it causes some odd vibrations but a coupling-type balancer that rotates in the opposite direction to the crankshaft takes care of the latter.
    It's fed by Yamaha's fly-by-wire, chip-controlled electronic fuel injection with 12-hole, piezo-electronic injectors on variable-length intake manifolds to broaden the spread of power even furtherThe rider can set the bike's engine response to suit the riding conditions - on the fly.
    New for 2009, however, are selectable mappings – as on the 2007 Suzuki GSX-R1000 - that allow the rider to set the bike's engine response to suit the riding conditions – on the fly, at the press of a button on the handlebars.
    The "A" mode chops the top off the power delivery but delivers sportier engine response in the low to mid-range. "B" mode softens the throttle response throughout the range for wet or gravel roads (or for heavy traffic!) and the "C" mode unleashes the full monty - 133.9kW at 12 500rpm and 115.5Nm at 10 000, according to Yamaha.
    The frame has been revised for maximum rigidity in the vertical plane with a predetermined amount of lateral flex and is welded from a combination of pressure diecast, stamped and gravity cast components. The bolt-on rear sub-frame is a one-piece, magnesium-alloy die-casting.
    New MotoGP-spec SOQI front forks separate the compression and rebound functions. The left side handles compression damping and the right, rebound, each sepataely adjustable. The 2009 R1 is also the first with a factory-fitted electronic steering damper.
    The new bodywork is, unexpectedly, plainer and smoother than the previous model, with less fussy little creases, corners and colour changes.
    Instead of the previous model's four headlights the 2009 model has only two, round projector lights with hemispherical lenses, mounted in the ram-air ducts – which makes the fairing considerably narrower and more pointed.
    Whether it will make the bike faster will have to be investigated in a wind tunnel – but it looks more streamlined.
    -Allah meherban tau gadha pehlwan
    Ducati's Avatar
    May 2008
    Johannesburg
    86
    5,444
    4 Post(s)
    Some pictures..........
    2009 Yamaha R1 -872237
    2009 Yamaha R1 -872238
    2009 Yamaha R1 -872239
    Ducati's Avatar
    May 2008
    Johannesburg
    86
    5,444
    4 Post(s)
    And finally the technical specs..........
    Engine: Liquid-cooled four-stroke transverse four.
    Capacity: 998cc.
    Bore x stroke: 78 x 52.2mm.
    Compression ratio: 12.7:1.
    Valvegear: DOHC with four titanium valves per cylinder.
    Power: 133.9kW at 12 500rpm.
    Torque: 115.5Nm at 10 000rpm.
    Induction: Electronic fuel-injection chip-controlled throttle and intakes.
    Ignition: Transistor-controlled electronic.
    Starting: Electric.
    Clutch: Cable-operated multiplate wet slipper clutch.
    Transmission: Six-speed constant-mesh gearbox with final drive by chain.
    Suspension: 43mm inverted cartridge forks adjustable for preload with adjustable compression damping in left leg and adjustable rebound damping in right leg, monoshock adjustable for preload, compression and rebound damping at rear.
    Brakes: Dual 310mm discs with radial mount six-pot opposed piston callipers at front, 220mm disc with single-piston floating calliper at rear.
    Tyres: Front: 120/70 - ZR17 tubeless. Rear: 190/55 - ZR17 tubeless.
    Wheelbase: 1415mm.
    Seat height: 833mm.
    Fuel capacity: 18 litres.
    Kerb weight: 206kg.
    whisky's Avatar
    Jan 2006
    28
    2,201
    6 Post(s)
    That's 179.5 Horsepower!
    My engine history; CB70 -> 4EFTE -> D15B VTEC -> D16Y6 VTEC -> 1JZ-GTE
    mamehmood's Avatar
    Sep 2008
    702
    R15 is also launched in India
    that is 150cc
    muhammadasifmehmood@yahoo.com
    Cell#: 0300-4007480
    mamehmood's Avatar
    Sep 2008
    702
    Yamaha Motor Co., Ltd. announces the debut of the new YZF-R15, a new supersport model mounting a newly designed 150cc liquid-cooled, 4-stroke, SOHC single-cylinder, 4-valve fuel-injected engine on a Deltabox frame. It will be displayed for the first time at 9th Auto Expo – 2008 (Organizer Confederation of Indian Industry; Venue: Pragati Maidan) in New Delhi from January 10 (Thursday.) to 17 (Thursday.)
    Packed full of state-of-the-art technologies, the new Yamaha YZF-R15 boasts performance worthy of a supersport model and a body design that evokes the image of the YZF-R series and gives visual expression to the quality of its ride. It is truly an embodiment of Yamaha’s desire to bring customers a model to help them Enjoy riding.
    In Yamahas new medium term (3-year) management plan that begins this year and runs through 2010, rebuilding the Yamaha motorcycle business in India has been designated as one of top priorities.
    The new YZF-R15 now being unveiled is an example of the objective of introducing attractive new products called for in Yamahas high value-added marketing strategy for India business, and plans call for it to be released on the market in the middle of this year.
    Main Features
    (1) A newly developed 150cc liquid-cooled, 4-stroke, SOHC, single-cylinder fuel-injected engine
    (2) An all-aluminum DiASil Cylinder produced by an exclusive Yamaha casting technology
    (3) Eco-friendly performance that clears the next-phase Bharat 4 emissions standard
    (4) The Deltabox frame known for excellent rigidity balance
    (5) Impressive 2-eye multi-reflector headlight design in the YZF-R series image
    * Tyre Front: 80/90 - 17 inch tubeless
    * Tyre Rear: 100/80 - 17 inch tubeless
    * Brakes: Front- Disc, Rear- Disc
    * Fuel Tank: 12 Litres
    * Wheelbase: 1290 mm
    * Min Ground Clearance: 160 mm
    2009 Yamaha R1 -872418
    Cell#: 0300-4007480
    mamehmood's Avatar
    Sep 2008
    702
    here are more pics
    2009 Yamaha R1 -872419
    2009 Yamaha R1 -872420
    2009 Yamaha R1 -872421
    Cell#: 0300-4007480
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    sweet mother of yamaha ...those are some pretty impressive stats...180 BHP ...now that is powerfull indeed...suzuki will have to fight for its money now
    >>Time Doesnt Heal Wounds...A Kawasaki ZX-6R does <<
    kingabsar's Avatar
    Jun 2006
    34
    41
    2009 r1 z 183bhp without ram air and means more with ram air the 2008 model was 180bhp now in coming future yamaha will introduce vmr and vmn 1400cc sports bike to compete with hayabusa
    _9B7_PakWheels(com).jpg]2009 Yamaha R1 -872978
    mahamza86's Avatar
    Jul 2006
    Multan
    30
    942
    My dear FOOSA
    Suzuki GSXR1000 Already produces more than 180BHP and Weights just 174KG
    Now Yamaha has to Struggle
    Living in Denial
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    yea...but suzuki gsxr is...dorky looking...at least the R1 has some style
  12. #12
    LEDLIGHTMAKERZ's Avatar
    Sep 2012
    245
    7
    12 Post(s)
    Thumbs up Yamaha r1 cat eyes
    Asalaam alaikoum Brothers, just wanted to share my work i just did on a Yamaha R1 headlight n the speedometer
    Tanzeel Rehman
    LEDLIGHTMAKERZ
