here u go...........the SPECS:
Engine: 599 cc (36.5 cu in), liquid cooled, 4-stroke, forward inclined inline 4 cylinder, DOHC, 16-titanium valves
Bore & Stroke: 67.0 mm x 42.5 mm
Compression Ratio: 13.1:1
Carburetion: Fuel Injection w/ YCC-T and YCC-I
Ignition: TCI
Transmission: 6-speed w/multi-plate slipper clutch
Final Drive: #525 O-ring chain
Suspension Front: 41 mm (1.6 in) inverted fork; 4-way adjustable, 4.7 in (119.4 mm) travel
Suspension Rear: Single shock; 4-way adjustable, 4.7 in (119.4 mm) travel
Brakes Front: Dual 310 mm (12.2 in) floating discs w/radial mount, forged 4-piston calipers
Brakes Rear: 220 mm (8.7 in) disc w/ single-piston caliper
Tires Front: 120/70-ZR17
Tires Rear: 180/55-ZR17
