Results 1 to 14 of 14
Thread: 2009 Yamaha R6
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    Default 2009 Yamaha R6
    hey guys ...some pics of the 2009 Yamaha R6 ...im still struglling to find the specs...if anyone finds them plz post them here
    2009 Yamaha R6 -560005
    2009 Yamaha R6 -560006
    2009 Yamaha R6 -560007
    2009 Yamaha R6 -560008
    2009 Yamaha R6 -560009
    >>Time Doesnt Heal Wounds...A Kawasaki ZX-6R does <<
    Naveed4speed's Avatar
    Aug 2006
    Sialkot
    26
    6,130
    7
    49 Post(s)
    2 Thread(s)
    looks kool:p
    speces?
    FXXB and EJ8 on its way............
    sam007's Avatar
    Feb 2008
    Dubai
    26
    3,524
    8 Post(s)
    here u go...........the SPECS:
    Engine: 599 cc (36.5 cu in), liquid cooled, 4-stroke, forward inclined inline 4 cylinder, DOHC, 16-titanium valves
    Bore & Stroke: 67.0 mm x 42.5 mm
    Compression Ratio: 13.1:1
    Carburetion: Fuel Injection w/ YCC-T and YCC-I
    Ignition: TCI
    Transmission: 6-speed w/multi-plate slipper clutch
    Final Drive: #525 O-ring chain
    Suspension Front: 41 mm (1.6 in) inverted fork; 4-way adjustable, 4.7 in (119.4 mm) travel
    Suspension Rear: Single shock; 4-way adjustable, 4.7 in (119.4 mm) travel
    Brakes Front: Dual 310 mm (12.2 in) floating discs w/radial mount, forged 4-piston calipers
    Brakes Rear: 220 mm (8.7 in) disc w/ single-piston caliper
    Tires Front: 120/70-ZR17
    Tires Rear: 180/55-ZR17
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    I would like to know the difference between the CDI and TCI ignition. Can anyone put some light on it?
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
    imranbhatti's Avatar
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    @7thgear
    CDI satnds for capacitive discharge ignition System While TCI represents some version of Transitorised ignition system might be Trasisitor control ignition or Transisitor coil ignition.
    Exploring Machines is my Passion...
    mahamza86's Avatar
    Jul 2006
    Multan
    30
    942
    @7th Gear
    Goto howstuffworks.com
    and go to auto part and search all the desired tech
    Living in Denial
    sal
    sal is offline
    sal's Avatar
    Dec 2004
    36
    601
    18 Post(s)
    front is a little changed.. still no projection headlamps like R1 :-(
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    yes...i was xpecting to be more like the new R1...but they only changed the front end...thats it
    sunny234's Avatar
    Aug 2005
    29
    6,976
    7 Post(s)
    2 Thread(s)
    nice pics.
    helliceo's Avatar
    Mar 2005
    Rawalpindi
    24
    3,334
    aala..........(y)
    Saad Akhtar Khan...
    cowboys's Avatar
    Apr 2008
    Rawalpindi
    29
    378
    beauty!!
  12. #12
    Khubi's Avatar
    Mar 2008
    Multan
    30
    86
    SUTHRA DANA
  13. #13
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    ^Kya baat hay yaar!! :-)
  14. #14
    umar219's Avatar
    Jul 2008
    27
    206
    superb...new design in bikes industry
