Dear Pakwheel members,
I am facing transmission problem with Toyota Surf-94 (1Kz Engine).
The gear shifting is bit late. Normally first two gears shifts properly and rapidly but third jeep shifts into third gear at around 3000 RPM on 60-70 km/hr and subsequent gears shift late also on high RPM's.
Reverse gear was also very weak, it's really difficult to reverse if there is even a brick behind rear tyre, and jeep start moving in reverse gear at around 3000 RPM's.
Got it electrical checked from Arshad-Sultan ka khoo and there is considerable difference after he fixed some electrical cables both in the front late transmission, and reverse gear. But still not very good.
Mechanic suggested me to change the stock transmission with kabli one.
Respectable fellows, pls suggest what should I do as this being my first 4x4. Bit afraid swapping to kabli transmission which can prove to be a Pandora box and i ll become shuttle **** between mechanics. Or suggest some good electrician in Isb/Rwp who can perform a thorough check.
thanks.
