Results 1 to 13 of 13
Thread: Pak suzuki alto AC
    Muhd_saddique's Avatar
    Nov 2005
    43
    89
    Default Pak suzuki alto AC
    Dear Pakwheelers,
    How i clean the inner unit of alto AC. Its 2009 model. Its colling has become decreased but blow of air is ok. Its only driven 10,000km. I already service its front condensor. Is this some AC filter issue and Is waranty also covers such issue.
    aomair's Avatar
    Apr 2005
    575
    Have your a/c gas checked.
    Change of faces won't change anything in Pakistan. www.greenwood.pk
    suzukialtomehran's Avatar
    May 2005
    Sargodha
    25
    6,967
    11 Post(s)
    1. Check your cars ac gas and any leaks.
    2. Always use blinds for better results.
    3. Dont compare your ac with other cars even dont compare with cultus or coure bcoz they had separate fans for condenser and alto has just 1 fan for cooling and for AC.
    Two of the best quotes of Punjabi : 1. Rull tan gae aan! Per Chass aa Gae ai!, 2. Gal Pya Dhol Ty Wajana Penda ay.
    osama96's Avatar
    Jun 2008
    Riyadh
    24
    2,601
    Quote Originally Posted by suzukialtomehran View Post
    Agreed but ac of alto is very good within class.
    Beshak ALLAH he sy hy sub waqt sy pehly nahin zarorat sy zada nahin.
    mohsinhp's Avatar
    Mar 2010
    Zanzibar
    34
    491
    Quote Originally Posted by osama96 View Post
    +1
    daniyalahmad's Avatar
    Jun 2009
    Select City
    8,406
    10 Post(s)
    +2
    @OP
    Check the AC gas, If it needs refilling then get it done.
    Check for any leakage.
    Since its a 2009 model and you already had your condensor serviced so I dont think it needs any service for the time being.
    One of the most difficult things in the world is to know how to do something, and to watch without comment, somebody else do it incorrectly.
    Jun 2009
    Select City
    8,406
    10 Post(s)
    Quote Originally Posted by Muhd_saddique View Post
    Dear Pakwheelers,
    Inner unit consists of just the blower and the evaporator box which can be serviced.
    All the other components which mainly need service are in the engine bay.
    Xulfiqar's Avatar
    Aug 2003
    Other
    36
    19,948
    58
    2216 Post(s)
    57 Thread(s)
    the problem with the alto is that the fresh air vent door has a foam on it that is supposed to be stuck with glue to the door - the problem is that Suzuki are so broke poor that they cant afford to put glue on the foam. You will need to open up the whole unit inside - remove evaporator - (meaning all refrigerant will be lost) and then remove the whole HVAC unit to get to the control door and glue it properly
    affan555's Avatar
    Mar 2010
    Shenyang
    25
    893
    3 Post(s)
    the ac of my alto is v gud........... u must chk ur ac gas
    Breezers's Avatar
    Jul 2010
    7
    Try this what Xulfiqar said if the Gas is OK.
    Jun 2009
    Select City
    8,406
    10 Post(s)
    Thats not an issue,
    The 2NZ FE (Petrol) Corolla is also having only one fan.
  12. #12
    Xulfiqar's Avatar
    Aug 2003
    Other
    36
    19,948
    58
    2216 Post(s)
    57 Thread(s)
    exactly right - because the condenser is small but good - just infront of the radiator, hence one cooling fan is enough to suck through it.
    You may want to have your systems pressures checked it may also be a weak expansion valve (weak as in stuck) a properly working expansion valve block will superchill the evaporator while a not so good one will either load the compressor or not cool down the evaporator to freeze temperature
  13. #13
    LIANARULES's Avatar
    Feb 2009
    17
    5,905
    5
    42 Post(s)
    Alto Indeed has an awesome A/c but it has glitches get ur car checiked from a dealer and get it repaired under warranty!
    Under the Coconut tree
Similar Threads
  1. Suzuki Alto VXR
    By saint71 in forum Member Opinions & Suggestions
    Last Post: 24-07-2012, 12:38 PM
  2. vich car is beter suzuki cultus or suzuki alto,,?
    By carsloverdude in forum Preventive Maintenance Parts / Oils / Fluids
    Last Post: 01-09-2009, 10:25 PM
  3. Japanese suzuki kei or suzuki alto
    By deep79pk in forum Vehicles / Bikes
    Last Post: 11-02-2009, 10:48 AM
  4. Video: suzuki alto vs suzuki cultus
    By dani123 in forum Wheels Photography and Videos
    Last Post: 01-12-2008, 05:31 PM
  5. suzuki Alto own
    By Abid85 in forum D.I.Y Projects
    Last Post: 17-03-2006, 11:46 AM
